Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
The pull cord on my Ryobi 30cc trimmer broke. Is this true, that there is no way to access case to replace the pull cord? This has been my difficulty! There seems to be no way to reach clutch springs, etc.
  • 2 more comments
  • spudhead8 May 20, 2008
    Need the procedure to remove the clutch in order to get to the string assembly
  • Anonymous Jul 31, 2008
    clutch is off magneto is difficult to remove is there a trick
  • cominco Sep 01, 2008
    Cthe rewind does not pull at all. It worked fine a eweek ago this morning it acts as though it is seized. It pulled a couple of times and was rewinding very poorly, now that it wound back it will not move at all.
    |so far I have gone online looking o downlaod a manual. Thanks greg
  • rogerjthomas Oct 05, 2008
    Cant seem to get cover off to gain access to cord
If you have the same kind of clutch as my cs30 week wacker, then there is a screw at the end of the shaft that the clutch sits on. The screw is down inside and requires a star shaped screw driver to turn. When I tried to turn it, the engine kept turning. I had to open the back part of the engine in order to put a screw driver in it to stop it from turning.
Posted on Jun 01, 2008
On mine, the screw was bigger than the hole at the end, so there was no way to get it out. I used a hacksaw and sawed lenthwise down the shaft (the clutch housing) on the edge so I could see where the drive shaft was (you don't want to cut this). Then I cut accross the shaft (clutch housing) to expose the inside. Now I use a common screw driver and take the screw out. It also take a tourqe (star) wrench like the other screws. I guess if I don't replace the clutch I'll use it for a RC boat or something...
Posted on Jul 20, 2008
I have a Ryobi RPT3000 trimmer. Firstly how do I top up engine oil? And then how do I restring it?
The engine on that trimmer will be a 2 stroke 30cc engine not a 4 stroke.
"Two Stroke Oil" is added to the fuel for a 2 stroke fuel mix in accordance with the proportions specified by Ryobi for that engine. The required petrol/oil mix may be printed on the top of the fuel cap. No other oil is used in a 2 stroke engine.
There are a number of videos on Youtube people have uploaded which will show you how to replace the pull cord on a trimmer.
Dec 28, 2015 | Ryobi Garden
Repair video on removing cylinder from a ryobi power head.
Ryobi Technical Support Questions - HelpOwl.com
https://www.helpowl.com/Ryobi/Technical-Support
Ryobi - How Do I Replace A Piston On My Ryobi Edger. Ry 34006? ... Ryobi - Just Bought The Ryobi 30cc 4-cycle Power Head
Apr 26, 2015 | Ryobi Garden
Hi i wonder if you can help my Ryobi hedge trimmer has a problem with the pull cord it works goes in and out but it does not turn the engine over is there maybe a key way or something that maybe broken...
Hello Nick,
Inside the cord attaches to a plastic wheel which cranks the engine. This cord can become loose or can break after some use. Try opening the plastic casing where the cord is to see if this is the problem.
Thanks
Jul 25, 2011 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
Ryobi 30cc trimmer won't run. Difficult to start, hard to keep ru
chnge the plug for the best you can get then depending on the mix petrol oil mix u could cahnge that ie if its 50:1 go down to 40:1 or visa versa if that doesnt work bin it and get a sthil or an ehco
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Ryobi 30cc string trimmer 2230 4y30040b shaft overheating
mike try pulling off the motor and pour oil down the shaft.let me know how it goes
Mar 22, 2009 | Ryobi Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
313 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
