Question about Cell Phones
I need a replacement for the camera lens for an iPhone. This is NOT the camera. It's the plastic lens which is taped to the inside of the back cover of the iPhone. Do you sell this small part?
  • raj5 May 21, 2008
    If I'm understanding the only comment I received correctly, it sounds to me as though I'm being told that one can not purchase just the camera lens (sometimes called the "camera lens cover") for the iPhone camera. Throught much searching, I have found this is not true. The part can be purchased from the following URL:
    <http://www.etechparts.com/ProductDetails...
    I purchased one of these and found it to be the exact replacement which I needed. It does not come with the small silver bezel around it, but that can be acquired by simply removing it from the previous lens.
    I hope this information helps others who are in need of this.
    Sergeant:
  • 282 Answers
No, here you can't get it.
Posted on May 19, 2008
It wont eject or play makes lound noise for a min
There is a broken plastic part on the cassette. Needs to be replaced.
Mostly caused by improper position of the tape and camera jam(tape jam)
needs sony camera technician who can replace the part inside the cassette.
Apr 03, 2010 | Sony Handycam DCR-TRV310 Digital Camcorder
Hi8 won't eject cassette
There is a broken plastic part inside the cassette and needs to be replaced. Mostly due to cassette tape improper position and camera jam (tape jam).
Apr 03, 2010 | Sony Hi8 CCD-TRV138 Camcorder
DVR TRV-27 is showing error C:32:11
The problem is a rubber tape tension roller. Simply eject the tape, look inside where the tape goes. You will see a black rubber cylinder that may have a white plastic tube protruding. If you have long tweezer or a hemostat remove the plastic tube which hold the rubber tensioner in place, then remove the rubber tension cylinder. Clean the shaft of the black rubber tensioner with alcohol on a q-tip. Replace rubber tension cylinder and plastic tube.
Also, the tapes can cause the problem. This process is possible by one person, but you may need another person or have three hands. The C:31:23 is tape tension error. The tape has become stuck. Simply eject the tape. Holding the tape upside down, pull back on the tape cover release slide on the left side of the tape, now take the hemostat and push the tape release tab, located opposite of the tape cover, push this tab down and back toward the back edge of the tape. Now while holding both those release levers, take a pencil and wind the tape past the bad spot or until the tape winds freely.
I did both of these and was able to use the camera again and view all my tapes!
Good luck and QUIT SPANKING YOUR CAMERAS!!!!
May 01, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Lens stuck/lens error
Hello
there are tiny plastic gears inside and may have chipped or a small piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Aug 19, 2008 | Nikon COOLPIX L10 Digital Camera
Used FE-170 hardly powering on.
The lens need to be replaced or repaired. It is not fully extending. It may be that one or more of the plastic gears or plastic rods that hold the gears in place, are broken. I repaired two plastic rods in my lens, by drilling holes for new plastic rods,(I cut plastic rods from a plastic toilet bowl chain!!! It fit inside the gears perfectly), and super glue the rods in place. Replaced gears, put camera back together and BAM in worked! Nothing like a perfectly working refurbished rig job. Camera takes great pictures to this day.
May 10, 2008 | Olympus FE-170 Digital Camera
FE 170 OLYMPUS digital camera
Nov 27, 2007 | Olympus FE-170 Digital Camera
K100D Problem
Remove lens, locate silver vertical pin inside of mounting ring on left side as you are looking at camera. Lightly slide black plastic piece which is on the vertical pin downward; if it will go downward remount lens and try camera. If plastic piece will not go down, lightly slide it up and then down and now remount lens and try camera. My guess is that either that component is sometimes stuck or that it may have become mispositioned while removing and replacing a lens.
Nov 11, 2007 | Pentax K100D Digital Camera
Lens cover cap broken
There are no Spares for these I feel Canon Technical Support may have a solution or a little bit of imagination and a suitable bottle/jar top may serve- with a little piece of fine cord to loop around the camera body
Jun 26, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens cover closed
I'm just shooting in the dark, but have you tried taking the batteries out then putting them back in again. Also, you might want to look through the Sony website for an e-mail address that you could wite a question and/or ask for help/advice.
Jun 18, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Not turning on
Hello Ariel, You need a new battery lid. The problem is the lid has a pin that when closed properly, allows the battery to power up the camera. You can get one for $30.00 on Ebay item number 7623965577 if you act fast. This is a good camera and would be worth $30.00 (plus 5.50 shipping) to fix it. Please let me know how it works. Best regards, nightdiver
May 31, 2006 | Kodak EasyShare C340 Digital Camera
Cell Phones Logo
95 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
