Question about Mitsubishi WS-55857 55" Rear Projection Television
Mitsubishi WS-55857 won't turn on
Hi.
I have a 55" Mitsubishi 1080 HD WS-55857. When I press the power button (on either the remote or the TV), the green light blinks on for 1 - 2 seconds, but then blinks off. The TV never turns on. Any suggestions?
  • Anonymous Mar 12, 2014
    I hook it up. I look through the channels, press input. I cant the tv to play my movies!!
    Problem Solver:
  • 7 Answers
Fwadley, is that your prom tux picture? lol
Posted on Jan 14, 2009
    Master:
    Sergeant:
  • 482 Answers
I would take it to a repair shop, they charge around $50 to look it over, and then tell you want is wrong with it and they will give you the cost to fix it. This is what I do when TV's go out. It will save you time and money in the long run.
Posted on May 19, 2008
    Genius:
  • 1,142 Answers
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha May 19, 2008
    Open the TV SET and look for a blown fuse near where the power cable enters the set. You can find the fuse very easily available in the market.
  • Maanita Chadha
    If it is blown replace it and do this wile the set is unplugged before replacing the fuse. You can also check the board where the components are mounted and
    resoled any that look bad. Brief power outages may cause the tv to turn
    off on its own. If you are using a surge protector, try connecting the
    set directly to the wall outlet.
  • Maanita Chadha
    I would suggest you to get a technician to check for any other part faliure. apart from fuse if you do find one.
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
MITSUBISHI WS-55315 WON'T TURN ON WITH REMOTE OR START BUTTON
do the self check and find the error code if set shows power and then goes total dead shortly after.
May 02, 2012 | Mitsubishi WS-55513 55" Rear Projection...
When i turn on my mitsubishi ws-55857 it turns off after a few seconds. should i call a repair guy???? i am a handyman??/ what should i do
Hello
this has two general failures that cause this type of problem... The first and easiest is that when the bulb gets older the tv's start turning off by themselves. Pop in a new bulb and the problem goes away. The second is a power supply issue, and those are generally available on ebay or shopjimmy. If you like the tv, I would find a new bulb ...
Best of luck
Nov 26, 2010 | Mitsubishi WS-55857 55" Rear Projection...
My power button broke to my mitsubishi hd 1080 and I lost the remote control is there any other way to turn it on?
is the button pysically broke... the unit does have a keyboard lockout feature press and hold menu for 10 seconds... maybe if not then the power button will need repair or a universal remote may be used
Oct 14, 2010 | Mitsubishi WS-65315 65" Rear Projection...
My tv has power and sound but no picture. its a mitsubishi projection model ws-55857
You need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 10, 2010 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 turn on/auto turn off problem
After it shuts off, you need to get a code from the tv by pressing the menu and device buttons together for 5 sec. A code will flash at you made up of 2 digits. Example. 2 flashes a pause and 2 flashes points to a convergence failure. If this is not your code post yours and I will help you.
Jul 06, 2010 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 55 in connection problem
there is a setting in the menu under setup i believe it is called
"LABEL VIDEO INPUTS". check you owners manual. you need to make sure that
the DTV input is set to YPbPr NOT RGB.
Feb 22, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Open Questions:
Mitsubishi WS-55857 55" Rear Projection Television Logo
492 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
