Question about GE Microwave Ovens
I have an F3 displayed on the dispay for my micro model# JES1036WF001 SERIAL# TD973308 WHAT DOES THAT MEAN?
  • GE Master
  • 9,098 Answers
F3 means you have a failed keypad.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's at http://www.microwavedisplay.com/keypad_replacement.pdf
Otherwise, we can do that for you for only $39.95 plus part cost.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Posted on May 22, 2008
Out of no where I get and F3 error messaGE AND A BEEP BEEP BEEP the model # is JES1036WF001
Hi
F3 error in your GE microwave means that the keypad/touchpad is bad and should be replaced. However, before replacing it you can follow these step by step instructions to clean the touchpad assembly and see if it works:
1) Unplug microwave
2) Remove two small screws from upper face plate
3) Remove screw on upper side of control panel
4) Life panel and pull out
5) Identify flat tape-like harness connecting circuit card to keypad
6) Wipe down harness with an all-purpose wipe
7) Use hairdryer to dry remaining leftover moisture
8) After this put the keypad back if its not solved then replace it.
Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE Microwave Ovens
Frigidaire F3 problem
thank you, problem resolve....bought new micro
Mar 22, 2009 | Frigidaire FMV145K Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Micro beeps 3 times with "F3" flashing on LCD screen. Nothing works.
If it's a GE model, F3 will mean a shorted key panel.
(If it's not a GE, please reply back with your brand and model number so we can help you).
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
BUT If you would like to have us do this for you, we do that for $39.95 plus part costs.
prototech@usa.net
Jun 24, 2008 | GE XL1800 1100 Watts Microwave Oven
I have a GE microwave. The display panel says F3 and the microwave beeps and will not run. If I unplug it it will then work if you use it right away. But then it will display F3 again and beep and not work...
F3 means that your keypad is shorting.
If you'd like to have us fix it for you, we do that for $39.95 plus parts. We repair them for customers nationwide.
Or if you want to do it yourself, please contact me directly and I'll give you details on parts and procedure.
prototech@usa.net
Apr 26, 2008 | Microwave Ovens
Samsung MR6699GB
This model was one of many subject to a recall due to defective membrane keypads.
Details of the recall are here: http://www.allworldauto.com/recalls/NHTSA_03E044000__SAMSUNG_MICROWAVE_MR6699GB_recall_55168.html
Long story short, please unplug it and contact Samsung with you model and serial number at 800-932-3837.
If your serial number was not one subject to a recall, E2 usually means a temperature sensor problem but it may also mean you have a bad door switch.
If it's not in the recall, please post back and I can give you info on checking the other parts.
Feb 13, 2008 | Samsung SMH7174BC Microwave Oven
F3 Error Message
It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
prototech@usa.net
May 29, 2006 | GE JVM1861SF Microwave Oven
Microwave Ovens Logo
264 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
