I'm not sure if my heating element is bad or one of the fuses is bad. Can I tell if the heating element is bad without buying anything or having a service guy come out?
The part number is 53-1641. It comes with a high limit and is around $50. You must pop the top on this unit and you will finnd the element in the rear of the dryer. A simple and easy fix.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
How much is a heating element for the crosley dryer cde6500w series?
It appears you have a Electric dryer (220V)So, if you feel any heat at all after its been on for say 2 minutes than your element is fine.Your problem is most likely the air thats leaving the dryer is being blocked.If you want to be 100% sure its not a vent problem than do this..run the dryer for ONE load on timed dry cycle (60 minutes)without the vent hose attached and you'll know in 60 minutes if its ok.This is the easiest way to help you.If you can ,place a nylon sticking around the vent hose for this one time so it doesnt blow dust around.I'll be happy to guide you through this.
SOURCE: CDE6500W Not Heating
most common cause is burn out of the thermal cut-out. These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
Clean the exhaust ducts all the way to the outside wall, lots of vent hoods block over time. then examin the exhaust duct for devices that look like this or like this with wires connected to the terminals. there may be 2(hi lo), test with a flashlilight bulb or ohmmeter conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
I
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
dishwashers...
Element not Working
Dishwasher
Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
I
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
dishwashers...
Element not Working
Dishwasher
Maintenance
heatman101
heatman101
Asker
heatman101
dffg12
I need to know how to get the heating element out
