Question about Kenmore 72912 / 72914 / 72919 Bottom Freezer Refrigerator
Compressor hums and shuts off
My 72914 stopped cooling. The compressor clicks on but just hums and then shuts off (overheats I suppose). All lights and evaporator fan works fine. Defrost switch is ok. I was wondering if the capacitor was bad. It sounds like a split phase motor without the switch working and just hums until it over heats
  • deniserevel Jan 22, 2009
    i am having the same problems... compressor humms then shuts off and food is defrosting in freezer...frig 72913 is only 6 years old so out of warranty on compressor...spoke to many,many people at sears and all they want to do for me is sell me a smart service agreement...cost is $251 and covers max of $500 repair per repair annually... their customer service is about the lowest i have ever seen i guess we can see their stock prices fall and ee's will be laid off...who would shop sears not me and i plan to tell as many people as i know about my experience at sears...btw when i bought my washer, dryer and frig from sears all i had was problems from the start...they damaged the washer in delivery and dented my stainless steel frig...it has just been a unforgettable experience...next stop lowe's i know i will be treated better
    denise
  • 828 Answers
This sounds very much like a compressor failure. unplug the refrigerator and check the condenser for cleanliness. After cleaning the condenser and allowing the compressor to cool, plug it back in and listen for the same sounds. If the compressor was overheated it should restart after it cools. If it does not restart the compressor could be seized. Check the compressor warranty against the age of the refrigerator.
Posted on May 19, 2008
Air conditioner and fan will not come on ,when set a hum is heard for 15-20 seconds then shuts down
Sounds like a bad run capacitor on the outdoor fan motor. Compressor kicks on but quickly overheats because fan is not running. Good Luck!!
May 12, 2017 | Heating & Cooling
Hotpoint Refrigerator constantly runs and doesn't shut off normally.
Sounds like the thermostat is not working that is what tells the compressor it is cold enough shut off.
May 17, 2012 | Hotpoint Refrigerators
My refrigerator quit cooling. The lights work, and it routinely makes a clicking sound like it trying to do something. It is a Whirlpool ED22GW approximately 10 years old. Any ideas?
If the clicking is right at the compressor, there is an overheat switch there. If the compressor is not humming normally, it may be the start capacitor, or the compressor itself.
Check for dust buildup on the coils, that will overheat the compressor, same for a fan that is not working.
Mar 15, 2012 | Whirlpool Refrigerators
Kenmore 65234 bottom refrigerator has a hum/rattle for about 30 seconds then quiet, then after a couple minutes, it does it again. Sometimes for an hour this repeats and sometimes does it for a few cycles...
Might be the compressor relay is fixin to depart this life. themobilian_1937.jpg
If this relay starts sticking all the windings will remain active and overheat the compressor. The overload will tae notice and shut the whole shebang down. Once it cools and makes contact the circus continues until the relay finally disintegrates. The last death throws will be a constant clicking followed by noticeable cooling loss in the ice box.
Amana bottom mount service Manual
Mar 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Unit starts, it cools fine, but all of a sudden it stops I used to click on the interrupter, but it doesn't work anymore I take the power off for 15 min, connect again, it works 2 minutes and then stops.
Low freon will usually cause a freeze up, your sounds like an overheat shut off, compressors get hot, but if the get too hot there is usually a safety shut off... also, if the compressor is wearing out you can install a hard start cap inline with the compressor to bang it into operation. It would make an unusual humming sound if your compressor is not turning... capacitors are inherently dangerous when charged, so you may need someone to install it for you. The caps are not expensive.
Feb 27, 2010 | GE AGW18DH Electronic Room Air Conditioner
Compressor motor won't start. Hums and clicks
Most likely the problem is either the condenser coil is very dirty or the condenser fan isn't working causing the compressor motor to overheat and cycle off on its internal thermal limit or the compressor capacitor is defective causing the compressor to overheat and cycle off.
Nov 10, 2009 | Kenmore 57029 Side by Side Refrigerator
Small frig stopped
are you sure the compressor is running or is it just humming trying to start then clicking out on the overload, if so you have a 50\50 shot of the relay being bad, otherwise the compressor is shot
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
Whirl pool side by side refrigerator problem
It looks like the Capacitor Start Relay is failing.  It is located either on the starter Relay or mounted on the side of the compressor compartment.  It sould have two wires on it, one orange and the other probably white.
Oct 22, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore 72912 / 72914 / 72919 Bottom Freezer Refrigerator Logo
627 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
