Question about Estate TGDX640JQ Gas Dryer
Timer doesnt move while dryer is on
Timer doesnt move heat doesnt come on but dryer will run nonstop. I checked fuseable links and replaced timer
  • 07aj Jun 17, 2008
    having trouble with dryer heating, drum turning but no heat
    New Friend:
Clock in timer bad. replace timer.
Posted on Jul 23, 2015
    Genius:
  • 1,142 Answers
Please page me here so that i can get back to you
Posted on May 19, 2008
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 | Dryers
My Kenmore HE4 electric dryer runs for 2 minutes and stops
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replac it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Oct 01, 2013 | Kenmore Elite HE4 Electric Dryer
Frigidaire AEQ8700FGO dryer will run (and heat) for about 30 to 60 seconds then stop. 3 lights above start button will flash rapidly. Depressing cancel and start buttons at same time will not work for...
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
Sep 30, 2013 | Electrolux AEQ8700F Electric Dryer
Dryer tumbler for a short time then shuts off,will not run a full cycle like it stuck
see this causes and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and needs replacing. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace the Heating Element.
Sep 27, 2012 | Amana ALG331RAW Gas Dryer
The timer does not work correctly. The timer does not move and the dryer runs forever.
If the timer doesnt even advance in the time dry cycle then you have a bad timer. However you will need to make sure that your getting heat throughout the auto dry cycle because no heat will cause the dryer to run forever. Hope this helps _MJ_
Aug 17, 2010 | Kenmore Dryers
Dryer won't heat
you spent a lot for a timer when you needed to check your heating. check the heating element, the high limit, and the thermofuse
Sep 25, 2009 | Whirlpool LER5636P Electric Dryer
Whirpool amana dryer runs but no heat. on timed try timer doesnt move either.
HI, the timer motor is malfunctioning. this can affect the way you dryer heats in this case. I would advise to check the thermal fuse before replacing the timer. it is located on the blower house or, on the vent duct. in will show no continuity if defective. replace the timer if the thermal fuse is showing good continuity when measure with a meter.
Jul 24, 2009 | Whirlpool LER4634J Electric Dryer
When u turn on my gas whirlpool dryer it runs as normal. when u check on it a little later (on automatic dry) the timer has not moved, and the dryer has quit producing heat
Hi, the timer control the heating commands and, if its not moving(rotating), this will confirm timer failuer. replace it asap.
Jun 18, 2009 | Dryers
Whirlpool Gas Dryer, LGR5636EQ2, timer not moving on Auto (DryMis
If that is a 3 wire gas assembly then the timer is screwed.The orange wire when removed from the mix will make the thing advance. The trouble is in the timer. If that is a 2 wire gas operator you need to change the high limit and open up the outside vent. My opinion.
Nov 14, 2008 | Whirlpool GGQ8831L Gas Dryer
Estate TGDX640JQ Gas Dryer Logo
212 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
