Question about GE Refrigerators
Fridge stopped getting cold
I dont no what model I have but I do have a manuel that is for models 20-27
I all of a sudden stopped getting cold it still makes ice cubes but both sides are warm
  • 828 Answers
Check for frost on the back wall of the freezer section. If there is frost there your problem is defrost related to a timer or defrost heaters. I say this because you indicated it still makes ice cubes which indicates it is still working to some degree. Check the condenser for cleanliness and clean if necessary. Under the refrigerator front behind toe plate and /or in back behind removable panel.
Posted on May 19, 2008
My maytag fridgerator has suddenly stopped getting cold. My freezer is fine and stays cold. Troubleshooting it did not work. Please help.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Jul 30, 2011 | Maytag MBF 2256 Bottom Freezer...
Hi,i have chescold rt50 fridge freezer,older model,colourbond brown colour,recently i have replaced the 240v element and the fridge work perfect again,at last camping trip i used on gas and work icy...
try disconnecting thermistor let run if cold replace thermistor if not bad board or cooling unit look for yellow stains on cooling unit or if you smell ammonia
Oct 13, 2017 | Dometic Refrigerators
Maytag side by side model MSD2757AEB suddenly stopped working. The freezer is thawing and dripping fluid on the bottom left side of fridge. It is still running and is putting out cold air, but it doesn't...
Could be that you have a bad freezer (defrost) thermostat and it is not "shutting off" after a defrost. Do you feel heat (DON'T touch the panel) near the bottom rear panel inside the freezer? Also, could be a Adaptive Defrost control problem.
http://refrigeratorheaterrepair.blogspot.com/
Dec 28, 2010 | Refrigerators
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
My Whirlpool Refrigerator Model ER8MHMXML02 isn't as cold. Help!
Freezer drain plugged and froze up also froze the air returns to frig
Aug 22, 2009 | Whirlpool Refrigerators
Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Jul 06, 2009 | Dometic RM2620 Refrigerator
All of a sudden stopped getting cold in the fridge portion, freezer is fine
If you completely defrost the freezer and restart the unit and it doesn't get cold in the refrig portion it could be the internal fan that moves cold air from the freezer to the frig area if it does get cold after an hour or so then it is probably the defrost coil needs replacing. I am not familar with your exact model but this senario applies to many different units.
Apr 18, 2009 | Refrigerators
Freezer suddenly stopped freezing and fride is not getting cold
Hi, I would try putting your refrigerator and freezer control switches on medium. Good Luck,I hope this helps you out.
Nov 07, 2008 | Whirlpool Refrigerators
Whirlpool Arc7410 fridge/freezer
that isn't a good model number doesn't show up on sears but if you're saying you touch the cold control and it runs then the control has to be replaced,when it stops try tapping on the control and see if it starts,the control tells it when to come on and off,they do go bad.go here and look up your model and you can see the part number,if the freezer is on top open the fridge door and look on the left side wall up near the ceiling and you should see a tag with the model number,if the freezer is on the bottom or side by side open the fridge door and look up at the right hand wall near ceiling and the tag is usually there,also there's a timer in some of these units and the timer tells it when to go into defrost and if this sticks this can also happen and they can be in the same area up in the console where the light is or like my fridge both are up top on fridge side,if you know where the timer is you can try turning it with a strait screw driver and see if it starts when you turn the timer but try to do this gently,if you tap the cover and it's the cold control you might start it lol all it sometimes takes is a light tap and the control will work again,if it doesn't start when the timer clicks from turning it just a few clicks then it will be the cold control and most probably it will be that,you can change it out,not hard,just install it the same way you take it out.
Dec 02, 2017 | Refrigerators
Open Questions:
GE Spacemaker JVM1339ww002 - looking for photo of plugs in control board plugs for reassembly or a wiring diagram? Disassembled without noting locations and now start & clear buttons do not work. I have a very old model GE spacemaker XL microwave, model# JVM1339ww002. I repaired the #1 key by cleaning contacts and reinserting the ribbon connector to the control panel. However, I did not photograph the connections. Some plugs have only 1 location where they fit. However, 2 pairs of plugs are the same size and I do not know the correct place to reinsert them. I took a guess & reassembled the microwave and it worked except for the start/clear buttons. If you press a number 2 shortcut for example, it will cook 2 minutes and the food is heated. However, start and clear do not work at all. These buttons DID work before I repaired the numbers. I contacted GE and they gave me a hard time about providing the wiring diagram which was removed or not inside my microwave. I am not sure if I reassembled the plugs wrong OR if I broke something else when I was repairing the numbers. Can anyone help me with the right locations for the 2 pairs of plugs listed below? And/Or tell me if it sounds like start & clear are a new problem or will be resolved by getting the plugs correct? These are the 2 sets of plugs that can be inserted in either location: 1) a pair of matching white plugs that snap in place along the bottom (1 has white wires only and the other has 1 white/1 black wire) 2) a pair of red and white plugs of equal size in the middle of the board. They are similar (but smaller) to plugs in wall outlet with 2 prongs. Similar to a wall outlet, you can rotate the plug 180 degrees and they still fit. In other words besides asking which plug is upper or lower, do I need to worry if the plug is upside down or this doesn't matter? The red plug has black wires, while the white plug has blue and white wires.
Apr 19, 2018 | GE Refrigerators
Refrigerators Logo
183 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
