Question about EliteGroup nForce3-A Motherboard
YOUR NFORCE3-A POST/BOOT BEEP
U EVER FIGURE IT OUT ? I HAVE THE SAME PROBLEM, THE ONLY THING THAT STOPED THE BEEP IS WHEN I PULLED THE PROCESSOR (AMD SEMPRON) THAT THE DOC.'S SAY IS SUPPORTED, IS IT POSSIBLE THAT THE MOUNTING HOLE'S DEPICTED IN THE MANUAL AS ALL HAVING SCREW'S IS THE PROBLEM, MAYBE A GROUND ISSUE, IMA TRY IT, IN THE MEANWHILE IF YOU GET A FIX PLEASE LEMME KNOW @ AMUCK_4_U@YAHOO.COM
I had a amd 64 3000+ processor got the beep could not figure why did nit trust the mem
changed them and new day!! now usind ddr400 2gb mem hope thes helps
dpm davep9@netzro.net
Posted on Oct 18, 2008
I need this driver for my computer please
Posted on Sep 07, 2008
Sir , i found my mother board is good . but , my processor failed to boot mine is AMD ANTHLON 64 3500+ . I dont have even a small damage to the pins in the processor , everything is good. my processor...
Processors do not fail unless they are mishandled or installed incorrectly. This system is very old and uses memory that is no longer available. Try starting your system with no memory, does it start to beep repeatedly? The memory may be at fault. No beep, could be the motherboard has failed.
You will not find replacement parts, you will need a new system.
Feb 13, 2011 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
Asus mb wl300 amd 64 4000+ won't boot to bios.
To make sure it isn't anything else, pull all cards, and drive cables from the board so the only thing left connected is the power connectors to the motherboard, the speaker, and the power button. Pull all the ram cards.
Now power up the computer. If you hear a series of beeps then the computer recognizes there is no ram on the board. At this point I would take the power supply out and have it tested. If you do not hear a series of beeps I would still have the power supply tested as it could be the 12v is fine but the 5 and 3.3 volt side is bad.
If power supply tests good then I would replace both the motherboard and processor. You take a risk of burning a new processor if it's the motherboard causing the problems.
Jan 08, 2010 | ASUS Computers & Internet
Abit kn8 ultra mb no post one beep
Trying your peripherals one at the time is the way to find your problem, Memory first - one beep is good, If your mb has onboard video use it first. if not check the settings in the BIOS may be a shared memory that is not set right. Make sure your memory is computable ck one stick at the time.
Jul 18, 2009 | Computers & Internet
Single Beep on boot... repeats after 2-3 seconds, no video
This is a tough one. On some system bioses one beep means a problem with the RAM. On most it means a succesful POST. Are you getting any video? Have you tried booting to a boot disk? Have you tried a new hard drive? Have you tried to clear the CMOS? Good Luck!
Jun 27, 2009 | Dell Dimension 4700 PC Desktop
Gigabyte k8m800-8237 won't boot with 2nd gig ram installed.
Could have been dusty. Find a copy of Memtest and run it to check things out. Errors could mean a bad stick or bad slot.
May 03, 2009 | Gigabyte GA-K8VM800M Motherboard
My dell inspiron 1521 laptop with amd athlon x2 processor does not boot...all it shows me is the dell startup screen.... what can i do?
hit Ctrl and F11 while the blue bar is loading this will start your recovery process. now if there are beep codes then it might be something diffrent your computer will beep once thats normal but if it beeps more times after that you need to post how many count them. right now it looks like your harddrive crashed.
Feb 24, 2009 | Dell Inspiron 1521 Notebook
PC doens't boot up HELP!
There are a few things you can try, the trouble shooting doesnt necessarily have to follow in this order. Best thing I can suggest is try re-seating the processor, and if that is the only stick of RAM you are using see if you can find another to test with. If it still doesnt work after either of those, you might have to try a different processor. Granted, this is if you have those parts on hand. If you still are unable to even get a POST beep, then I would also try snatching the CMOS battery, unpluging it and then hitting the powerbutton reset the CMOS to default settings. If it still doesnt work after you get back then there, then I would snatch every removable piece of hardware from the board down to just the processor/heatsink/fan, memory, and PSU. If you get a POST beep after that, then try adding one piece of hardware at a time until you find the problem piece. If it still doesnt work then there is a pretty good chance that the board is dead.
Jan 10, 2009 | Computers & Internet
NFORCE3-A CPU fan & LED come on, nothing else, no beep or video
If the RAM is incompatible with your board then yes it would not allow a boot. Make sure your front panel power wire is plugged into the proper spot on the motherboard and retry. If it's the RAM then you will still have the problem. If it was the wire loose or in wrong spot then it should work. Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | EliteGroup nForce3-A Motherboard
Powers on but no video.
Your motherboards RAM is not working properly. First you try getting it out and installing again. If that not work you can change with other one.
Feb 09, 2008 | EliteGroup nForce3-A Motherboard
NFORCE3-A Won't post with 2 sticks of 512MB DDR RAM, only if 1 stick used :-(
U cannot use 2 identical DIMMs of RAM Memory, find two same and faster, couse 233 or 300 is too slow for nForce3 motherboard.
Aug 30, 2007 | EliteGroup nForce3-A Motherboard
EliteGroup nForce3-A Motherboard Logo
88 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
