Question about Maxtor (6B250S0) (6b250s0-20pk) 250 GB Hard Drive
Maxtor 250 GB SATA problem: Foreign disk problem
I have a problem with my Maxtor 250 GB SATA Hard Drive, It is detected by my pc, it's there in the BIOS but it is not displayed in My Computer, and in Computer Management, it's not displayed on the upper pane but it's diplayed as foreign disk on the lower pane with a yellow triangle facing down and an exclamation mark.
  • bflowz May 21, 2008
    The HDD was working before, it recently gave me this problem
Firstly, Unplug the cable connecting to the external HDD. Then go to my computer, right click on it and select use your legs and hands to dismantle maxtor HDD. Look at the maxtor brand title on the HDD. Press the 'X' letter as hard as you can for at least 100 times. The external HDD will open up to form the shape of letter 'X' and there will be a button called start to initialize the harddisk. After finish using, unplug the drive and HOLD IT TIGHTLY. IF NOT, IT WILL
FLY UP INTO THE AIR TO THE CEILING AND THE LIGHT WILL TURN RED WITH A EXTRA LOUD BEEP SOUND THAT MAXTOR DRIVES HAVE!!! GOOD LUCK!!!
Posted on Dec 14, 2008
    Scholar:
  • 119 Answers
Simple you need to update your bios by downloading bios updates for you motherboard. Then it should recognise your HDD. The yellow triange just means your mboard does not have the necessary drivers to recognise the device. thanks
Posted on May 19, 2008
I need driver for diamondmax 21
Turn the computer off.
Turn the computer on, and press <DEL> to enter BIOS SETUP.
Ensure that the hard-drive is "enabled", and set to 'AHCI'.
Save the BIOS settings.
Reboot, and install Windows.
May 03, 2015 | Seagate 250GB Maxtor DiamondMax Plus 21...
I AM LOOKING FOR LATEST DRIVER DRIVERS FOR MAXTOR DiamondMax 21 SATA 250GB Hard DRIVE FOR WIN XP-PRO PC
The latest drivers and support would be available from the Seagate website. The Seatools utility is an excellent tool that is also available.
http://www.seagate.com/www/en-us/
I hope this helps.
Sep 03, 2011 | Seagate 250GB Maxtor DiamondMax Plus 21...
Please, i have two hard drives, the first one is maxtor 80 gb (which i want to make master),the other one is sata sumsung 750 gb (which i want to make salve), how could i get that done ?
Hi!
That can be done from BIOS setings. First check that both the disks have been detected by the BIOS.
Usually, the hard disk at sata1 (1st sata connector on board is for master drive.
Secondly, look for the bootup option and choose maxtor as primary drive (to boot from it)
Hope this helps!. let me know about *********** board details also, if further any assistance is needed.
CreativeTECH
Nov 10, 2010 | Samsung SpinPoint T HD501LJ 500 GB SATA...
Will not recognize sata drive need to know necessary connections
There are only two connectors on a SATA drive, namely POWER and DATA.
Check that both cables are securely connected.
Try the disk-drive in some other computer.
Nov 02, 2010 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
I cant erase the files in my hard disk, if i erased it, it's keep on comimhg back..what will i do?
INFO:
Files are never really erased from a hard drive.
At various stages files are always recoverable.
RECOMENDATION:
To truly erase your hard drive take it out and completely destroy it down to many small parts.
Reformat the hard drive.
Hope this tip helps.
r/
David
Mar 11, 2010 | Seagate 250GB Maxtor DiamondMax Plus 21...
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
MY PC HARD IS NOT DETECTED
IF THE HARD DRIVE IS IN WARRANTY THEN SEND IT TO SEAGATE FOR WARRANTY CLAIM. TO CHECK THE WARRANTY STATUS GO TO THE SEAGATE WEBSITE. SEAGATE GIVES 5 YEAR WARRANTY.
DONT FORGET TO VOTE
Oct 10, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
My slave hard disk is not showing in my computer
Is it formatted ? Does it have a drive letter associated to it? If not then either format it (right click on My computer -> click Manage -> click Disk Management. Now right click the drive if it is showing there and either create partitions and/or format it if it not already formatted.
If it's already formatted, and you just need to assign a drive letter, then in Disk Management, right click the drive and click Change Drive Letter and Paths and assign an unused drive letter, say Z.
Close Computer Management and open My Computer. The new drive should show up now.
HTH,
Deboo
Jan 05, 2009 | Seagate 250GB Maxtor DiamondMax Plus 21...
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Maxtor III 600 gb will not mount
What Operating system are you using ?
I'll assume your using windows.
Try going to disk management
it may not have any partitions
you can get into the disk management by pressing start --> Control Panel ---> Administrative Tools --> Computer Management --> Disk Management.
Once your in Disk Management you should see the 600gb
After you find it right click and either format / import foreign disk
(This applies to internal hard drive only)
If Hard drive is not listed you may have to set jumpers correctly or check bios to make sure hard drive is detected
Feb 22, 2008 | Maxtor OneTouch II external hard drive...
Maxtor (6B250S0) (6b250s0-20pk) 250 GB Hard Drive Logo
292 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
