Sony Playstation 3 (PS3) Console Logo
Posted on Sep 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Since i brought my ps3 on ebay when ever i play it it freezes after 20 - 30 mins, after it freezes if i reset it it will turn on slowly and then wont show the game up and if it does show the game it will freeze when i try to play it.
Anonymous
Level 3:
  • Master 4,102 Answers
  • Posted on Sep 19, 2010
Anonymous
Master
Level 3:
Answers
4102
Questions
26
Helped
1199714
Points
14563
Hi, you may have a problem with the lead give it a good wiggle all the way from the ps to the telly if that dont work try and borrow a friends lead to rule out the lead being the problem, if it still dont work then try the following to reset the console.
This is how to fix it:
1)turn your ps3 -off- by the switch at the back
2)turn it back -on- again by the switch at the back only
(there should be a red light now)
3)now -hold- your thumb on the power button located on the front for a few seconds until the ps3 turns itsself on and off.
(during this process there will be about three beeps spaced apart,and after that the light will return to red)
4)finally hold your thumb on the front power button again and you will hear two beeps then a double beep.
-IMPORTANT-
After you hear the double beep take your thumb off the button before it shuts itself down again.
5)once you have done that you should see the picture.
if after doing the above it still dont work then this would indicate it has over heated so try the following.
1 switch the ps3 off and leave it off for at least an hour
2 remove all leads from ps3 and tv
3 make sure the ps3 is not being used on carpet or on top of dvd player or sky box as this will cause it to over heat very quick
4 make sure all the air vents are clean and have no dust vac them out if needed.
5 make sure the ps3 has got good air flow around it and not stuck inside a shelf thats blocked off at the back as this to will cause it to over heat.
6 now plug it back in and give it a try.
if it still dont work then this would indicate the gpu chip has over heated and has probably fried.
if you have any warranty left on it take it back as this fault is covered by warranty.
i fix these for about 25 pound plus parts so you need to shop around and see if you can get it repaired, their is no guarantee the repair will work as their is always the chance that it has over heated that much that it has cracked the solder joints that hold the chip onto the circuit board.
im in uk and we do offer a repair service so if your in the uk and would like it repaired you can give me a shout back or if you need further assistance just give me a shout back.
let me know how you get on ok
plz rate this solution as i have a whole page of unrated posts, thanks
500 gb playstation wont load home screen
Have you tryed unpluging device for 10 min. to reset device.
1helpful
Game system freeze after playing for 10-15 min
well i had this problem with kill zone 2
once a month or so i would freeze up and i would have to hit the power switch on the back
i got a cooler fan and this problem stop havent had this problem since... hope this helps you .
1helpful
My ps3 has just started to stop playing blu ray films after 20min
the laser is starting to go bad in the dvd drive. It takes more power for the drives laser to read and play a blu ray movie then it does to play a dvd game.
You can either replace the laser if you have the technical knowledge to take the dvd drive apart, or just replace the drive. You can usually find either one on ebay.
PS3 freezes.
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up.
2answers
Games would freez and i cant play dvds
call sony about this one 1-800-345-7669 you need a new blue ray drive
My ps3 is freezing
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up.You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
13helpful
15answers
Ps3 like freezing
If the disc/laser lens are dirty it will cause the games to freeze, or if the system doesn't have proper ventilation it will overheat.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
