Question about Audio Pro 15PLB76 15 Inch 800 Watt Woofer Car Speaker
Car speaker installation
My 2003 silverado truck has component speakers in the front. i doubt chevy actually went to the trouble and cost to install crossovers in the stereo or the separately under the dash. The tweeter has a small cpacitor wired to it that I'm gussing theyre using as the high pass filter and just letting the impedence of the woofer itself to act as the high filter to it. will I be OK just wiring the crossover of my new pioneer component speakers only to the woofer's wires or no?
  • 112 Answers
Yes... for sure you can use the woofers wiring, BUT if you are keeping the factory radio you might have reduced volume and or quality due to the inefficency of some newer model higher power needing components... let us know if you are amping or not, and if not.. try and do so..
Posted on Jan 26, 2009
Hooking up speakers
first off stock wiring for speakers,and or amp are with minimal wiring.Rewire system for better sound quality,also use noise suppresors if needed.
Jan 18, 2014 | Toyota Cars & Trucks
I purchased a used Jensen UV10 from a friend and installed it in a 97 eclipse spyder. I recently bought a 2003 chevy silverado 1500hd LX, and took out the aftermarket JVC cd player to install my Jensen....
Depending on the model, the Silverado may have an amplifier between the OEM radio and the speakers. If that is the case, you will have to remove it and wire directly to the speakers. Check the wiring schematics for the original truck radio option (one source is Alldatadiy.com).
Jul 16, 2017 | Cars & Trucks
What is the positive and negative colors for the speaker wire on a 99 chevy silverado?
I need to know the positive and negative speaker wires for the door speakers in my 1999 ford expedition xlt. Can anyone help please?
May 06, 2012 | 1999 Chevrolet Silverado 1500
Installing aftermarket stereo in 99 silverado which wires from stock harness connest to aftermarket harness
connect the wires as indicated below
1999 Chevrolet Silverado C1500 Wiring, aftermarket stereo wire colors
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (Tape off) not used
Car Stereo Dimmer Wire: Brown (Tape off) not used
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
Oct 22, 2011 | 1999 Chevrolet Silverado 1500
My son installed my pioneer stereo inti my chevy tracker 2003, which as caused some electronic problems with my sensors. he did not have it grounded, so who knows what other mistakes there are? could you...
2003 Chevrolet Tracker Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White
Car Radio Accessory Switched 12v+ Wire: White/Black
Car Radio Illumination Wire: Red/Yellow
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): White/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Light Green/Black
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Gray/Black
pls rate
Aug 16, 2010 | Car Audio & Video
Im installing a new head unit. and i was looking for a wire diagram to help me out
2005 Chevrolet Silverado Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Class 2 Serial Data
Radio Ground Wire: Black/White
Radio Illumination Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: Pink
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Jul 09, 2010 | 2005 Chevrolet Silverado 1500 2WD
I have a 04 silverado do i need to install my component speakers in series or can i hook up woofer to factory wing and tweeter seperate from factory
With component speakers it is imperative that both the speakers be hooked up to the supplied crossover. Wiring them in series or parallel will not yeild satisfactory results since the woofer requires lower freequency then the tweeter, which plays the high notes.
Now some cheaper speakers do not use crossovers and sound rather poor. What make and model of speaker are installing? Does you truck already have component speakers in it?
Cheers,
Jan 06, 2010 | Alpine SPS-600C Car Component System
Need Radio wiring diagram 2004 chevy silverado 2500hd (oem plug)
Left Front Speaker(+) TAN ; Size: tab_tech.gif Left Front Speaker(-) GRAY ; Size: Right Front Speaker(+) L GREEN ; Size: Right Front Speaker(-) D GREEN ; Size: Left Rear Speaker(+) BROWN ; Size: Left Rear Speaker(-) YELLOW ; Size: Right Rear Speaker(+) BLUE ; Size: Right Rear Speaker(-) LT BLUE
Yellow -ignition
Orange-Constant +12 volts
Black - ground
If you need more info, please ask.
A rating is appreciated.
Jun 13, 2009 | Car Audio & Video
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Car Audio & Video Logo
118 people viewed this question
Top Audio Pro Car Audio & Video Experts
xxxxxx xxx
Are you an Audio Pro Car Audio and Video Expert? Answer questions, earn points and help others
