USB not recognised
Never had a problem until now. great digital recorder. Inserted into USB and my laptop and office said that it did not recognise the USB drive. So reloaded the JNC Win98SE Driver and both laptop and desktop computers say it has a Trojan and Virus and McAfee quarantined it.
Where do I get my hands on another cd to reload the driver?
  • 2 more comments
  • 1Champion May 19, 2008
    What is a hard reset?
    Make and model is as follows:
    JNC Digital Voice Recorder
    Model No: SSF-1100
    FCCID: P7KDDR5000
    more detailed info
    Put in recorder with the USB connection and up popped USB driver not recognised.
    Did this on 2 computers.
    Restarted both computers.
    Then loaded CD for Win98SE Driver Version 1.00 for Windoes 98SE/2000/ME/XP
    I have windows XP version on both computers.
    When I loaded the CD it came up with error from McAfee that the CD file had a trojan and McAfee quarantined it.
    Trust this is more clear for you.
    Not sure what you mean by scan your mp3 digital memory card as there is no card in the JVC digitial recorder.
    Will download the avg antivirus 8 version and see if this sorts it out
    I went to download AVG and it is not free.
  • 1,257 Answers
First of all you should update your antivirus, than scan your mp3 digital memory card ,if it clears the trojan and virus ,its ok.otherwise take backup of your memory card and try to format it..this willl remove trojan and virus
if McAfee is unable to do that,download Avg antivirus 8 version which is free and can be downloaded from internet ,its good and will resolve the issue and you will be able to workk with your digital recorder.........
Now if your are getting the error message usb drive not recognized
Things to try :
loadTOCNode(1, 'whattotry'); If you have a problem with a USB device, try these methods first: 1. Unplug and then plug in the device. 2. If the computer prompts you for a device driver, read the information that was included with the device, or visit the manufacturer's Web site to see whether a driver is available. 3. Run Windows Update to obtain the latest fixes for Windows XP. When this is complete, plug in the device to see whether it is installed correctly.
Posted on May 19, 2008
  • Deeps . May 19, 2008
    I found the following solution workable for my case:
    Remove Hidden Devices 1. Click Start. Click Run. Type cmd and press OK.
    2. Type “set DEVMGR_SHOW_DETAILS=1′ (without quotation marks) and press Enter.
    3. Type “set DEVMGR_SHOW_NONPRESENT_DEVICES=1′ (without quotation marks) and Press Enter.
    4. Type “start devmgmt.msc” (without quotation marks) and click press Enter.
    5. Click View. Click Show hidden devices.
    6. Click “+” to expand Imaging devices, Unknown devices and USB devices.
    7. Are there any USB devices and unknown devices (including grayed out devices)? If so, please right click it and click Uninstall.
    (It's found on the hersam web site)
    After doing this, my device works again with no problem.
    Your Problem:
    If you get "Usb device not recognized" in Windows and the above solution doesn't work for you, there might be other causes:
    A) USB device worked before but suddenly stopped working:
    The following solution might be applicable:
    1) Remove all oem*.inf files
    1. Click start and click run then under the run line type in the command “cmd” (without the quotation marks)
    2. In the command line, type in the following (without the quotes) and press enter after each command:
    “cd \windows\inf”
    “ren infcache.1 *.old”
    “ren oem*.inf *.old”
    “del C:\windows\setupapi.log”
    2) Removing all entries under HKEY_LOCAL_MACHINE/Enum/USB that start with VID ==
    Removing the VID entries from the registry will cause them to be redetected at restart.
    CAUTION: If you have a USB keyboard or mouse, do not remove the VID entry for these devices, otherwise, Windows may not restart correctly.
    1. Click Start and click Run. Type regedit and click OK. The Registry Editor window will open.
    2. Go to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\USB.
    3. Highlight and delete all the VID_…. entries.
    Permissions may be set allowing the deletion of the VID_ entries by following the steps below:
    a)Right-click the key to be deleted, and then click Permissions. The VID_… Permissions window will open.
    b)With Everyone highlighted in the Group or User name section, select Full Control in the Permissions section.
    c)Click Apply, and then click OK.
    4. Turn off the computer.
    Reconnect the USB device to the computer system: ==
    1. With the computer system turned off, reconnect the USB hub to the the USB port.
    2.Restart the computer.
    3.A New Hardware Detected window should open and reload the drivers.
    B) USB device never worked before / it works but die in midway when doing something or you may get "usb device has malfunctioned":
    1) Try using a shorter USB cable.
    2) Try plug in the device to the back of your computer instead of the front USB port (this is because some computers don't have enough power in the front USB ports)
    3) Some USB 2.0 device are not backward compatible with USB 1.1 ports. Try plugging in with USB 1.1 and 2.0 port to see that's the cause of the problem.
    4) Try downgrade all your USB port from 2.0 down to 1.1, you can do that in your BIOS.
    5) if all failed, try the USB device on a different computer. Then you can determine if the USB device or the USB port is the culprit of the problem
    also, if you can't find your solution here, you might be able to find it on the link below...
    let me know if it works ,if not i will try my level best to resolve the issue .
    Technical Associate
    here is the download link for avg 8 free version
    just click on the link and download will start........if you are still unable to download ,let me know your email address n i will send you ..............thanks
  • 1,142 Answers
Try to do a hard reset, and unplug the device from the usb and do the reset first and let me know.
  • 4 more comments
  • Maanita Chadha
    Maanita Chadha May 19, 2008
    Provide the make and the model for the digital recorder i will provide you the download link for the win98se driver
  • Maanita Chadha
    you have to give me the information in more details so that i have a clear picture about the situation
  • Maanita Chadha
    Download the trojan remover from this link
    Trojan remover download
    Scan your system and the device should run fine
  • Maanita Chadha
    Download antivir (antivirus) this is absolutely free and its very good too
  • Maanita Chadha
    Try another USB device to connect to the computer and if that too doesnt work than has to be the USB emulation in the BIOS which is not turned on you have to make sure you get into the bios of you system and turn the Emulation on.
  • Maanita Chadha
    After scanning your system download the firmware for ssf-1100
    firmware for SSF-1100
    Device will start recognizing the drive
    Please dont forget to rate FIXYA
My canon 450D does not recognise my memory card
Your laptop uses a different FAT than your camera. Once you formatted it on your laptop it will never work in you camera - unless you have one of the expensive image recovery programs that allow you to reformat it for the camera.
Sep 30, 2012 | Canon EOS 450D Digital Camera
Ita not being recognise by my toshiba laptop whenever i connect the usb cord.
This is bcos the driver is absent or is not properly inserted.
Please check the install disc that came with the camera for the driver.
Jan 06, 2010 | Casio Exilim EX-Z50 RED STAR Digital...
I have a sony digitalhandycam(digital 8)and cant seem to transfer to my laptop
I have a digi8 DCR TRV140E - The USB does not recognise, windows does not recognise it and the only method that works to edit from the tapes recorded to pc is fire cable - try that folks at least it will hold you back from smashing the camera!!
Oct 18, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
My laptop has stopped recognising CDs
Sounds like a fried motherboard.
Jun 07, 2009 | Computers & Internet
Playing recorded DVDs on PC or other DVD player
This is problem exactly with finalizing for finalizing after disk burning You need to press stop button and finalising menu will appear in your display at that time you need to press Record button top finalize it will take a little time for finalizing then your DVD will play fine in all DVD players
Aug 23, 2008 | Philips DVDR3455H/37B
Phillips mp3 player
Connect the player to the power adaptor and connect to the PC.
On the player press and hold "Power" & "Vol +", this should reset the player.
Wait for PC to recognise player.
If this doesn't work try the following:
Connect the HDD6330 to the mains adaptor and the PC.
Before the computer has a chance to recognise the player, press "Power" and "Vol +" to reset the player.
As soon as the player resets (screen goes blank) press and hold "Vol -" until the PC recognises the player as a removable drive.
Try to access the player through "My Computer" as you would the main hard disk.
If the computer recognises the player, then it can be restored by copying the system files directly on to the player.
Feb 14, 2008 | Philips GoGear HDD6330 MP3 Player
PC no longer recognises the device
please restart your pc and your Digital voice recorder and reboot it your problem will be solved. If the problem continue then install the USB driver to your pc. It will  work.
Dec 05, 2007 | Philips LFH-7680 Handheld Digital Voice...
ICR-B130 Handheld Digital Recorder
Ha this is a greatly contested two posiblities.
1/ Are you on a business network? The most common reason for this error is because the user has mapped network drives on low drive letters e.g. mapped drives on E F G H I etc. When you connect recorder windows trys to assign the physically available drive letter. However that drive is being used by a mapped network drive so windows simply doesnt recognise the newly attched device hence the sanyo software not recognising the device.
2/ Some Dell PC's struggle to supply enough power to all USB ports so try connecting to the back of the PC or removing some USB devices and reconnect the B130.
This error cannot be produced without a recorder being connect so it recognised to a point just. Just not correctly.
Sep 18, 2007 | Sanyo ICR-B130 Handheld Digital...
257 people viewed this question
