"Panasonic dmr-es15" My unit was working fine until I put a HP DVD+R/RW disk in it. It asked me if I wanted to format it. I said yes. After the process, I set the timer, it accepted the time, I then shut off the machine. Later on when I went to finalize the disk, & watch it. I received the U61 error message. The clock blinks sometimes, other times it will display Ch 3, on the display. I do hear noise coming from the disk, like it was trying to read the disc. Panasonic Tech support was very responsive (via their E-mail service). After 2 E-mails, the final resolve was to send the unit in for repair. Any ideas. I believe that if I did not use the HP DVD+R/RW disc, this would not have happened.
    Sergeant:
    Champion:
  • 347 Answers
This is what U61 syands for
"unit is carrying out a recovery process, don't do anything , just wait till display returns to normal, remove disc first."
I found this in another forum, you might find it helpfull.
"Yesterday, my DMR-ES15 started to malfunction, giving me the error U61.
No matter how many times I tried to press Enter, and Power On, the machine
kept re-booting with the error U61. I noticed that the drive was making
some noises as if the Read head was not able to park properly.
So I decided to open up the unit and find out why.
I took out the 3 screws holding the DVD drive top in place. And then moved
the drive head mechanism back (pushed it towards the back of the unit).
I then plugged the power in, turned it on, and amazingly there was no more
U61 error.
I test the unit this morning again and everything seems to work properly again!"
Posted on May 19, 2008
  • Santiago Vallejo
    Santiago Vallejo May 19, 2008
    If your product is still under warranty call Panasonic and they will send you a technician, or they will pick it up, and fix it for free.
  • Santiago Vallejo
    Here you can find a more detailed proces about, how to fix your U61 error code, however, if you have the change i will recomend you to call Panasonic and ask them for your warranty, or see if you can change that product since i have heard it has that common anoying U61 error code.
    http://jacobshome.blogspot.com/2008/02/p...
    Genius:
  • 1,665 Answers
I am trying to record with a sony dvd-r disc and the recorder don't recognize it. the only disc that works is the dvd ram 4.7 but that disc does not work on other standard dvd players. what is the answer?
According to the official description of that recorder, you should have no problem, this is from the description for the DMRES15:
Recordable DVD Media
Record your favorite shows onto DVD-RW, DVD-R, DVD+RW, and DVD-RAM DVD discs. The DMR-ES15 is also compatible with DVD+R Double layer media and provides up to 14 hours of media recording.
Multi-Format Player
Don't worry about limited playback capabilities, the DMR-ES15 can play DVD, DVD-RW (VR Mode), DVD-RW (Video Mode), DVD-R, DVD+R, DVD+RW, DVD-RAM, VCD and CD-DA discs. Also, you can play your favorite songs from CDs or MP3 files, and JPEG images.
Nov 29, 2009 | Panasonic DMRES15 DVD Recorder
Trouble with DVD+RW Disks being compatiable or staying formatted
cos they are cheap - get some decent branded discs such as TDK or tayo yuden and it should be fine
Also check the manual and or requirements on there website and it should show which are the best discs to use for that player but TDK or tayo yuden should be fine.
www.svp.co.uk or any where you can buy discs from should be fine
Apr 15, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EH55 Ram Drive Failure
Buy a used DMR-ES15, DMR-ES25, DMR-ES45, or DMR-ES46 with a good DVD drive and swap out your bad drive.
Jan 23, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
DMR-ES15 Stops after 45 Min.
U88 means the unit has detected an error while recording or playing and has entered its recovery process to restore the unit to normal operation. You could try using a DVD-RAM disk or a different make of DVD-R but, as you say the unit is new, you should probably return it to the retailer for exchamge, repair or refund according to unit age and retailer's return policy.
Nov 03, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
DMR-E50 DVD recorder versus DMR-ES15 are these equivalent recorders
The DMR-ES15 is a later model (around 2006/07) than the DMR-E50 (2003/04), but essentially both should do the same job so technically - a good equivalent in terms of recording and same brand so yes. The connections on the rear (of the replacement recorder) should suit and work with your other devices just as the old one did.
According to some other online reviews, the DMR-E50 has had a few issues with recording, and finalizing certain discs.
I'd say go for it - accept the replacement - as long as it comes with some kind of guarantee, works fully and has all the accessories (including remote, instructions etc.) you should be good. Contact the store and seal the deal.
I hope you can get this in time for Christmas.
Dec 21, 2017 | Panasonic DMR-E50 DVD Recorder
Panasonic DVD Recorder Model DMR-ES15
For the unit to be confirmed if its o.k or not You have to take disc which is not very knew and slight scratches ,offcourse which is playing in your other dvd player.Play it on dmr-es 10 see if it plays normally,if it does than its lens is o.k.Other thing you can try is insert blanck disc and try formatting it,if it does than it s o.k.Try R+,R- AND RW+,RW-.iF This disc can be formatted on dmr es10 than the unit you can decide to purchase
Dec 18, 2007 | Panasonic DMR-ES10 DVD Recorder
Suddenly won't read discs
just try playin the lens cleaner disc....
Sep 18, 2007 | Panasonic DMR-ES10 DVD Recorder
Model No'DMR-ES15 - U61problem
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
May 23, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
