Adjusting brightness for my gateway 3520 laptop
I have this laptop and the screen seems really dim but yet wen i put the charger in it gets bright, How do i make it so its bright all the time.
    Problem Solver:
  • 17 Answers
Most likey the dim screen while running on batteries is the power saving feature. This can be changed in the operating system configuration. Assuming you have Windows, you should be able to right click on the desktop, click Properties then the Screen Saver tab. I have a desktop so I won't see the same details as a laptop. Just go to the appropriate settings & change them to give you higher performance for use with the battery. You may also be able to adjust the brightness with the Function key & another key combination. Look at the blue or green colored silkscreening on some of the keys on your keyboard & maximize the brightness while running on batteries only. Next time you reboot, it should remember your previous settings. Hope this works for you.
Posted on Feb 13, 2010
  • zbuilder801 Feb 13, 2010
    Actually, I just found a setting in the BIOS system setting for the brightness with & without tusing the A/C adapter. I think this is where you need to change it. Change the setting from AUTO to MAX to keep the screen bright. Thsi of course will drain your battery much quicker though.
  • 57 Answers
Your laptop needs hardware diagnosis.maybe it is grounded already.
Posted on May 19, 2008
My lenovo ideapad is showing that the brightness is all the way up, but it is really dim
If it is new, I would get it replaced as it sounds like the back light is failing.
Feb 15, 2014 | Lenovo IdeaPad Computers & Internet
My laptop display very dim
If your HP laptop has a dull screen, or if the screen is too bright to make out anything that's displayed, you may need to adjust the brightness to get your screen back the way you like it. You don't want to strain your eyes to see your screen, and the fix is really simple. It's about as easy as adjusting the brightness on a TV. You'll have your brightness set the way you want it in a few seconds.
1. Right-click on an empty space on the desktop and a drop-down menu will appear.
2. Click on "Properties." If the HP laptop uses Windows Vista, you'll click on "Personalize."
3. On the "Personalize appearance and sounds" screen, click on "Window Color and Appearance."
4. Click on the arrow beside "Show color mixer."
5. Use your mouse pointer to move the tab on the "Brightness" scale to the left or the right to adjust the brightness and click on "OK" when you're content with the color.
I hope you find it very helpful. Thank you for using fixya.
Best regards.
Aug 15, 2011 | HP G62144DX Laptop
I can't adjusts my laptop brightness..i tried everything..display settings nothing seems to work..only when is charging seems like the brightness is better..but when i remove the charger it doesn't look...
The setting you need to change there is your power settings. The laptop dims the the display to save power when its unplugged. You will have to go into change power options from diplay settings i think.
Dec 14, 2009 | IBM ThinkPad T30 2366 Notebook
How do you make the lighting on the screen brighter without the charger in ?
The screen will automatically dim slightly when it is on battery power, this is to conserve battery power. For maximum brightness connect the power adapter into the laptop.
On the Thinkpad laptops you can adjust the brightness by pressing and holding down the blue Fn key plus the Home key to brighten or the End key to dim the screen.
Nov 26, 2009 | Lenovo ThinkPad T61 Notebook
Dim screen, bright mouse pointer
Right click the battery icon on the right bottom of the screen in the task bar. The performance profile may be set to energy saver causing monitor to dim to save energy.
Sep 09, 2009 | Gateway Computers & Internet
Laptop Screen goes dim when plugged in!!!!
Hold down the Fn key then press arrow key up or down.
Aug 10, 2009 | Gateway 450ROG Notebook
Gateway screen flashes bright and dim
Usually the connection is one wire down the middle and their is another wire wrapped around it.
You can try to do a soldering job with heat shrink material around it, but if you don't know the procedure, it can damage the laptop.
Look at the charger and the amperage it needs as well as the voltage. You can actually just buy a new one as little as 80 dollars.
Aug 09, 2009 | Acer Aspire 5500 5570-2609 Laptop
Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Dec 06, 2008 | HP Compaq Presario R4000 Notebook
My screen has dimmed but the cursor remains normal
I think its just like driver problem or you adjust the color in under advance button in the screen and resolution setting
takecare
Apr 28, 2008 | Computers & Internet
Help Please.
Is it so dim that the screen cannot be read with shining a flashlight into it? if so this is a hardware failure not a brightness setting. let me know if it is.
If it is just somewhat dim but readable, there is probably a hotkey. Gateway laptops are all different.
Google search for your particular model and specifications. you will get the gateway support page for your notebook.
for example if you have an mx6550 enter this at google.com
mx6550 specifications
Dec 17, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
410 people viewed this question
David Payne
David Payne
