Question about Sharp AL-1000 Copier
Error on sharp copier
Sharp al -1000 copier shows error E-7 and 15 please help me to rectify it
  • 146 Answers
That has to do with the laser unit and/or the white shading plate.
First remove the platen glass and clean the white strip on the bottom side. BE CAREFUL FOR THE GRAY OR BLACK LINE ON THE STRIPE IF YOU WIPE IT WITH A SOLVENT AND REMOVE THE LINE YOU ARE DONE.
If the unit is making a whining noise it is probably the laser unit polygon motor.
If the scanner mirror system is hanging or not returning to home position check to see that the scanner lock on the underside of the scanner where the paper comes out is unlocked.
Posted on Jun 06, 2008
My Sharp AL 1000 is displaying alternatively the letter H and the number 4. What should I do?
Hello
The error that is on your disply is the following.
The fusing temperature does not reach 175 degrees celsius within 30 seconds of turning on the power, or the fusing temperature keeps at 140 degrees celsius.
In sequence press the following buttons [clear]-[density select]-[clear]-[desity select] the display will go blank.
With the copy quantity keys input 14 and press the start/print button, the machine will cycle.
If the error returns then the thermistor and themo fuse will have to be rplaced.
I hope this helps you
Regards
Apr 16, 2011 | Sharp AL-1000 Copier
Sharp AL-1000 error E7
E7 is CCD drive circuit trouble. Refer to the manual
obtainable from mauritron
Feb 21, 2011 | Sharp AL-1000 Copier
It is a Sharp al 1000 with error message L6 which means Polygon mirror motor not up to speed? How is this fixed and what cost?
Since the polygon motor is part of the laser unit, it would cost about $200 plus labor to replace it
Jun 14, 2010 | Sharp AL-1000 Copier
MY SHARP AL-1000 PRINTER IS PRINTNG VERY FEINT
Could be either one. Probably toner.
Apr 06, 2010 | Sharp AL-1000 Copier
How can i remove H 4
Press c> photo>C>photo press 14 press start/Print key
machine ok
Oct 08, 2009 | Sharp AL-1000 Laser Printer
H 4 FLASHING, MANUAL LOST, AL-1220 Sharp Photocopier
Try to press #, Interrupt, C, Interrupt in that order and enter 14 then press copy key.
Oct 20, 2008 | Sharp AL-1000 Laser Printer
Error Code "L" 0n Sharp AL 1540CS
The scanner does not move - I get an "L" code flashing on the readout - please help???
Jeri
Oct 04, 2008 | Sharp AL 1631 Copier
Sharp al 1000 shows E and 7 and hangs off
if a number and alphabeth appears alternately The copier will not function. Turn the power
switch off, remove the power cord from the
outlet, contact any authorized service
representative for overall service maintainance
May 18, 2008 | Sharp AL-1000 Laser Printer
Sharp AL-1000 Copier Logo
165 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
