Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Unltimate Care II
Washer will drain fine, but does not spin. Makes a loud noise when trying to spin. New clutch put on machine. What else could it be?
  • 7 more comments
  • ronnie2042 May 19, 2008
    Sounds like a belt slipping, but there is no belt (direct-drive).
    Motor coupling appears to be good. Is there anyway to tell if it is bad without replacing?
  • itstaken May 19, 2008
    My Ultimate Care drains fine, but will not spin or aggitate, it also makes a loud noise when it should be spining or agitating. The coupling is working, I've watched it during the noise, it spins, but at very slow RPM, maybe 2 per second. The machine is only 3-4 years old, and everyone wants $50 to look at it, even if I bring it to them and plug it in! I would like to fix it myself, but most of all I would like to know if it's worth the trouble. Thanks in advance, any help would be greatly appreciated.
    Thank-you, Tim
  • BooshieDaddy May 20, 2008
    I have the same problem and will be watching for some advice as I would like to fix this myself.
  • ronnie2042 May 25, 2008
    Replaced motor coupling. Still not spinning. Any more suggestions. Has new clutch and new motor coupling now.
  • itstaken May 26, 2008
    Ronnie24.. I'm pretty sure I have the same problem as you. From what I've read and seen it's either the transmission binding and causing the motor to turn to slow, or there is a motor control gizmo of some kind on the blink. All I have is the wiring diagram that came with it, it shows a centrifugal switch upstream of the motor, any ideas on what that does?
    Thanks, Tim
  • Anonymous Jul 04, 2008
    Making a strnge sound, like a bad bearing.
  • itstaken May 11, 2010
    Loud noise may not be the right word, more like a buzing....
  • robert samples May 11, 2010
    what kind of loud noise
BooshieDaddy & ronnie2042 I would like to pass this along. I found a web sight for the testing and repair of the Drive motor switch (my centrifugal switch), it also has prices, parts diagrams, and prices for my LSQ8512KQ0, which is the Ultimate Care ll, same guts as yours, I believe. Since the coupling is alright, that probably means the gearbox didn't bind. The prices are ridiculous, I added up just the one page for the motor and gear box and it came to like $500.! You wouldn't want to build one at home! The switch is $55., the gear case $143. and the drive motor is $111.83. On some of the models you can't buy the switch separately, you have to get it with the motor. They have a place where you can enter your P/N and find out though. The other neat feature is you get step by step instructions for everything, removing case, water pump, ect...It's www.repairave.com/washerrepair_wpl_motorswitch.asp, hope this helps....
Tim
Posted on May 28, 2008
    President:
  • 1,314 Answers
First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain, and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps. Then facing the washer locates the two screws. They will either be in the front or rear of the control panel or back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when you’re done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. Take them and clamp the hose coming from the tub but it’s not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on May 19, 2008
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at  http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Jul 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer problem
run the waher in a high spin and lift the lid repeat this three or four times and your brakes will free up and begin working again
Feb 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate Care II will not spin and makes a loud noise, I did get it to drain the water.
The usual culprit is the motor-transmission coupler. This is located between the motor and the transmission. You need to remove the pump and then the motor to access it.
Oct 17, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud Noise at the End of the Spin Cycle
some item has fallen down between the outer and inner wash tubs? remove it
May 20, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
317 people viewed this question
Dan Webster
Dan Webster
Sal De
