Question about Mitsubishi VS-70601 70" Rear Projection Television
Mitsubshi VS-70601 TvGuide+
I just hooked up my tv and it says its programming the TvGuide+ and it says turn off tv or cancel. i hit cancel and nothing happens and i turn the tv off and 12 hours later it still isnt programmed. why is it doing this? it wont let me change channels or go to the menu or anything. only the volume works when its like this
    Problem Solver:
I had this problem and only thing that worked was turning the tv off while programing was in progress approx. 30mins and back on again and it is fine untill the set is unplugged again and then the process must be repeated.
Posted on Jan 18, 2010
  • badfishaquar Jan 18, 2010
    Even better solution for this issue, go to the tv main menu, press 1370. This should bring you to a blue screen hidden menu, select guide plus option and turn it off. No more guide plus no more problem :)
I have the same problem have ypu figured it out yet?
Posted on Jun 16, 2008
I don't see a way to contact sling tv to cancel
FAQ: How do I cancel Sling TV? - Help Center
  1. Cached
  2. Similar
Start by signing in to your account on your computer. Click the Cancel Subscription link on your account page. Tell us the reason why you are leaving the service, then click CONTINUE. Enter your password, then click CANCEL MY SUBSCRIPTION to confirm.
Sling TV - My Account
  1. Cached
  2. Similar
Manage your Sling TV account, add new programming and rent movies.
FAQ: What happens if I cancel Sling TV early? - Help Center
  1. Cached
  2. Similar
If you cancel within your free trial, your subscription will be terminated immediately. To view your subscription renewal date, sign in to your Sling TV account on, then, visit your View Billing Details.
Cancelling sling tv Google Search
Jan 04, 2017 | Computers & Internet
How do i stop the DEV auto power off frkm turjing my tv off?
I am having this problem and It is happening on 2 different brand tv's. I have had Foxtel on both tv's for years and never had a problem until I moved, I got the Foxtel reconnected at my new address and it started. I have IQ on 1 tv and standard digital on the other. If anyone could help that would be great.
Feb 21, 2015 | Televison & Video
2002 Passat I hit the ignition nothing happen. I
Sounds like you need to clean your battery connections.Next time it happens, turn your headlight on and wiggle the battery treminals, and if the lights come on, thats your problem.
Jul 10, 2010 | 2002 Volkswagen Passat
Timer light is flashing and I cant turn on tv
The V26 DM repair kit should take care of that issue. The kit has the caps and the instructions. You can get it at
Aug 03, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Guide button only works for curent program (first push) . Second push should bring up full program menu, but instead it just goes back to tv show.
I had the same problem with my 37L and 42L Vizio TVs but my 26w vizio TV guide works perfectly. on 12/28/2009 I called vizio about the problem and they said that Vizio lost a law suit with a company (tech didn't tell me the company name) that said that Vizio did not own the "TVGUIDE" technology b/c the other company invented it first. So, Vizio was forced to turn this feature off in their new TV's so that's why my guide button with older Vizio 26" TV (bought in 2007) works and my newer 37" and 42" Vizio TV's (Bought in 2008) do not even though the instructions are still in their user manuals which the tech said will be removed in future user manuals.
Jul 07, 2009 | Televison & Video
Panasonic DVR, loss of TV Guide on-screen program listings
I had the TVGUIDE listing through my GE TV and it came across with a notice that they would no longer be putting out the listings. That was last year and the listing never showed up again. Your DVR may be recording digitally but if you can see it on a analog tv, it is using a analog turner and you will need a converter box to record once everything goes digital.
Most of the digital converter boxes come with a guide built in. I have the Magnavox and the Zenith and they work fine. You will need two converter boxes, one for the DVR and one for the tv, if you want to watch the tv and record a different show at the same time.
I would hook them up by splitting the antenna wire to the tv and the DVR. Then I would use the RCA plugs to connect the DVR to the TV and use the Input setting on the TV when I want to watch the DVR. You will have to set the converter box to the channel that is playing the program you want. The DVR will be set to channel 3 or 4 (whatever channel the converter box is set on to broadcast on) to record on, not the broadcast channel. Make sure the power saver on the converter box is set to off or the converter box will turn off after a couple hours and you will get no picture for the dvr to record on.
The digital signal is being sent over the air usually over UHF channels. It sent digitally but will be picked up by your antenna in the same way it picks up the analog signal thus there is no difference. There is no such thing as a digital antenna, thus a antenna from a Home Depot will work fine. I needed a outdoor antenna but the picture quality is the same as cable. Just make sure the antenna can pick up UHF and VHF signals.
Hope it helps!
Jun 02, 2009 | Panasonic DMR-EH50 DVD Recorder
How do i stop the tv guide plus from loading?
when this has happened to me in the past; if I remember correctly I hit home, stop, cancel, etc any of those gets it to send me the banner that if I stop is not going to CANCEL loading!!! I'm thinking YEAH!!! and then I select the prompt to cancel. I then hit menu again, to cancel and I believe I select home...Now perhaps you think I SOUND a bit "iffy" it would be true; seeing how it has been at least 3 months since it has happened and I sure not going to go and hit that ****** to walk you thru it(he he) sorry but I know you know how it is!!! GOOD LUCK DON'T GIVE UP AND DO YOUR BEST TO NEVER HIT THAT TVGUIDE+ AGAIN (i have many times and its always a pain in my brain)
now get her done!
Mar 02, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Need code list for tvguide unvrsal remote
universal remote, rca tv program lennox dvd plaYER 2003
Feb 09, 2009 | Sharp Televison & Video
Snowy picture with catv 1 mono on screen
is tv making some.. sound...please tell me..
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
Recorder is not showing tv listings
I spoke with Toshiba tech support today (800-631-3811). They have an advanced services team that focuses on TV Guide On Screen. Learned the following:
- The TV Guide On Screen signal is updated 4x / day and is broadcast by your service provider
- The broadcast channel varies depending on what the service provider chooses (though typically a major network or PBS station)
- TV Guide On Screen has been doing some reprogramming and updates recently and this has resulted in many sporadic outages
If you ARE not receiving your listings, it's one of two things - either your DVR or the signal from the cable company.
- If you are having issues, call Toshiba and let them know, they will walk through some basic troubleshooting to narrow down if the problem is the DVR or the TV Guide On Screen signal.
- If the issue is the TV Guide On Screen signal, they will be able to report the issue to TV Guide On Screen and let them know their is an issue.
After that - it's in someone else's hands!
Feb 05, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Televison & Video Logo
192 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
