Question about Nikon Coolpix 7900 Digital Camera
Formatting a sandisk 4g to work with coolpix 7900 camera
When in insert the new sandisk 4g sdhc card to coolpix 7900 it says the card can not be used. I have never used larger than 1g in camera. went to nikon site, looked up 7900 - it does list sandisk 4g as an usuable card. when i go to menu/set up on camera, it literally "skips" the formatting option. any suggestions?
Sd hc cards are not supported by 7900, you will never can use such a 4gb card with this camera
Posted on Nov 01, 2008
I got a 4G SD and installed the card and the camera says that this card cannot be used Solve it
The 4600 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Jul 09, 2012 | Nikon Coolpix 4600 Digital Camera
I have a sandisk sdhc class4 4GB card and my camera ( nikon coolpix L4 ) is telling me card cant be used?
I would try to insert it in your PC and then format the card. Then reinsert in your camera and
see if that helps.
Jan 23, 2011 | Cameras
New sandisk 8 gb sd card reports memory error when inserted in camera. other cards work in camera. card is recognized by laptop. tried reformatting by Vista
There are no 8GB SD cards. Cards this size are SDHC (High Capacity). SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC cards. SDHC is not backwards compatible.
Dec 01, 2010 | SanDisk Cameras
Why won't my Nikon coolpix L1 camera work with my sandisk SDHC card?
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Another possibility- SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Finally, it may be that the card is not formatted. Most come pre-formatted, but there is a format function in the camera that you can try. Formatting deletes anything already on the card.
Dec 01, 2010 | Nikon Coolpix L1 Digital Camera
Can I use 4 Gb SDHC card in my coolpix 7900?
No. The 7900 uses only SD cards, not SDHC cards.
Nov 27, 2010 | Nikon Coolpix 7900 Digital Camera
My coolpix 3200 will not accept a SD card. it rejected the 128 mb card and I replaced it with a 4g card that it doesn't like either. It also will not allow me to format any SD cards
The 3200 works with SD cards. Your 4GB cards is actually an SDHC card, which is electronically incompatible. You need to use SD cards, 2GB and smaller.
Oct 21, 2010 | Nikon Coolpix 3200 Digital Camera
I purchased a new memory card (sandisk sdhc ) it will not format?
Get a new camera :-)
Seriously, the Z740 is designed to work with SD cards, not SDHC cards. While SDHC cards will fit into the camera, they will not work. You need to buy SD cards 2GB and smaller.
Jul 26, 2010 | Kodak EasyShare Z740 Digital Camera
Memory card wont format. I bought a new 4G sandisk memory card but all it says after formatting is the card is full.
The S200 uses SD cards. Your new 4GB card is actually an SDHC card and will not work in the S200. You need to use SD cards, 2GB and smaller.
Jun 02, 2010 | Nikon COOLPIX S200 Digital Camera
CoolPix 5000 "OUT OF MEMORY" message that we can't figure out
At 4GB size, your memory card is likely a SDHC card, and not a standard SD card. Although they look the same, there is a difference in formatting. Unfortunately your model camera was designed before the SDHC format came out, and it will not work with your camera. But fortunately standard SD cards are very inexpensive these days, and you should be able to purchase a good 2GB standard card for around $6 with shipping:
http://www.amazon.com/s/ref=nb_ss_e?url=search-alias%3Delectronics&field-keywords=sd+card+2gb&x=23&y=20
Jul 03, 2009 | Nikon Coolpix 5600 Digital Camera
Nikon Coolpix 7900 Digital Camera Logo
464 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
