Question about Audiovox FPE4216P 42 in. Plasma HDTV
Audiovox FPE4216P won't come on - power board problem?
A friend of mine gave me his one year old FPE4216P TV. He said that the display had a red area in the top center which later spread in a line across the top and down the center. One day, while watching a show, the TV shut off - power light went red, and he could not get it back on.
When I got it to my house and I plugged it in, the power light will turn blue but the screen won't come on.
Is this a power supply board problem or is this too expensive to be worth keeping the TV?
In addition, the red led on the board printed 782-PH42D8-200A does not light up. It also has a sticker with the number 667-PH42FB6-20.
Thanks for your help.
  • Booberbird Jun 01, 2008
    My set is 14 mo old and yesterday while on it suddenly switched off. buttons did not work to turn it on again though the red power light was on. I unplugged it and replugged it and it then turned on. The picture is there but its fadded and has areas of black pixalation in it. It's over warrenty and I just don't know what to do. What happened and will it cost over $500 as a repair shop told me on the phone? This was a gift to me and I'm on Social Security so I'm kind of shaken by this.
    Thanx, Lee
  • Tushy2 Jun 21, 2008
    Sound no picture and red dot/sparkles/speckles fix summary
    This post is basically for anyone that stumbles across it trying to fix what seems like two fairly common problems with plasma tvs. I apologize for the length of it but hope it can help others.
    To start off, I got a free Audiovox FPE4216P 42" Plasma TV.
    The previous owner said that there was a red cloud in the top center that after time spread across the top and down the center of the screen. Some time later, they were watching it and it was as if someone simply turned the power off. After that, there was no longer any picture - menu or otherwise.
    After much research on the net, it seems that fixing plasma TVs is strongly based on the educational guess method. This compounded by the fact that replacement parts are quite scarce and generally crappy customer service provided by the manufacturer if the TV is older than 14 months basically makes many of these TVs $2000 doorstops if something goes wrong with them. Luckily, my TV uses many LG boards which seem to be used in a number of different makes and models.
    Once I took the set apart, I first checked the power coming into it and it checked out ok. I then found a fuse on the YSUS board that had blown, upon replacing it, I no longer had sound. The indicator light on the front would turn from red to blue for about 3 min then back to red. After this happened, the LED on the power board would light up and the there was no longer any response from the power button (led on front would only stay red). I would have to unplug the set and plug it back in to duplicate the above.
    I then checked the voltages for Vs, Va and 5v on the connectors coming off the power board (using the DC setting on a voltmeter) against the specs on the sticker on the back of the display panel and they checked out.
    It was recommended that I change the YSUS board since the fuse had blown on that board. This seemed counter-intuitive to me since it seemed that the power was fed into the YSUS board through that fuse first as if to protect the YSUS board.
    With reluctance, I purchased a "new" YSUS board. Once I popped it in - presto! I had picture! But picture with a cloudy, sparkly red "I" beam that would show through the dark areas of images including the menu screens. It seemed that as long as there was a color over where the "I" beam ran, it was fine and there was only a problem when the image was supposed to be black.
    I say possibly mal discharge because it seems that some label this problem as such where some describe mal discharge as another problem.
    After much research on the net (again), it seems that there are two fixes for this problem: 1 - a new control board and 2 - adjusting the voltages. It seems that each fix has about a 30 - 50% success rate. With the first fix, you just pop in a new board and you could be done or you could have the same problem. With the second fix, people have said that the dots have gone but the image is now crappy or they have different color dots. Some also say that merely changing voltages will only temporarily fix it. I opted for the cheaper second fix.
    My power board has two potentiometers (pots) on it (adjustable dial thingies). One for the Vs and one for the Va. I first made sure that these were adjusted to spec. I took readings off of the molex connector and grounded to the support bracket of the set.
    My YSUS board has 4 pots, two are labeled SetUp and SetDn and the other two are on little circuit boards rising off the YSUS board - one of which was completely inaccessible due to it's position behind the support bracket.
    I first set the TV to an empty input since the red showed best against all black. Jacking up the SetUp pot seemed to have the effect of making the black really black and essentially removing the red. SetDn didn't seem to due much and I didn't mess with the other pots. When I switched to an active source everything looked great but then I started to notice that on bright images that weren't quite white, there was blotchy pixelation and redness. It then started messing with all three accessible pots and got the image to be really good but I could still see some red and now blue sparkles in the dark areas.
    I was pretty satisfied with my results but there was that one other pot that I could not get to unless I removed the YSUS board. Since I knew I would have to adjust that pot multiple times, I decided to remove the board and drill a small hole in the support bracket to gain access to the pot with the board installed. For me, this was the most difficult and frightening part. I didn't want to damage the panel itself and I also didn't want to get metal shavings everywhere. I carefully masked off the area and nearby boards with paper and when I drilled I held a piece of wood behind the bracket.
    I then had access to all 4 pots and just kept messing with different balances between them. I used an empty input to check the black and numerous DVD's to look for crappy picture on lighter areas. As it turns out, the menu for the Underdog DVD really showed the light image flaws.
    Now, the image is about 98% perfect. When a lighter image turns to complete black, there are some, extremely diffuse red and blue brief pixel flashes (just for a millisecond) but then the black stays black. To notice it, you have to be within 3 or 4 feet of the TV which I think is too close anyway for a 42" TV and is virtually non-existent when watching DVDs.
    Here is some extra part number info with possible equivalents:
    YSUS: 6871QYH953A or 6870qyh005B and possibly 6871QYH053B EAX31974801 EBR31872801 EBR32642701 6870QYH105B EAX31631001 EBR32642702 1032298-hs
    Control Board: 6871qch977b or 6870qch0C6b and possibly 6870qch006b 6871QCH077B 5070-5623
    Power Supply Board: 667-PH42FB6-20 or 782-PH42D8-200a and possibly 6FB0192010
    Thanks for all your help Minnie!!!
Thanx, Lee
Posted on May 31, 2008
Is my tv 220 volt? whats the volts that my tv needs?
If you bought the TV in the United States it runs on 110 volts.
Sep 24, 2014 | Audiovox FPE4216P 42 in. Plasma HDTV
Audiovox 07 42 plasma
I have encountered that issue several times. I want to give you practical solution. There is nothing at user side that we can do. But a qualified hands on technician should check the connector at the display-matrix driver area. Most of the case connectivity issue of the connector or display has the dead zone. Since you mention you lost video totally it will be helpful option to check the display's power input level. You may try authorized service centers of the Audiovox. If you specify your location we may check possible options
Good Luck
Jan 25, 2008 | Audiovox FPE4216P 42 in. Plasma HDTV
Broken screen on audiovox fpe4207hr
At 42", it will be cheaper to by a new tv. Plasma is vacuum sealed. The new LED is better.
Feb 12, 2014 | Audiovox FPE4216P 42 in. Plasma HDTV
I have an audiovox FPE4216P. the picture has gone almost entirely black still have audio. help
Check the picture setting in that the brightness has not been turned right down.
Also check that the ambient light sensor in menu is off.
Lastly check the picture menu that "cinema" or other mode has not been selected, select normal.
Please dont forget to vote this answer was helpful
Many thanks
Feb 16, 2011 | Audiovox FPE4216P 42 in. Plasma HDTV
Tv power comes on but no picture th name Audiovox
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Dec 01, 2009 | Audiovox FPE3206 32 in. LCD Television
No picture only sound
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty with some type of extended purchase plan, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | Audiovox Televison & Video
No power on a Panasonic This TV just does not turn on now. Panasonic CT-32HL44J 32" CRT TV 4 years old. A friend of mine seemed to think this is a common problem with either Panasonic TV's in...
I have a Panasonic and after a year it did the same, this turned out to be the PCB Board(this is the master board). You may be able to pick one up on EBay possibly.
Dec 03, 2017 | Panasonic Televison & Video
Problem with screen
Mine did the same thing and it was the back light board. Good luck getting one. I had to threaten to sue them and badger Audiovox until they mysteriously had one. Now my power suppy is bad at least I got another year out of it. This TV SUX!
May 27, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Audiovox FPE4216P 42 in. Plasma HDTV Logo
363 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
