Question about LG LRTBC1825T Top Freezer Refrigerator
LG refrigerator not working
Refrigerator is not cooling. When this happens if I unplug the refrigerator and plug it back on it starts to cool but after some time it stops cooling again. Please advise what may be wrong with the refrigerator.
LG model # LRTBC2025BK
  • 3 more comments
  • sri1 Jun 02, 2008
    Pardon my ignorance but where would I see the error code on this model. LG model # LRTBC2025BK (top freezer).
    Thanks.
  • sri1 Jun 03, 2008
    Greetings ...Thank you all for your suggestions. This time I unplugged refrigerator and plugged it back on after cpl of days. Using leveling screws i raised the refrigerator bottom to allow air to move freely. Also I was using an extension cord which removed and connected the refrigerator to the outlet directly. Currently the refrigeraot has been running with out problems for over a week. If I run into the issue again I plan on replacing the thermal fuse as suggested. Great site and very much appreciate the recommendations and the suggestions.
  • Anonymous Aug 12, 2008
    Refrigerator shuts off get a ER FF code. Unplugging seams to render it for a few days and it happens again.
  • steve151971 Dec 12, 2008
    where is the evaporator located? is there somewhere that I could find the schematic for this?
  • Anonymous Mar 29, 2014
    Model wirlpool mf226682q temp keeps going up unable to cool.
    Champion:
  • 210 Answers
What lights are on, it has an error. Most likely if it runs for a few hours after plugging it in, the problem is with the thermal fuse. It is located on the evaporator. You will need a service call unless you can get the part. It is quite easy to change.
error code would be ER DH or 567 in the freezer lite up.
Sgt 48
Posted on Jun 02, 2008
  • Andrew Lauder Jun 02, 2008
    On the display where you control the tempurature. When the unit stops to work, what lights are on?
    Sgt 48
  • Andrew Lauder Jun 03, 2008
    ok so what is happening the unit gets to defrost and stops. Therefore it is most likely the thermal fuse is blown.
    It is located on the evaporator. Get this fixed and your problems are over.
    Sgt 48
  • 828 Answers
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
Posted on May 19, 2008
Lg refrigerator is not working at all
Unplug the refrigerator for ten minutes then plug it back in. If it starts to cool you need a new control board.
Feb 28, 2014 | LG Refrigerators
LFC20745SW- Refrign not working, the freezer working
the refrigerator is not defrosting automatically the vent is geting ice up blocking the air flow when you unplug it the refrigerator defrost and start working like normal they may be a problem with the motherboard
Sep 11, 2013 | Refrigerators
I have a LG LRSC26940TT and the cooling temp. keeps saying error and the freezer is not cold. i unplugged it and when i plugged it back in it worked but then i put food in the freezer n it said error...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | LG LRSC26940TT 36" Side-by-Side...
Refrigerator section not cooling
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jun 20, 2010 | LG LFC22740 Bottom Freezer French Door...
Need help w LG refrigerator..temp control not working. Was told it is computer chip Can you advise?
Hello there:
There are a couple of reasons why this controle may be not working (or it may be working but not properly)
I will post this solution in 2 seperate posts so you can troublehoot this in detail ok before going right to the chip and associated parts
It's not cool If the refrigerator isn't cool, you need to answer some questions,
Is the thermostat knob turned to the proper setting? If not,unplug the refrigerator for 30 min then plug it back in than reset it. first at the highest setting than slowly turn it counterclock wise to see if it clicks if not the temperature control device itself may be bad and not the chip itself.
the chip rarly fails
Next, see if the compressor motor is running Cooling is poor
May 27, 2010 | LG LFX25960 Bottom Freezer French Door...
Stopped cooling
Best to unplug the refrigerator now and let compressor cool. The internal overload will be damaged if power remains on and trying to start. We need to test the compressor and start components before you buy anything, Let me know Sea Breeze
Aug 18, 2009 | Frigidaire FRS26R4A Side by Side...
LG LRTBC1825T Top Freezer Refrigerator Logo
1,995 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
