Question about Philips Lands Phones
No power ... check batteries and when charge no indication on charging unit.
  • 1,944 Answers
Sounds like your batteries have malfuntioned. You should get new batteries.
Posted on May 19, 2008
Power portastudio
Gel cell batteries usually are good for 3 to 5 years and from your description, it sounds like the battery is not recharging properly. They will indicate a full charge but in reality, do not have the stored power to operate the device. Check for replacement batteries at your local burgular alarm shop or buy online BUT make sure to match the voltage and AH (amp hours) ratings.
May 09, 2014 | Anchor Audio PB-2500 Battery powered sound...
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
on May 14, 2015 | Xantrex Technology Electronics - Others
Show charging symbols
Your question was posted under the Nuvi 680 GPS, so I am assuming this is the model that you have.
On the main screen, you will see a green battery status indicator in the upper right-hand corner of the screen. The battery is divided into 4 parts. Each part represents 1/4 power. So if you have one green bar, that indicates that the battery has 1/4 of power left. If there are 3 bars, that indicates that there is 3/4 power left.
When the unit is charging, you will see a yellow lightning bolt appear over the green battery status icon.
When the lightning bolt is not there, this means the unit is running off of the battery.
When leaving the unit to charge, press and hold the power button until you see that the screen says Charging Battery. A few seconds later, the screen will go blank to save energy.
Pressing the screen again later will either say Charging Battery or Battery Charge Complete.
Mar 26, 2013 | Garmin Nuvi 680 GPS Receiver
Garmin nuvi 2555lm battery want charge
A common problem with these units are loose/broken connections on the rear USB port. There are 5 pins on this port. If the power pins are loose/broken, the unit will not be able to charge the battery. The unit will not turn on because the battery is dead. Even if you plug in the charger, there battery will not charge.
The unit will not charge the battery if it won't turn on.
While you could have a bad battery, the Nuvi 25xx series is not that old and the date code on the battery is probably from 2010 or later.
If you plug in the charger, the green battery status indicator should go away or you should see a lightning bolt appear over the battery status indicator . If you don't see a change to the battery status indicator when you plug in the charger, then this confirms that the rear USB port is broken and not applying a charge to the battery.
More information can be found here:
Mar 25, 2013 | Garmin nuvi GPS
How long does it take to charge a new garmin660?
If the battery is in good condition, just a couple hours. Plug the charger into the unit and you should see a yellow lightning bolt over the battery status indicator. 4 green bars means the battery is charged. Anything less and it is not.
To leave the unit in charge, press the on/off power button until the screen says battery charging. You can check the charging status by just touching the screen. If it says battery charge complete, then you are done.
More info here:
- Jim
Aug 26, 2011 | Garmin Nuvi 660 GPS Receiver
Does not power on although charging led is on....
You may have a defective battery. Depending on the notebook and battery, try one of following procedures to confirm if this is merely a battery problem:
1. Examine the battery to see if there is a built-in charge status indicator on it. These will be a series of LEDs and a button that, when pressed, will cause one or more to illuminate. If none of the LEDs illuminate, even after the unit has been charging for some time, you probably have a bad battery. Or
2. Remove the battery from the notebook, attach the power adapter, and turn on the computer. If the computer runs WITHOUT the battery installed, you probably have a bad battery.
Apr 15, 2009 | Computers & Internet
Is m Garmin nuvi 200 GPS charging
Merritt, Your Garmin Nuvi does not have a charging indicator similar to say your Cell ph. Simply a battery charge indicator scale. Normal full charge time is approximately 3 to 4 hr. If you looking to ensure your unit is in fact charging Plug in & then remove the connection, Your unit will pop-up a screen to request if you wish to remain on battery power. I hope this helps you.
Mar 09, 2009 | Garmin nuvi 200W GPS
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
Lands Phones Logo
49 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
