Question about Zenith D60WLCD 60" Rear Projection HDTV-Ready Television
My Zentith D60WLCD has a green tint
What is causing my Zenith D60WLCD TV to have a geen/blue tint even through the picture is fine, and what must been done to fix it.
  • Noel78 May 20, 2008
    I tried doing a hard reset and got the sme results. Please explain why changing the lamp might fix the problem since it has not gone out?
    Genius:
  • 1,226 Answers
There is a low voltage on the projection that sometime cannot be filtered, some cases can be solve by upluging to the wall outlet then replug it again.
and then test.
But if this not solve you should test the horizontal and veritical cercuit to check the voltage regulator in it.
warning-high voltage inside the TV.
melnavz
Posted on May 19, 2008
    Genius:
  • 1,142 Answers
Try to do a hard reset first and let me know the status
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha May 19, 2008
    Is the TV under warranty ?
  • Maanita Chadha
    To do a hard restet is to take the power cord/cable off from the wall socket and leave the tv turned off for atleat 2 hrs then reconnect and see the status.
    post me the status.
  • Maanita Chadha
    Replace the DLP lamp out of your Zenith or LG, you will need
    to reset the counter…otherwise you may get an annoying reminder every
    few days if you’re surpassed the predetermined hour mark.
    To Reset:
    Ensure the TV is powered on.
    1) Press and HOLD the MENU button on the TV
    2) Press and HOLD the MENU button on your REMOTE
    (hold both these until the service menu pops up 5-10 secs max.)
    3) Let go of the REMOTE button first, then release the button on the TV
    4) Press and HOLD the ENTER (or OK) button on the TV
    5) Press and HOLD the MUTE button on the REMOTE
    (hold both until the LAMP LIFE HOURS appears on the screen)
    6) Let go of the REMOTE button first, then release the button on the TV
    We suggest writing your lamp hours on a peice of masking tape and taping it to the back the TV for future reference.
    7) To reset the lamp counter, press SELECT (or the button in the middle
    of the direction arrove buttons). Hit SELECT a second time to confirm
    clearing the lamp counter
    For certain models, you might have to tweak these steps slightly…offer your inputs!
    Genius:
  • 2,785 Answers
Some transitor is gone bad,you better send it for repair
My tv zenith is working the only ploblemb is the escreen get blue you see evryting blue de color of the people too
Your problem sounds like the projection bulb is going bad. It is the main problem with projection TV's, and is usually very spendy. I would recommend calling Zenith and request a new bulb.
May 03, 2011 | Zenith D60WLCD 60" Rear Projection...
My zenith lcd tv has lost its blue tint. most
the light polarizer on the blue lcd panel is fried due to excesive dust and heat, and therefore need to be replaced. unfortunately, zenith may not sell individual parts of the optical engine, so you'll have to replace the whole optical engine.
Dec 17, 2009 | Zenith E44W46LCD 44" Rear Projection...
60 inch zenith tv m#d60wlcd picture all blue
the part maybe no longer available. p/n
3141VSN180C its an LG part called an optical block but the substitute is for around 900 dollars
3141VSN180H
Mar 13, 2009 | Televison & Video
Zenith D60WLCD Repair
Go to the Zenith repair site. This has been resolved in a lawsuit. Zenith will fix it free of charge through 7/1/2010. The shop just picked my up to replace the light engine free of charge. Call 1-800-228-1757, have your model number and serial number, and where you purchased it. Here's the neat thing-the question I asked is "have they fixed the problem with the light engine, or is it going to keep going bad?" If happens again (blue lines/spots) before 7/1/2010, they'll replace the TV with a new and different TV of equal value!
Sep 21, 2008 | Zenith D60WLCD 60" Rear Projection...
Zenith Model SY2551S 1996 27" - Green Tint
The core problem with the green tint is the aging of the picture tube, and can be compensated a bit by using either the green drive control usually located on a printed circuit board on the neck of the picture tube or on the main chassis. There will be 3 main controls which will adjust the red and blue as well. If these controls are not present then you will need to get into the service menu and adjust it from there. Don't adjust anything else as you can make the set much worse. Also remember that in order to make these internal adjustments while watching a black and white picture (turn the color all the way down) you will have your hands and arms near live circuits that could shock you and cause injury to yourself as well as break parts inside the set when you pull back after being zapped (voice of experience here) Of course if you can do all this by the service menu then you won't even have to remove the back of the TV.
Sep 08, 2008 | Zenith C27A24T 27" TV
Orange and fuzzy
have the optical engine replaced
Jan 01, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith D60WLCD 60 in. Rear Projection
CALL ZENITH AND PROVIDE SERIAL NUMBER AND PROOF OF PURCHASE. THEY WILL SEND TECH OUT TO FIX OR REPLACE TV. THIS IS A PROBLEM WITH MANY PROJECTION TV'S BECAUSE OF A FAULTY PART.
Oct 03, 2007 | Zenith D60WLCD 60" Rear Projection...
Zenith D60WLCD with blue haze over entire picture
throw the set away!the part required to repair the set is the optical engine.Zenith made alot of these sets with defective engine assemblies in wich the lcd filters burn,which cannot be replaced.The labor is also silly.Theunitrequires a complete teardown for replacment.You could buy a very nice new set for the repair bill
Feb 20, 2007 | Zenith D60WLCD 60" Rear Projection...
Zenith D60WLCD 60" Rear Projection HDTV-Ready Television Logo
200 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
