Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi Big screen problem
Did you ever find a solution to your blink light problem? I seem to have the same issue. I hope its not to serious because it was working fine this morning. I appreciate your help :)
Thanks
oh and the product I put in isnt the actual one> i just put it in because it asked me for one and i couldnt find mine. I have a 60" mistubishi diamond series rear projection big screen. Bought in 2002 I believe
-Rob
incanpunjab@gmail.com
    President:
  • 4,402 Answers
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Posted on May 22, 2008
Mitsubishi big screen model wd73cp
It is in shutdown because either a short or a serious problem in the set.
GOOGLE the model with error codes to find out how to read what the lights on front (if on or blinking) mean.
Mar 19, 2012 | Mitsubishi WS-55511 55" Rear Projection...
I have a WD-52525 set that the green light kept blinking after a power outage. The reset button never worked. I unplugged the set for 30 seconds and re-plugged it back in. The light began blinking between...
Bad digital/power module. Contact Mitsubishi, they may cover part of repair, I am serious. If not, have a an authorized servicer send module to Mitsubishi for rebuild program. The only economical solution.
Jan 18, 2011 | Mitsubishi WD-52525 52" Rear Projection...
We have a Mitsubishi Big screen projection tv model no. VS-50705. when the on button is pushed it clicks like it wants to turn on but then doesnt. When I unplug and plug back in the green light flashes...
This could be a trouble code for your model television. Try counting the blinks and note any pauses in blinking. It could be a one or two digit trouble code. Then once you have that number, type in your tv model along with the words "trouble codes" or "diagnostics codes" or "green light blinking" and see what you get. Hope this helps...
Jan 08, 2010 | Mitsubishi WS-65712 65" Rear Projection...
Why does my Mitsubishi Big Screen television keep turning off by itself?
probably had digital module, if it's intermittently doing to blinking green light, if not a blinking light, then probably solder connections on the board or yoke connectors.
Aug 31, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
My panasonic big screen wont turn on
find out if someone can push the rest button on the side somewhere in a certain sequence
Feb 07, 2009 | Mitsubishi WD-52725 52". Rear Projection...
blinking light stays blinking even after re-set
Jan 17, 2009 | Mitsubishi WT-46805 46" Rear Projection...
My Mitsubishi big screen tv will not come back on
Is the light blinking a certain number of blinks then pausing?All mistubishi have a diagnosis feature built in. Try pushing the input and menu buttons on the set and holding them both in for 5 seconds to see if it will blink a diagnosis code.
Feb 10, 2008 | Televison & Video
Big Screen Televison problem
Need to try self diagnosis, it's here in threads. If not you need live chat!
Oct 01, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
