Question about Mitsubishi WS-55805 55" Rear Projection Television
Turns off I have a MITSUBISHI HD1080 MODEL # VS-A50 . The issue is tv powers off sometimes it will stay on 1 hour sometimes 1 minute sometimes not at all. This happenes if you use the remote or the on/off switch. tried unplugging to no avail
  • Anonymous Jun 14, 2008
    When I turn on the tv it stays on for an hour or sometimes for 5 minutes. What's the problem?
  • jopa01 Sep 22, 2008
    How is this done? How are the front buttons disabled from the menu if TV will not power on?
I had the same problem with mine and fixed it by disabling the front buttons from the menu.
Posted on Sep 14, 2008
    Problem Solver:
  • 10 Answers
I fixed two WS-????? mitsubishi 73" TV's with a similar problem (got them for free for that reason). If the power LED keeps blinking after it shuts off, it is very likely this problem. It took me 1 hour and $5 in parts to fix it. Just search for 'mitsubishi blinking green' and you will see the solution.
Posted on Aug 14, 2008
No I do not have an answer yet
Posted on May 19, 2008
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
It stays on for a different length of time each time it's turned on. Sometimes will work for many hours per night and 4 or 5 nights, sometimes will stay on for only a few minutes. When it shuts down, you...
This tv is aging and you many bad grounds on the deflection board [it has the flyback transformer] And many bad grounds on the signal module [has convergence ICs]. And many many bad capacitors..I know as I repaired a few of these.
Nov 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Will not turn on.
if your using a surge protector or power strip, just connect your TV
straight to the wall, sometimes thats it but if still the same,
you need to call a servicer because theres a power problems on the supply
Sep 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv will not stay on
Another great mitsubishi tv introduced in 2002 chassis # v20b,Most problems with this fine tv have been no problems..... but power supply capacitors and convergence ic's. This tv is equiped with the diagnostic led codes for your tech. but i'm sure he will skip that step and head right for the fuses that open when the convergence ic's go bad. Get it fixed !! it'll last another 6 or 7 years.
Jun 11, 2009 | Televison & Video
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Turning on TV
check if there is any loss connection in the power supply circuit...
May 09, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi HD1080 Medallion TV
Do the self test and return with model number and I can help.
Dec 18, 2007 | Televison & Video
Mitsubishi WS-55805 55" Rear Projection Television Logo
157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
