Question about Sony Playstation 3 (PS3) Console
Disk detection when I insert any type of disk (CD/DVD/BD), the playstation does not detect it. The auto run is activated and it is updated with firmware V 2.30.
  • reeseraw May 19, 2008
    None of cd, bd,dvd, and the games doesn't and I updated my software 2.30. What should I do.
You have to send it in for a repair. same thing happened to my friend and he sent it in and it came back good as new in under a week.
Posted on May 19, 2008
Cd drive not detected
This is usually a sign that your disc is corrupt or that the drive itself has failed.
Jul 28, 2013 | Lenovo Computers & Internet
Can this burn using dvd+r rw? 'Cause it does not detect the blank dvd if I try to burn it using Nero 7.
is it only using nero that it does not detect your blank dvd ??
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 05, 2011 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
My sony blu ray drver not play blu ray dice only
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver
http://download.cnet.com/sun-cd-dvd-burner/3000-2646_4-10308060.html
Sun CD/DVD Burner can back up data on CDs and DVDs, store large media files, and compile music CDs. It can burn and save whole ISO files, as well as create multisession CDs and erase rewritable CDs. Sun CD/DVD Burner supports almost all kinds of driver types including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB). The program also supports the ability to drag and drop. Version 3.10 may include unspecified updates, enhancements, and bug fixes.
What
Jul 31, 2011 | Sony BD-5300S-0B 12x Internal BD-RW...
DVD A DS8A1H ATA drive is not detected by Device Manager at times and will drop out sometimes after running for awhile. The problem seemed to start the last time that I used the itunes program. The device...
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jul 18, 2011 | Computers & Internet
How to watch movie here??
Perform an observation of the computer devices disk location compartments. For example, computers would provide logo indication of what media disk is displayed on the location drive. In situation that the computer disk area has CD rom, DVD rom, or CDRW or DVDRW is indication that movie disks with mentioned logos is displayable at insertion. Second, observe that the computers disk logos made specific demarcations least an alternate disk would least produce impressive expectations. Acquire a disk media at retails with movie material. Once inserted in computer disk compartment should take effects discussable. For example, the computer is prior designed to auto detect media material at insertion in components. Computer program also known as multimedia player displays momentarily after disk has been detected on computer. Compatible disks would display the media expectation either as audio CD or DVD movie. Alternately, in situation that the computer least displays recognizing media disk is indication that each entities has malfunctions. First disk media that least has movies or encountered malfunction is least recognized at insertion in computer compartment. Second, computers that least has the innovativeness of the disk media least recognize an impression. Alternately, computers that an internet connection would recommend a means to restoring malfunction that is encounter at inserting media in compartments. An expectation is to perform update to capture displays to outdated disks. Alternately, modern disks are recognized on computers that have network connections as least having the programs to capture an impression.
Feb 27, 2011 | Computers & Internet
PS3 is not reading any discs I insert into the system.
The following types of discs can be played Blue Ray Disc - Playstation No 3 format BD-ROM, BD ROM,BD-R, BD-RE DVD - DVD-ROM, DVD+R/RW, DVD-R/RW, AVCHD, DSD disc CD - Playstation format CD-ROM,CD-DA (Audio CD), CD-R/RW
Also Check the regional code on the disc which should be compatible with the regional codes which can be played by the PS3
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
CD-RW/DVD drive doesn't detect disk on Acer 2930z laptop
may be your combo drive go to demage change it replace another or you use external usb cd rom or DVD must be select usb cd rom/DVD
Nov 23, 2009 | Acer Aspire 2930-4661 Notebook
Device- SONY CD-RW CRX320EE It is detected by the OS(Xp-64bit). Device Status- working properly. Disks(any type) when inserted not detected . More over i can access the drive when i double click it even...
make sure it is not a DVD disk you are trying to insert into your Drive because your Drive is a CD-RW will not read DVD nor burn onto it.
Your disk may be damaged or corrupt and the drive cannot read it.
your drive may need a firmware update from Sony.
use this link below to access Sony's website to download drivers.
here is the link:
http://sony.storagesupport.com/
Jul 17, 2009 | Sony Computers & Internet
MY DVD/CD DRIVE DOES NOT WORK IT WILL NOT READ THE DISC cannot play dvd,cds or load or make dvds or cds
Open the drawer.
Insert a disk, rotating the disk so that the writing on the face of the disk is "level".
(Imagine a clock-face on the disk; rotate the disk to make the writing go from "9" to "3",
not "10" to "4", nor "12" to "6".)
Close the drawer.
Wait a minute (to see if the disk should automatically start spinning).
Hold down the "Windows-flag" key on your keyboard, and touch (once) the 'E' key.
Wait a few seconds.
Open the drawer.
Is the disk still at the "9-to-3" position?
If so, then the CD-drive has *NOT* read the disk at all, and it needs to be replaced.
Try the above with the same disk in another computer, to see how it _should_ work.
Then, shutdown your computer.
Turn it on.
Look for the message: "Press DEL to enter setup".
Quickly, press the DEL key.
When you see the "setup" menu, press ENTER.
You should see at least 4 similar lines:
AUTO ... AUTO
AUTO ... AUTO
AUTO ... AUTO
AUTO ... AUTO
If you see 'NONE' anywhere, press the TAB key (or the DOWN-arrow key) until that 'NONE' is highlighted, and press PG-UP/PG-DOWN until it changes to AUTO.
Repeat for each 'NONE'.
Press ESC once to return to the "main-menu".
Press RIGHT-arrow and DOWN-arrow to highlight the "Detect Drives".
Press ENTER.
It should auto-detect your CD-drive, within 1 minute.
When it's finished detecting, press ESC.
Use the "arrow" keys to select 'SAVE CHANGES'.
Select it, and save the changes.
Let it reboot.
Now, is your CD-drive working?
Within Windows, hold-down the "Windows" key, and (once) touch the 'E' key.
Do you see an icon for the CD-drive?
If not, then the CD-drive is *NOT* physically-connected (either ribbon-cable or power-cable) to your computer's motherboard.
Apr 22, 2009 | Toshiba (WMD070AC) Magneto-Optical Disk...
Does not detect any tipe of disk
TAKE A HIGH POWER AIR CAN AND SHOOT IT IN THE DVD/GAME INSERT DRIVE FOR ABOUT 20 SECONDS, IT WORKED FOR ME
Aug 05, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
