Question about Leviton (102-5G108-RW5)
Network cabling need to find manuals on how to install network cabling and what tools I need to buyo
  • Anonymous Mar 14, 2009
    how to climping the i/o box
    New Friend:
    Problem Solver:
  • 12 Answers
I want to say just one thing that use Ethernetpedia App.then u understand many thing realated to it.
Posted on Dec 20, 2014
Sir, if i switch on my PC it tells me Primary drive 0 is not found, so i don't know what causes that?
Posted on Feb 20, 2009
Sir, i need some manual on this topic like network cabling.
thanks.
Posted on Jun 26, 2008
  • 22 Answers
Hi
Here is a gret link to get you started.
http://fcit.usf.edu/network/chap4/chap4.htm
I hope this helps.
/Shawn
Posted on May 19, 2008
No internet - cannot get online
plug in the internet cable.
May 23, 2015 | Computers & Internet
Tip
Tips to Use Computer Network Cabling
Problems in computer network due to computer network cabling can be stressful for someone. follow the simple tips mentioned below to keep away from issues caused by network cables:
They come with eight wiring standards which are T568a and T568b. to keep away from any trouble it's recommended that you ought to not merge the eight wiring standards on a same network.
in case you are fixing network cabling in a brand spanking new place, it's suggested that you ought to go in for patch panels to forestall any computer network problems.
in case you need your cables to give an optimal result make positive you buy the right plugs for them.
Make positive the cables you use are not over eight hundred sixty four feet long and ought to be devoid of any joints.
Network cables ought to not be placed along the electrical cabling and also avoid suspension of network cables on ceiling.
To prevent any network issue make positive that no network cable is crooked or even turned. And also stay away from metal pins for securing cables.
A network cable consists of four crooked wires which come in different hues of brown, orange, blue and green. To steer clear of any network issue make positive that not over a quarter inch of the cable is untwisted at both the ends.
As mentioned above that a cable has four wires. usually only eight are used but still it's essential you keep all the pairs wired to uphold network requirement.
While doing network cabling for your network always use the highest quality tools. receive a lovely quality crimping gizmo for the same. basically steer clear of pliers.
In areas where radio frequency is on the higher side, try and use shielded crooked pair or STP network cable in lieu of unshielded crooked pair or UTP network cables to avert meddling.
on Jan 13, 2011 | Computers & Internet
I have 08 ford escape when I try to scan it said no communication
Do you know about communication networks or serial data communications on vehicles , these let the scan tool communicate with the different modules on the vehicle ! Newer vehicles have several, PCM - powertrain control module , Anti-theft module , Air bags , antilock brakes , Body control module or in the case of ford a smart junction box . an some others !
Communications Network Vehicle communication utilizes both International Standards Organization (ISO) 9141 and controller area network (CAN) communications. ISO 9141 is used for diagnostic use only, and CAN is used for many modules to communicate with each other on a common network. CAN in-vehicle networking, is a method for transferring data among distributed electronic modules via a serial data bus. Without serial networking, intermodule communication requires dedicated, point to point wiring resulting in bulky, expensive, complex, and difficult to install wiring harnesses. Applying a serial data network reduces the number of wires combining the signals on a single network. Information is sent to the individual control modules that control each function.
The vehicle has 3 module communication networks:
  • ISO 9141
  • Medium speed (MS) CAN
  • High speed (HS) CAN
All 3 networks are connected to the data link connector (DLC). This makes diagnosis and testing of these systems easier by allowing one scan tool to be able to diagnose and control any module on the 3 networks from one connector. The DLC can be found under the instrument panel between the steering column and the audio unit.
HS-CAN Network Operation
The HS-CAN network communicates using bussed messages. The HS-CAN network uses an unshielded twisted pair cable, data bus (+) and data bus (-) circuits. In addition to scan tool communication, this network allows sharing of information between all modules on the network.
The HS-CAN is a high speed communication network used for the following modules:
  • ABS module
  • 4WD control module (if equipped)
  • Instrument cluster
  • PCM
  • MS-CAN Network Operation
    The MS-CAN network communicates using bussed messages. The MS-CAN has an unshielded twisted pair cable, data bus (+) and data bus (-) circuits. In addition to scan tool communication, this network allows sharing of information between all modules on the network.
    The MS-CAN is a medium speed communication network used for the following modules:
    • SJB
    HS-CAN Network
  • What type of scan tool are you using ? or are you using a code reader ?
  • What
Computer No Communication Troubleshooting by Wells Saturn Toyota Echo No Communication Case Study
Mar 18, 2015 | 2008 Ford Escape
Hello Steffen, We have a 8830 scanner Synergix.
Hey Panos,
What are you trying to feed a paper roll or single sheets or are you telling me you cant feed the original to be scanned? Can you copy or print internal status pages from your Xerox?
But it sounds like thats not the problem as it isnt hooked up and your lappy as it dont have a serial port you only have USB...... but this is a network printer.... do you have a network or it is just a stand alone lappy?
So I guess.. stand alone lappy to Xerox.... you will need to network it... and if it just a stand alone lappy ie no network then you will need a non standard network cable called a crossover cable to go from scanner to lappy but you will also need to set up a network with them manually asigning IP's of each to be on the same network, then hooking with a crossover (normally red never blue) network cable, and you will also need the software installed on this lappy no matter which way we go
Spose you could try a serial to usb adaptor but they will have issues propally when trying to use that sort of interface on scanning, normally one has the print server that is an option on your scanner to interface with the likes of a laapy, so I dont think it would workor a good idea to go with an adaptor
Well come back with some more info because the more info you can give me about your problem the better i can understand it.. cheers
We are talking about one of these beastys.. User Manual
Cheers
Steve
Dec 16, 2011 | Xerox 8830 Copier
How to create a network ?? using five computers ? what are the things that i need to know please help me...
for this the hardware you need is CAT 5E cable , rj45 connectors, crimping tool, a 8 port network switch, make straight combination in cat5e cable, then connect one side to the switch and other to the pc do this in all the systems, after that run the network setup wizard thats it
Jul 26, 2011 | Computers & Internet
My network adapter was missing and i need to install the network device so i can use my LAN cable
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall a yellow? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109025.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-pro-100-m/3000-2112_4-109029.html
hope this helps
May 26, 2011 | Computers & Internet
How to see visited webpage by other computers on my home network
You can access them by installing any third party tools in your system. The best third party tool is Cain & Abel. You can download it from www.oxid.it . Install the software and in that you can see number of menus and tools that are used for the Information Gathering and Password breaking. First of all you have to configure the software by activating it each time the system starts. When the activation completes the service will run each time the system is turned on.By following the user manual present in the website mentioned above you will come to know how to use it .It is a damn good Security and Network Information Gathering tool for Windows Operating System.
Nov 07, 2009 | Computers & Internet
I dont know crouter configuration
Dear sir, Here's How:
  1. Choose a convenient location to begin installing your router such as an open floor space or table. This does not need to be the permanent location of the device. Particularly for wireless routers, you may find it necessary to re-position the unit after installing it as the cables / signals may not reach all areas needed. At the beginning, its better to choose a location where it's easiest to work with the router and worry about final placement later.
  2. Plug in the router's electrical power source, then turn on the router by pushing the power button.
  3. (Optional) Connect your Internet modem to the router. Most network modems connect via an Ethernet cable but USB connections are becoming increasingly common. The cable plugs into the router jack named "WAN" or "uplink" or "Internet." After connecting the cable, be sure to power cycle (turn off and turn back on) the modem to ensure the router recognizes it.
  4. Connect one computer to the router. Even if the router is a wireless model, connect this first computer to the router via a network cable. Using a cable during router installation ensures the maximum reliability of the equipment. Once a wireless router installation is complete, the computer can be changed over to a wireless connection if desired.
  5. Open the router's administration tool. From the computer connected to the router, first open your Web browser. Then enter the router's address for network administration in the Web address field and hit return to reach the router's home page.
    Many routers are reached by either the Web address "http://192.168.1.1" or "http://192.168.0.1" Consult your router's documentation to determine the exact address for your model. Note that you do not need a working Internet connection for this step.
  6. Log in to the router. The router's home page will ask you for a username and password. Both are provided in the router's documentation. You should change the router's password for security reasons, but do this after the installation is complete to avoid unnecessary complications during the basic setup.
  7. If you want your router to connect to the Internet, you must enter Internet connection information into that section of the router's configuration (exact location varies). If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider (you would need to have requested it), the static IP fields (including network mask and gateway) given to you by the provider must also must be set in the router.
  8. If you were using a primary computer or an older network router to connect to the Internet, your provider may require you to update the MAC address of the router with the MAC address of the device you were using previously. Read How to Change a MAC Address for a detailed description of this process.
  9. If this is a wireless router, change the network name (often called SSID). While the router comes to you with a network name set at the factory, you will never want to use this name on your network. Read How to Change the Router SSID for detailed instructions.
  10. Verify the network connection is working between your one computer and the router. To do this, you must confirmed that the computer has received IP address information from the router. See How to Find IP Addresses for a description of this process.
  11. (If applicable) Verify your one computer can connect to the Internet properly. Open your Web browser and visit a few Internet sites such as http://compnetworking.about.com/.
  12. Connect additional computers to the router as needed. If connecting wirelessly, ensure the network name (SSID) of each is computer matches that of the router.
  13. Finally, configure additional network security features as desired to guard your systems against Internet attackers. These WiFi Home Network Security Tips offer a good checklist to follow.
Tips:
  1. When connecting devices with network cables, be sure each end of the cable connects tightly. Loose cables are one of the most common sources of network setup problems.
What You Need:
  • A network router (wireless or wired)
  • Network adapters installed on all devices to be connected to the router
  • A working Internet modem (optional)
  • A Web browser installed at least one computer in the network
regards
murali
Aug 27, 2009 | Macsense XRouter Pro MIH-130A (MIH-130A/6)
Can i connect my xbox to my laptop /w pc usb
Xbox Network Connection using Hub
This is the most common network configuration and is also the easiest to setup.
Step #1: Plug your network cable(RJ-45 cable) that comes from your cable/DSL modem into the uplink port of your hub. (Make sure that your uplink is switched to "on").
Step #2: Take an RJ-45 cable and run it from one of the ports of the hub, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your hub directly to your xbox.
**NOTE** A switch may be used in place of a hub with the same basic setup.**
That's it! No other network changes should be needed for this configuration. Your Xbox is now on the same network as your PC.
Xbox Network Connection using Router
This is another common network configuration.
Step #1: Plug your network cable(RJ-45 cable) that comes from your modem into the WAN port of your router.
Step #2: Take an RJ-45 cable and run it from one of the ports of the router, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your router directly to your xbox.
**NOTE** In steps #2 and #3, you should not use a port that is directly beside the "uplink" port on your router, if your uplink port is being used to connect to another routing device.** If your router has a built in firewall, you will need to forward ports 8602 both incoming and outgoing to the internal ip address of your pc. Consult your device manaul for port forwarding.
That's it! Your Xbox is now on the same network as your PC
Xbox Network Connection using Crossover Cable
This is the last network configuration. For this setup you need at least one NIC card.
Step #1: Plug your USB cable that comes from your modem into your PC's USB port. This should already be done, if you have a usb modem for your current internet connection.
Step #2: Take an RJ-45 cable and run it from an installed NIC card on your PC, directly to the Xbox.
**NOTE** A crossover cable is only needed if you are connecting the Xbox directly to the second NIC card. If you have a device such as a switch, hub or router in between you should use a standard RJ-45 cable. This type of network setup also requires "Winroute©", a program downloadable from the world wide web. Consult the manual for specific instructions on how to set this up. Also if you have a USB ethernet adapter, you may use any of the setups described herein. USB ethernet adapter basically converts a USB cable into an RJ-45 cable.
That's it! Your Xbox is now on the same network as your PC.
Aug 14, 2009 | Video Game Consoles & Games
I have no manual and I need to figure out how to scan on this machine. Canon Imagerunner 50001.
Download the network scangear from the canon web site.
Install the scangear on all the computers you want to scan to.
On the scangear tool there is a discover icon,click that icon and wait till the ir 5000 is picked up by the network.Select the machine in the scangear tool.Now you will be able to scan to mirosoft word and exel like you normally do with a scanner.
If the scangear tool was unable to discover the machine,the network settings of the IR must be checked.
Hope this help.
Mar 09, 2009 | Canon imageRUNNER 5000 Copier
Leviton (102-5G108-RW5) Logo
356 people viewed this question
Top Leviton Computers & Internet Experts
ashburton
Michael Galve
Michael Galve
george  peters
george peters
Are you a Leviton Computer and Internet Expert? Answer questions, earn points and help others
