Question about Hoover Washing Machines
To remove the agitator from Hoover washing machine (model 202m)
We need to remove the agitatior to check if my ring is there or not.
Following the instruction, we removed the screw at the bottom of the agitator and tried to pull the agitator up. It didn't move a bit. We applied some RB6 (lubrelicate) but still not working at all.
Any advices before calling the service and repair?
Thanks very much for your help.
SOURCE: need to remove agitator on
thank you for your prompt responce i did ring a local repair shop who was very helpfull and explained how to remove the agitator and put it back in . again thank you
Posted on Mar 12, 2008
SOURCE: Hoover 550 MA Top Loading Washing Machine
I have 550 Hoover about 6 years old,just out of warranty period,
is currently noticed the problem of stopping during prewash rinse, start again it startsup but stopped immediately.And keep repeating it. If i skip to spin manually then it almost completes the cycle. THis problem starts few months back also then vanished by itself and now it starts again.can some guru tell me if its because of belt or drive belt etc.
Posted on Apr 28, 2008
  • 6 Answers
SOURCE: How to remove agitator from Maytag A410 top loading washing machine
Remove the screw holding it down with a 1/4 inch nut driver.Look at the agitator from above and you will see a hole ,there is 1 only.Once you find tha follow from the hole up until you find the set screw and remove it
Posted on Jun 24, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Ultimate Care Washing Machine Agitator
after removing the agitator from the machine (7/16 bolt) i place the agitator on the floor, step on either side of it and pull up on the top half, ittl come loose, needs a little help! a word of advice though is after replacing the agitator dogs, turn the entire agitator upside down and insert the bolt through the entire agitator assy and keep constatn pressure on the bolt as you turn it boack over and try to realign with thte tranny shat. ( you see the parts wanna seperate as you try to reinstall them otherwise)
Posted on Oct 27, 2008
  • 59 Answers
SOURCE: I can't find the filter
The filter is in the agitator. Remove the agitator cap, and you will find it down there. The filter is pretty much useless. Even though you might get some lint in the filter, if it wasn't there the lint would go down the drain. This machine has a neutral drain feature where the lint gets pumped out with the rinse water before the bowl turns, so preventing the lint from being stirred up nd put through the clothes. Cheerts Tony.
Posted on Sep 07, 2010
Hoover 202m 5.5kg washer takes a long time to fill on cold
Check tap turned on fully, kinked fill hose, filter in fill valve where hose screws on to machine.
Sep 30, 2017 | Hoover Washing Machines
How do I remove the agitator from my Hoover 201M washing machine. It really needs to be cleaned under there with all the muck thats building up. Thanks.
if it is a top loader machine with an agitator that stands up in the center of the tub, try removing the dispenser and lint trap from the center ( normally just a pull up) and right down the bottom there is a 10 or 12 mm bolt that you undo and that allows you to pull the agitator up off the drive shaft
talk with a service agent as to how to get the agitator out or down load a workshop manual from google by typing in --workshop manual for hoover model 201m washing machine -- and if there is a pdf version then down load it
Feb 07, 2016 | Hoover Washing Machines
I can't find the filter location for Hoover 202M 5.5kg washing machine. Can you pls help.
Sep 07, 2010 | Washing Machines
I have a kenmore 70 series washer and the agitatior just spins freely when off is this normal
This assumes that you have a basic Kenmore2_bing.gif / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
I'd also check the Motor Coupler for a worn center rubber piece.
See the following.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=bcf6e5e944400b9ef62cc7cb892700af
Jan 17, 2010 | Kenmore Washing Machines
Agitator dogs stipped
the way to do this depends on if it is a dual action or triple action agitatior.
dual action
- Remove fabric softner dispenser
-pull off plastic cap with flat blade screwdriver
- bolt is under plastic cap 7/16"
triple action (bounces up and down)
remove fabric softenr and plastic cap
with a 1/2" drive socket extention, put into square hole and unscrew spring assembly. once unscrewed top portion of agitator will come off
May 27, 2009 | Washing Machines
The top part of my agitator moves slightly, and sometimes not at all. The bottom part moves but the clothes at the top don't seem to move.
The top agitator has small plastic mechanisms called "dogs" which engage the upper agitatior when needed. If the top agitator spins in both directions by hand, these gears are worn. To replace them, remove the top center cap by pulling straight up on it. This sometimes requires a good deal of pulling force. Then, if you look down in the center hole, there will be another cap recessed in there. You remove that by pulling up on it as well. Then there will be a center bolt which has to be removed. After that, the top agitator will pull off and you can look down and see the dog gears (usually 4). They are readily available and cheap. Note: I recommend replacing the cap o-ring when doing this repair.
Oct 21, 2008 | Whirlpool Washing Machines
Hoover 800 washing machine
take the cap of the top of the agitator you need a 10mm socket
on along extension bar undo the bolt in the bottom of the agitator and it will lift out replace by do-ing the reverse process
i have just done it better than paying $100.00 for a service call
for five minutes work
Aug 18, 2008 | Hoover HTC243 Top Load Washer
Need to remove agitator on my hoover 500m washing machine
Mar 12, 2008 | Hoover Washing Machines
Washing Machines Logo
312 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
