SOURCE: 1080i
grab your TV remote and go to setup. check your input settigs and change them from RBG.
SOURCE: Xbox 360 or Dish ViP 622
when i hook either my dish hd receiver up to the 1080i component video inputs, everything works fine if i set either device to 480p, but i get nothing i set them to 1080i.
SOURCE: Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
SOURCE: my ws-65611 always stay in 480i even with HD signal.
If you are using the component connection, make sure you are connected to the one that will support 1080i. If that is not the problem, make sure that the HD receiver is outputting 1080i and not 720p. No RPCRT will support 720p and the video may be down-rezed to 480 since this is the case.
Looks like you are going to be working with the following:
1080i (HDTV) • 480p (EDTV) • 480i (SDTV)
Hook up depends on what else you have connected to the TV. If you have nothing connected to the DTV component inputs, I suggest using those, as it will allow up to 1080i. Otherwise, use the 2 other component connections directly to the left of the DTV connections.
