Question about Sharp AR-M205 Copier
Problem in Copying and Printing
I am facing copying and printing problem with my copier, the display only shows `E' and `I' blinking and the machine does not start. I have followed the instructions given in page No. 62 of the instruction manual of the copier. Please help at the earliest.
With regards,
Rajesh
  • 146 Answers
Looks like it may be a memory communication error. See the clip from the service manual below. May require technician to diagnose.
Posted on Jun 06, 2008
Xerox workcentre 6505 My printer dosn't print it shows ' load manual feed slot' How do you fix this problem When copying it works perfectly
change paper source. Probably on computer in printing preferences
If it works copying then it most likely is a setting in the computer . Click on print and there should be a printing preferences option comes up before you commit to sending the print to printer.
Dec 06, 2016 | Xerox Office Equipment & Supplies
How to solve canon ir2870 copying problem ?
Welcome.
If you copying on top glass plz use offset function and then do job done with multi job.
Jul 21, 2014 | Canon Office Equipment & Supplies
My ricoh MP 2000 is printing blank documents when a print job is sent
is the copying ok? if yes then reload the print driver .it is causing the problem.if copying is also blankthen check the processing unit. the charge roller might be facing some problem or the developer gears might be worn out .
Sep 28, 2011 | Ricoh Aficio MP 2000 Black and White...
Printer does not print when I send from my computer, but does print when I place copy under screen for copying.
Copying and printing are two different functions. Your machine will process copies because the work is all done AT the copier. In order to print the PC and the copier need to be able to communicate properly.
Make sure that the printer drivers for your machine are set up properly on your PC and the two systems are communicating correctly.
Aug 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Brother MFC7820N
I assumed you are using a digital copier/printer, in digital machine there were 2 kinds of diagnosing a problem, and you are right with your observation Copying and Printing, and each have two separate troubleshooting.
If you say that in printing is fine, then the problem is with the scanning part which is in your Optical Unit, here's some pointers
1- Open the optical glass on the top, with screws
2- Observed the optical unit with 3 reflective glass, it could be dirty
3- the middle of the optical system is called the CCD which converts the image from the reflective mirrors, see if you can find dust and dirt.
4- Check the lamp for any sign of dirt this could cause also some problems.
these are the only areas you need to check, nothing else, and this would surely solve this problem
Jul 15, 2008 | Office Equipment & Supplies
Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Feb 19, 2008 | Toshiba 2860 Copier
Problem while copying
mark on scan glass, clean glass slit in where original is fed for copying
Nov 07, 2007 | HP LaserJet 3050 All-In-One Printer
Sharp AR-M205 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
