Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Bissell ProHeat belt won't turn, and belt snapped
Hello. Our ProHeat's belt won't budge, it wouldn't move and the metal piece that is at the top of the belt is reallly hot. The belt sort of disinegrated. Any ideas?
  • trooworld Jun 12, 2008
    Thanks, I'll try that. Would I get that new roll at the Bissell website?
  • 77 Answers
The brush roll is probably melted to the ends. there is a new brush roll ***'y with new ends. more reliable than old design. usually happens because floor is not vacuumed well enough and too much hair is left on carpet which winds around the roller and melts the end.
J
Posted on Jun 12, 2008
  • Jim Gillon Jun 13, 2008
    If you have a local bissell repair shop they should have that part. you can find them at bissell.com
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
The unit does not put any watter on the carpet and when I push the triger the red spinner does not move. The tank is full of hot watter
This sounds like your pump brush belt is broken in your Bissell. The belt controls the pump in the machine, as well as the brushes. This would be explain why the solution is not spraying, as well as why the red spinner on the top of the machine is also not spinning.
Here's an extremely helpful video that you can watch on how to replace the belt on your Bissell ProHeat Carpet Cleaner.
If you open up the door and find that your belt is not broken, please just reply using the Clarification Request form here on the Fixya website, and I'll be more then happy to do some advanced diagnosing with you to figure out what the problem is.
How To Replace the Bissell ProHeat 2X Carpet Cleaner Belt:
http://www.bissell.com/VideoRating.aspx?id=1555
If this information was helpful to you, help other Fixya users with the same problem find this video by clicking the very helpful four thumbs up icons in the top right hand corner of the repair.
Thank you very much,
Chris J.
GoVacuum.com
Apr 12, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
My Bissell Proheat 12 amps' brush keeps dragging on the carpet when I go to push it forwards. And it releases alot of water.
Mine is doing the exact same thing..Push it forward and it makes a awful noise. The Brush on the bottem is loose and it isnt spinning. SO i took and turned it over and there is a metal gear like part that runs the belt on the brush. I took it out and cleaned it...basically because it was just hanging in there..not Turning the belt..AND NOW I cant get it back in..I am totally disgusted as it hasnt been used very much at all. I cant get the gear metal piece back in to see if it works.IT Just falls out. and its a bear to get it in there..
Feb 07, 2010 | Bissell 8910 ProHeat Clear View Upright...
Can't reassemble top of carpet cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fggh
Jul 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell ProHeat, Brush won't turn, belt fine.
heatman101
dh
Jul 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Mysterious metal piece under vacuum motor?
heatman101
fdgf
May 07, 2009 | Bissell 8910 ProHeat Clear View Upright...
Pump Assembly Drive mechanism seperarted into two pieces
I believe the pump assembly can be replaced it is a15 dollar part.that is what works the brushes. Ijust took mine apart and looked at it the end snapped off.
Dec 10, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Replacig pump belt on deep cleaner
heatman101
vbcmbn
Nov 13, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
101 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
