Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Netgear Firewall Hi I have a Virgin cable internet connection and have installed a Netgear RangeMax WPN824v2 for the wireless connection on my laptop. I believe the built in firewall on the router is clashing with the Virgin PC guard causing the internet access and site opening to be very slow. If I disconnect the Netgear and connect direct to the cable modem the speed is fine. Can I disconent the firewall in the Netgear?
  • Himars Jun 07, 2008
    How do I allow port forwarding to port 5721
  • 4 Answers
with the router connected, open the internet explore and type in on the address bar and press enter.
enter the user name and password for the router.(by defaullt user name is admin and password is password).
u can find the blue scrren in left, in that click on the option "Wan ip set up". In that window by default first check box will be checked. Please check the box for the second option "disable SPI firewall". this will deactivate the firewall on the router.
Also in the same page You can find the option MTU size, by default it will 1500. change it to 1400 and click on apply.
check the internet connection whwther it is faster or not.
hope this helps..
Posted on Jun 13, 2008
I have NetGear RangeMax WPN824. I work from home and need access to my desktop at work . I go thru Kaseya to access my desktop at work. I continue to get the same error: "Unable to connecto the KServer@ on Port 5721. Check firewall, router or proxy server is allowing outbount TCP connection to on port 5721."
Is port 5721 associated with the rangemax WPN824? If so how can I enable this.
Posted on Jun 07, 2008
  • 65 Answers
With the router connected, open Internet Explorer and type after you log in there is a option on the left for firewall and you can turn it off. If it were me I would use the routers firewall over a software firewall though. By the time a software firewall detects a hack, its already in the PC.
Posted on Jun 01, 2008
Connecting netgear rnagemax router to clearwire
Restart the modem and router and you should be connected.
Feb 05, 2018 | NetGear RangeMax WPN824 Router
I just bought a Sony Bravia TV and am trying to connect it to the internet via my WPN824v2 LAN - it's not working and the LAN lights never light up on my router. Wireless connections are fine - even new...
I spent the last day trying to solve this, what worked was:
Refresh Internet Content
Wait (a while) until it Authenticates
Normal Internet service resumed :-)
Jan 11, 2010 | NetGear RangeMax WPN824 Wireless Router...
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
I'm not able to connect to the Internet after installing the adapter WPN111S
if you have any firewall or antivirus software in you computer means please turn off the firewall and check whethr the internet connection is working
Nov 12, 2009 | NetGear RangeMax WPN111 802.11g/b Wireless...
How do i hook this router up wpn824v2
Your router is connected between your modem (Cable or DSL) and your computer. Connect the modem output to the WAN or Internet connector on your router. Connect any of the output connectors to your computer's Network Input. Log in to the router by (with your Browser) going to ... after logging to router (login parameters in manual) set your Network Name (SSID) and set up Wireless security. I prefer using WPS-PSK[TKIP] for its ease of setup.
Nov 11, 2009 | NetGear RangeMax WPN824 Router
NETGEAR rangemax router
make sure you have enable wireless in router setup page
if you are using USB key remove cable and see if you can see your network .... if not remove your usbkey and see if your laptop Recognize the disconnect ... need additionla info on yout setup if this does not work
good luck
Jun 07, 2009 | Dell Wireless 2350 Router
Netgear wpn824v2
Plug your modem into the Internet port on the router, plug in any computers that will be hard wired. Open Internet Explorer and type This will start up the Netgear install wizard.
May 22, 2008 | NetGear RangeMax WPN824 Wireless Router...
Just want your opinion
  • IEEE 802.11b, IEEE 802.11g, 2.4 GHz
Physical Specifications
  • Dimensions: 8.8 x 6 x 1.2 in (223 x 153 x 31 mm)
  • Weight: 1.2 lbs (.5 kg)
Performance Advantages
  • When used with RangeMax client adapters, delivers the longest range of any wireless technology on the market up to 500,000 square feet of uninterrupted coverage*
  • Maintains video quality up to 10 times the effective speed when at long distances
  • Improves performance of existing legacy 802.11b and 802.11g wireless devices up to 50%
  • Five 10/100 (1 internet, and 4 LAN) ports equipped with auto-sensing technology
  • Data speed of up to 108 Mbps*
Privacy & Parental Control
  • “Trusted user” controls
  • Time-based usage controls
  • Web site logging
  • Remote management
  • URL content filtering
  • Double Firewall
  • Network Address Translation (NAT) to hide PCs & files from outside users
  • Stateful Packet Inspection (SPI) firewall to deny outside requests for personal information
  • Denial of Service (DoS) attack prevention
  • Intrusion Detection and Prevention (IDS)
  • Wired Equivalent Privacy (WEP) 64-bit,128-bit encryption
  • Wi-Fi Protected Access (WPA, Pre-Shared Key)
  • Wireless Access Control (SSID) to identify authorized wireless network devices
  • Supports 2 VPN pass-through tunnels (IPSec, L2TP, PPTP)
  • Exposed Host (DMZ)
  • MAC address authentication
  • NETGEAR 1-year warranty
Package Contents
  • RangeMax Wireless Router (WPN824v2)
  • 12V, 1.0A Power Adapter, localized to country of sale
  • Ethernet Cable
  • Vertical Stand
  • Setup Guide, Setup CD Warranty/Support Information Card
this product seems good, but do you need only wifi o do you want also wimax?
Mar 05, 2008 | NetGear RangeMax WPN824 Wireless Router...
Wpnt121 and wpn824v2
the rangemax may be 108mbps transfer speed, but are your wireless network adapters able to run at 108mbps?, as most earlier ones will only run at 54 mpbs, especially notebook wireless adapters. You will only gain on 108mbps transfer speed when file transfering or streaming to each pc, it will not speed up your internet connection, although you probably already are aware of that.
Jun 16, 2007 | NetGear RangeMax 240 WPNT121 (WPNT121NA)...
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
337 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
