Question about Motorola Mobility RAZR V3xx Cellular Phone
Quit charging I started charging my wife's motorola razr v3xx and it won't charge. When I plug in my phone, which is exactly the same, it does start charging. So I know the charger works. To see if her phone had a battery problem, I put her battery in my phone and it also started charging. So what's going on with her phone? A loose wire or something?
    Problem Solver:
  • 8 Answers
It is a Problem of charger Socket in Your Phone, Please Go to the nearest Motorola Service center Or gallary, If Not found, So to any local Mobile Repair Shop. good to go Motorola Service center because they provide original accesories & parts.
Posted on May 19, 2008
For awhile now my Razor V3xx has been shutting off by its self, the battery jumps around all the time like from full charge to almost dead to half way charged
try draining all the battery first, then remove the battery and put it back. It may just be a loose battery. Charge it until it is full.
Jun 26, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
My razr isnt charging like it use to
Your charging port is damaged, unfortunately. With a damaged handset, your only options are insurance, upgrading, or purchasing with confidence a different handset compatible for your carrier from Ebay, Amazon or Craigslist.
I would recommend insurance above all. Visit your nearest wireless carrier for further assistance. Thanks.
Mar 16, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Home Charger Quit Working
Hi!
Its not due to charging it via usb. Your charger is not giving full amount of charge and thats why its charging with the usb but not with the charger. And, if that is not the case then somehow an internal ic inside your phone is blown and needs a repair.
Please ask for further clarifications.
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Mar 01, 2009 | Motorola Mobility RAZR V3
Can you provide free unlocking codes for Motorola Razr V3xx
Hopefully this will work for you. Go to your cell phone provider and ask them for a 3G Sim card. To my knowledge all V3XX are 3G. I discovered that my service provider had 3G SIM cards after I purchased my husband a v3xx and he had problems with his service. I was told by the service technician when I called for help to try the 3G and it made the difference for my husbands v3XX. I am not certain this will fix your issues but it is always best to use an item t hat has been made special for that phone type... Meaning 3G.... I hope it works. I don't know if it will cost you anything or not. In my state they do not charge for SIM cards. But I have heard that some other states charge around $20 for a SIM card.
Jan 13, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Powering up
you should take the phone back and have it replace for a new one.
Aug 16, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
V3xx signal loss
take the phone to a mobile service shop and have them replaced the antenna that is located on the phone's main-board.
May 25, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola V3xx I-mode
Under the settings for usb connection type change the setting to memory card connection. This is subject to having a memory card (Micro sd) installed. Otherwise you may have to install motorola phone software into your computer and use this to update files on your phone.
Regards,
David M-G
Feb 20, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Cant charge
you need a new battery'
motorola battery cant charge when its fully drained.
Dec 25, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Motorola razor v3xx
Unfortunately, other than opening up the phone and swapping out the power module and/or jack, replacing it is one of the only options.
You may also want to check out a local mobile phone repair shop. They typically are priced quite fairly, and I imagine you could get it repaired for much less than the cost of a new one.
Dec 13, 2007 | Motorola Mobility RAZR V3
Motorola RAZR V3xx not powered on
you need to charge a phone over night for the battery to fully charge and have a memory
try plugging in as charging and turn phone on by holding the red button down for a few seconds on the right hand side
Oct 11, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3xx Cellular Phone Logo
98 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
