Re: Cobolt Jumbo remote control code for a centrex tv
Hey guys,
I am just chasing a code for the Cobolt 3 in 1 jumbo tv remote for a centrex tv as it does not have the centrex listed on the back in the brand listings however gives an option to scan for it but is not working!!
Look foward to hearing back from you in relation to this matter.
Kelly Stubbins
kel-n-rikk@hotmail.com
Try 0633
Posted on Aug 25, 2008
LG codes for a jumbo remote
Check these codes. 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Oct 22, 2012 | Jumbo Universal Remote TV DVD VHS...
Cobolt 3 in 1 jumbo remote control
have u checked wether is is supported or not????
it may not be supported.............
Sep 18, 2008 | Televison & Video
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
Sharper image jumbo remote to work with dish network
I can help you with your Sharper Image Jumbo remote control.
There are two Sharper Image Jumbo Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual. Click the above links to download these remote manuals. The included code lists will give you the correct codes you require.
The Jumbo Touch also has a learn function, while the standard jumbo does not.
I hope that helps.
Apr 04, 2010 | One For All URC-9910 LCD Remote Control
Jumbo remote codes and steps
I have found the iWave, Innovage, and generic "JUMBO" are the same remote.
Here is the link to the manual. It looks like it has a easy to do auto-search button, for TV's not on the list.
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
Good Luck
Dec 16, 2009 | Innovage Jumbo Remote Control
The sharper image jumbo touch panel remote control, can program every appliance (tv, dvd,etc.) except my directv hd receiver. no codes listed in booklet for the hd receiver, tried the codes for regular...
The instructions that came with my remote were COMPLETELY incorrect. I made note in pen in my jumbo remote manual. After hours of searching the web and piecing together various blogs, I wrote these easy-to-use instructions:
  1. Place the jumbo remote and your old remote on a flat surface, head to head, with a 1" to 2" space in between (the remotes should be aiming at eachother).
  2. Press and HOLD the device button on the jumbo remote (eg. TV) until the jumbo remote's small indicator light turns solid red.
  3. Press the LEARN button once on the jumbo remote. The light will blink rapidly.
  4. On the jumbo remote, press the button that you want to perform the learned action (eg. If you want the jumbo remote to turn your TV on and off, press the POWER button on the jumbo remote).
  5. Press the same button on your old remote (eg. POWER button on my old tv remote control). When the jumbo remote's light changes from rapid flashing to slower flashing, press ENTER on the jumbo remote.
  6. You're done! Try the jumbo remote out (eg. Aim the jumbo remote at your TV, press the jumbo remote's TV button, then press the jumbo remote's POWER button). Your television should turn on or off with your jumbo remote.
You can program any jumbo remote button this way (eg. MENU, EXIT, MUTE). Just make sure you press the same button on each remote in steps 4 and 5 (eg. MENU on jumbo remote, MENU or LIST on old remote).
Jan 04, 2009 | One For All URC-9910 LCD Remote Control
Need codes for Innovage Jumbo remote control with a Freeview box.
hi can anyone HELP I HAVE COBOLT JUMBO REMOTE BUT NO CODE FOR ACCER LCD
Dec 25, 2008 | Universal Remote Control Remote Control
Remote codes
www.reomtecodelist.com .........................................T.
Mar 21, 2008 | Televison & Video
416 people viewed this question
 Grubhead
Grubhead
