Question about Logic Soundlab CPX1820 Car Audio Amplifier
Amp fuse i have logic soundlab 1820 amp. there is two fuse holders on the amp its two channel amp. i need to know what size fuses i should put in the amp, and what gauge amp wire should i use, and maybe what kind of capacitor would best best?
There are two 40 amp fuses in the unit I have.
Posted on Aug 23, 2008
Maxon wire fuses
If a inline fuse in a holder the old one will aside from length have the amperage printed on it---very few mobile radios use larger than a 3 amp fuse-----look on metal ends of old fuse if have it for markings like 3ag 3 250---3AG is size, 3 is 3 amp, 250 is max working voltage (120 is fine).
Oct 24, 2012 | Maxon MCB-30 40-Channels Base CB Radio
Nitro 482 2 channel amp.....what size fuse goes in the fuse holder on the amp
http://www.youtube.com/watch?v=B9BJEPPans4&feature=player_detailpage
Apr 14, 2011 | Nitro BMW-482 Car Audio Amplifier
Amp
you want to put a 30A into the amp and the inline fuse that you put onto the wire should be greater than 30A but not too high for what the wire is rated. The best bet for wire is to buy a wiring kit which comes with fuse holder, right size fuse, wire for main power ground and remote. You may want to double check what is written on amp for the size to put in there. Technically you can put a 100A onto the wire if it is big enough and the fuse on amp will protect the amp from problems. Hope this helps, Good Luck
Mar 25, 2010 | Ultra Linear UL801 Car Amp
Logic soundlab plx 46 red led lit in center of board what does it mean?
does it have sound if not it may be on a protect or themal mode try taking our=t your main fuse when the system is in and put it back in
Dec 17, 2009 | Logic Soundlab PLX-520 Car Audio Amplifier
Jensen LXA400 Fuse Size and RCA hook up for 2 channel mode?
take it to a stereo shop. there are variables you may not be aware of when hooking up speakers to an amplifier like ohms, very important!
Dec 08, 2008 | Jensen LXA400 Car Audio Amplifier
Car audio
Product Details and Features PLX-520
Key Features
Amplifier Type grayquestion.gif Dual Channel Bridgable grayquestion.gif Bridgable RMS Power at 2 Ohms 400 W x 2
Performance
Frequency Response 10 Hz - 50000 Hz Signal to Noise Ratio grayquestion.gif 102 dB THD at Rated RMS Power 0.01 %
Crossover / Equalizer
Bass Boost grayquestion.gif With Bass Boost Low - Pass Frequency 50 Hz - 120 Hz High - Pass Frequency 80 Hz - 800 Hz
Other Features
MOSFET Circuitry Yes 3 Way Ready Yes
Dimensions
Width 10.4 in. Depth 17.7 in. Height 2 in. ..This is what I found for logic soundlab PLX-520 Amplifier, hope its what you were looking for. Don't forget to rate answers.
Mar 31, 2008 | Logic Soundlab PLX-520 Car Audio Amplifier
Logic alx1280 2 ch amp
Amps can be rated based on their RMS power or their peak power. In this case, the amp's rated RMS power is 300x2 at 2 ohms (total 600W RMS) with a peak power rating of 600x2 (1200W peak). For the most part, peak power means almost nothing.
If your head unit didn't have RCA preamp outputs, you would used the standard speaker outputs from the head unit and connect them to the hi input plug of the amp.
Mar 17, 2008 | Logic Soundlab ALX1280 Car Audio Amplifier
BLAUPUNKT TRAVELPILOT E1 RADIO/SAT NAV
Nov 21, 2007 | Car Audio & Video
Need to know what size fuse do i put in this amp .
Owner's manual
According to the manual, the maximum current draw is 30 amps.
Nov 09, 2007 | Legacy 2 Channel 1600 Watt Bridgeable...
Logic Soundlab CPX1820 Car Audio Amplifier Logo
531 people viewed this question
Top Logic Soundlab Car Audio & Video Experts
Tygh Duval
Tygh Duval
Bill Boyd
FastHarley
FastHarley
Are you a Logic Soundlab Car Audio and Video Expert? Answer questions, earn points and help others
