Question about Lexmark X83 All-In-One InkJet Printer
Lexmark x83 paper won't go through, no paper jam. sometimes it catches one side and then goes sideways and stops
  • kshinn247 Jul 16, 2008
    I tried to push a piece of file folder through. Won't go. I tried a heavier gauge paper, got stuck as before. Isn't there some way to get in there to see?
    Problem Solver:
  • 15 Answers
Sounds like there is something like a part of a sticky address label, or a piece of other paper stuck inside.
Take a heavy piece of card stock and feed it through the paper path. Chances are, when you get the card stock all the way through, it will push out the offending object that is hung in the paper path.
Posted on May 19, 2008
My Lexmark X2480 printer starts to feed the paper, it goes crooked and then an error message appears that there is a paper jam. How can I get to the rollers to clean them please? Thanking you in advance...
Normally this occurs when there is a tiny piece of paper stuck between the front roller and the feed metal piece. This can be cleared by putting something like a piece of card in (after lifting the flap at the front) and sliding it sideways until you can find the paper. Long nose pliers or tweesers can then be used to remove it.
Alternatively, put the card in and manually feed it though - as sometimes it can pick up and clear the paper jam.
Hope this helps.
Jul 26, 2011 | Lexmark 2480 Matrix Printer
How do I remove the cover of my lexmark X83? The paper will only feed part of the way then I get a paper jam message.
there is a cover there at the back of your printer, pull it down then remove the paper hang on their, then after you remove , check if there is another paper to hang, after that try to print
Jul 01, 2009 | Lexmark X83 All-In-One InkJet Printer
X83 lexmark A06 error (paper jam)
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 31, 2008 | Lexmark X83 All-In-One InkJet Printer
Label sheets won't feed, jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
good luck..
Dec 22, 2008 | Lexmark Z845 InkJet Printer
Lexmark X83 all-in-One printer drivers
Unfortunately, that is correct. Lexmark stopped software support for the X83 after Windows XP.
Jan 18, 2008 | Microsoft Windows Vista Ultimate Edition
LEXMARK X83 PRINTER 1) A few times papers jammed too far back to pull out from the front so i pulled them out the back. Now when the paper feeds there is a clicking noise and the papers feed only...
Oct 10, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 all-in-one printer
Hi gerby, need to eliminate a few issues to get to the cause. First, check for a jam. Paper jams can be so tiny you can barely notice them. Use a torch and check thoroughly down back of unit in paper feeder, open cover, let cartridge carriage roll left and settle. Now look inside thoroughly too. If no jam, check rollers are even and look same on each side. Post back if no good.
Sep 01, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
98 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
