Question about HP Pavilion dv6000z Notebook
Can not find system protection tab.
How can I make the system properties show the missing system protection tab, without it I can not create restore points. The only tabs available are computer name, hardware, advanced and remote.
I tried everything that I could possible try, based on my knowledge, which is very limited.
I have Window Vista, HP Pavilion dv6000 Laptop.
Thank you very much.
  • 57 Answers
The best thing to solve your problem is to reformat your system.it will cure all problems and also bad history.
Posted on May 19, 2008
Where do I go in the system to set the default storage to the sd card?
SD storage card restore to defaults
Click start click to open on my computer you should see your usb drive F: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Take Off Write Protection on an SD Card
Secure Digital (SD) flash memory cards are a common storage format for mobile devices.
By default, they allow both reading from and writing to the card.
However, they can be set so you can only read from the cards and not write to them.
Some cards are created as read-only by default.
Other times, a faulty card reader may mistakenly read all cards as read-only.
In both cases, you can make simple changes to the card to disable the write protection.
1.
Orient the card so the label is facing up.
Slide the write protection tab, which is located on the left side of the card, to the unlocked position.
If there is no write protection tab, skip to Step 4.
2.
Test the card in your computer.
Insert the card in the SD slot and open the folder to view the files.
Try to save a file onto the card or right-click an existing file and select "Properties," then uncheck the box marked "Read-only."
3.
Remove the card and check to see the write tab is still set to "unlocked" if you get a message that says it is still write-protected.
If it has become locked again, slide it back and tape it in the unlocked position.
4.
Place a piece of masking tape over the notch in the SD card located on the right side of the card. Make sure the tape does not cover any of the card's metal contacts.
Test again as in Step 2.
5.
Cover the notch with a second layer of tape if the card is still giving you problems.
http://www.getflashmemory.info/hack-why-is-my-sd-card-write-protected/
Aug 15, 2013 | Avatar Sirius S701-R2A-1 4GB NAND Flash 7"...
Tip
How to back up the registry in Windows Vista
1.Click Start, type systempropertiesprotection in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
2.Wait for Windows to search for available disks and most recent restore points. In the System Properties dialog box, on the System Protection tab, click Create,
3.Type a name for the restore point and then click Create
4.After the restore point has been created successfully, click OK two times.
Note: If System Restore is turned off, click to select the local disk, click Apply and then click Create.
on Mar 03, 2010 | Microsoft Windows Vista Ultimate Edition
HP System Software Manager
The HP Remote Support Software Manager is an application installed on HP desktops and laptops, that enables Remote Assistance on the computer for HP personnel access. This Remote Support client allows a technical support representative from HP to see and control your computer to assist you with making changes on the machine. The HP Remote Support Software Manager may be safely uninstalled from the computer. Uninstalling this application will not affect any other functions and features. However, you should create a Restore Point prior to uninstalling any software just in case problems arise with the changes. Create Restore Point in System Restore Click the Windows "Start" button and then right-click on the "Computer" entry. Click "Properties" from the context menu. Click the "System Protection" link in the left navigation pane. Click the tab labeled "System Protection" and then click the "Create" button. The Create button label indicates that this action will create a System Restore Point now. Type a description for the manually created Restore Point and click "Create." The System Restore Point is manually created. Uninstall HP Remote Support Software Manager Click the Windows "Start" button and select "Control Panel." Click the "Programs" link in the Control Panel. Click "Programs and Features." The list of installed programs will appear. Locate the HP Remote Support Software Manager in the list and click the entry. Click the "Uninstall" button on the top navigation bar. Type the "Administrator" password, if prompted, and click "Continue." The program is uninstalled from the computer and the entry disappears from the Programs list.
Feb 26, 2013 | HP Computers & Internet
Cosa devo fare dopo il ripristino
google translated
What should I do after recovery
Create a resore point
Click start right click on computer select properties windows update once an update has been installed a new restore point will be set.
or if no updates are available
Click the Windows Start button, right-click "Computer" and select "Properties."
Select "System Protection" in the left menu.
Enter your administrator password or click "Continue" if prompted by the computer.
The "System Properties" window appears.
Click the "Create" button near the bottom of the window to open the System Protection window, which prompts you to enter a description for the restore point.
Type the description in the text box and click "Create."
The restore point is created and a confirmation window appears on the screen.
Click "OK" to exit the window.
Hope this helps
Nov 04, 2012 | ASUS Eee PC 1001PX (1001PXEU17BK) Netbook
Not enough space on friends laptop
First you need to disable system restore on the drive to reclaim the missing space. To do this, you can do the following:
1. Go to Start > Control Panel > System
2. In System > Click on System Protection at the left side
3. In the System Protection Window > go to the System Protection Tab > then uncheck C: then hit Apply then OK
After disabling system restore, run disk clean up:
1. Go to Start > Computer > Right-click on C: > Disk Cleanup - make sure to check all of the files to be deleted to clear as much space as possible
2. After initially running Disk Cleanup you will now be able to see the More Options tab in the Disk Cleanup window > go to this tab then cleanup the System Restore and Shadow Copies to remove them completely
3. Enable the System Restore from the System Protection tab in System.
4. Resize the maximum amount of Shadow Copies that can be saved on the system, this will lock the System Restore feature from saving more than allocated amount. Run Command Prompt as administrator (go to Start > Programs > Accesories > then right-click on Command Prompt then Run as Administrator)
Set the maximum to whatever amount you feel is necessary. Setting it to 1GB should be more than enough for System Restore to create at least two restore points. Type the command: vssadmin resize shadowstorage /on=c: /for=c: /maxsize=1gb
5. Once this is done you should have reclaimed at least 30 to 40% of the missing space. Once the System Restore has been reenabled it will automatically create the restore points so there will be no need to manually create one.
Mar 22, 2010 | Compaq Presario Notebook
Cant find System Protection tab for Vista 32bit.
Do you mean "system restore" ?
If so its under control panel, system, system restore.
If it is turned off already then you will not be able to go back to an earlier restore point.
If you have a virus / spyware issue then take note that these can also hide in system restore points so even if you wanted to restore to a point before a virus or spyware issue you would still restore the bug too !
They can also corrupt the restore points so that they wont work
Aug 10, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
System protection option is not coming in the system protection option of the system window , then how should i enable system restore.
  1. Right-click My Computer, and then click Properties.
  2. On the Performance tab, click File System, or press ALT+F.
  3. On the Troubleshooting tab, click to select the Disable System Restore check box.
  4. Click OK twice, and then click Yes when you are prompted to restart the computer.
  5. To re-enable System Restore, follow steps 1-3, but in step 3, click to clear the Disable System Restore check box.
u CAN ENABLE OR DISABLE UR SYSTEM RESTORE OPTION
ENJOY
REGARDS RAHUL
Feb 22, 2009 | Microsoft Computers & Internet
How to change background
These tabs are the only way to change the background or screen saver. The display properties are integrated into the operating system, so, if the tabs are missing, this is an error with the operating system. Start with a system restore. Keep going back until they show on the display properties. If a restore doesn't work, then you will need to do an operating system repair with your recovery or operating system disc.
Jul 22, 2008 | Acer Aspire 3003LCi Notebook
Desktop properties (desktop and screensaver tab is missing)
The following is solved me
Well if anyone is interested and for general knowledge these are the 3entries that were killing the Desktop and Screen Saver tabs in XP. Hupigon13 seems to be at the root of it all.
Quote: Microsoft.Windows.System: Settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispBackgroundPage!=W=0
Microsoft.Windows.System: User settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispScrSavPage!=W=0
Hupigon13: Settings (Registry value, fixed)
HKEY_LOCAL_MACHINESYSTEMControlSet001ServicessrImagePath=...SystemRoot...
Read full story here
http://forum.osnn.net/showthread.php?s=f44e1bb094fbae9305c9f0c9999c52e7&p=841430#post841430
Jul 16, 2008 | A4tech PK5
HP Pavilion dv6000z Notebook Logo
407 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
