Question about Nikon D50 Digital Camera with 18-55mm Lens
Flash not working
My flash is not working. how do i fix the prob? how do i do a full reset?
Look at the screen on the top of the camera to see if the flash is turned on. There is a little button like a electricty bolt hold it down and rotate the little wheel on the top right on the backside of the camera.
Posted on Jun 05, 2008
I RECENTLY TRIED TO RESET MY LG KP500 PHONE BACK TO FACTORY SETTINGS AND AFTER I DID, IT WON'T TURN BACK ON. THE ONLY THING IT DOES IS FLASH THE LG SCREENSAVER ON AND OFF SO I CAN'T EVEN GET THE COMPUTER...
hi,
Ah, sounds like a nasty prob, I recently restored the factory settings as well but its ok so far.
Try taking the SIM n battery out and putting it bk in, dont turn the phone on, leave it on charge, then when the batterys full try turning it on,
let me know if it works, email is ssandh10@caledonian.ac.uk
Apr 05, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
My right turning signal sometimes doesnt work. The light in the dash stays on, but doesnt flash. When this happens the front light stays on when the signal is applied, but the back one doent work. Ive...
  1. Turn 4 way (hazard) lights on check to see that all lights are flashing if rear is not flashing suspect bad ground since 4way usually goes through brake light.
  2. If everything flashes you may have a bad flasher relay find it replace it.
  3. If light still will not flash check light socket by removing bulb & looking for burnt melted contacts or plastic. You find any of these problems consider replacing socket.
  4. If you do not find any problems with socket use a cheap test prob connect alligator clip to metal ground near socket with bulb out turn on blinker carefully touch each contact inside socket when you find the right contact prob should light up & blink.
  5. If you cannot get prob to blink move prob ground to new location do step 4 again.
  6. If you still get no blink start probing wires coming into socket until prob lights working away from socket.
  7. Ground is on the side of the socket when you look in it.
Mar 08, 2009 | 1993 Dodge Shadow
Resetting phones and restoring to full factory default.
okay i will fix the prob but i need model name
and fix ya rate after giving the solution okay??
Aug 18, 2008 | Uniden 5.8GHz Dual Cordless Phone
EOC-3220+ flash reset probs
Hi..
I had that problem too.. I scan the radio IP with Dude, software that come free for mikrotik.. and I got 192.168.1.245 for my radio. since that day I know that 3220 will go to that IP after flash reset. the mode will be Ap only, if you change to AP on operational mode than it will go to the standart Ip either 192.168.1.1 or 192.168.1.2
Hope this will help
Apr 02, 2008 | EnGenius EOC-3220 (EOC3220)
D600 probs
sounds like ye old keyboard was compromised by some foreign matter. You'll need to remove it, blow it out with some compressed, air, let it dry, and then, when the moon's full, re install it(just kidding about the full moon, you can do it while it's still waxing, too. Got backup?
Feb 10, 2008 | Dell Latitude D600 Notebook
Help Motorola RAZR V3 Cellular.flash and bootloader problems
try reflashing your phone with a different firmware/monsterpack, also try using p2k tools instead of rsdlite
Feb 10, 2008 | Motorola Mobility RAZR V3
The flash wont turn on! what to do?
Hey, had the same prob, go into settings and go to master reset under general, and restore settings - flash works again
Dec 12, 2007 | Sony Ericsson K800i Cellular Phone
Envelope sign stuck
dear brother the solution for ur prob is
actually your sim card memory is full, that's why the sign of msg memory full flashing on your cell screen.
delete 1 or more than one msg from ur sim card memory.
best regards
good day,
Anwaar
Jun 19, 2007 | Samsung SGH-E900 Cellular Phone
TELIVISION
unplug for 3hours this is a hard reset, if the prob is still there after pluging back in , listen real close two back of set, is there a squeeling noise, if so prob. a bad power board. about 300$ two fix SORRY
Dec 28, 2006 | RCA HD52W56 52" Rear Projection HDTV
Restart.
i want master resat code
Jun 24, 2006 | Nokia 6610
Nikon D50 Digital Camera with 18-55mm Lens Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
