Question about Sony Handycam DCR-TRV460 Digital Camcorder
Cannot record anything - can't see anything thro the viewfinder or in the screen
I am unable to see anything through the viewfinder or on the LCD in the camera mode. I just see a blank (black) screen. Whereas payback is ok.
Could anyone help? Is the lens damaged?
Regards
GR
  • 3 more comments
  • Anonymous May 29, 2008
    I have the same problem, screen shows blank in record mode. Play back is working fine.
  • Anonymous Oct 17, 2008
    Me too! Same problem! Playback is working fine - just can't see anything in camera mode.
  • Anonymous Nov 09, 2008
    i have kinda the same problem i can See through the lcd but i cant see through ther veiwfinder ! i have model sony handycam HI8 ccd-trv58 ntsc
  • caapsize Apr 02, 2009
    I also have the same problem The REC turns on however nothing shows on the led,screen or thru the viewfinder HELP
  • Anonymous May 02, 2009
  • 10,594 Answers
Hello grnca,
CCD Imager ( an electronic part) at the end of Lens Assy got defective thats why you can't see any result in camera mode.
Please contact nearset Sony repair shop for replacement of CCD Imager IC.
Posted on May 27, 2008
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
Not seeing anything through the viewfinder when switched on
Most cameras and video recorders now display picture either through the viewfinder or the LCD screen.
Your camera model allows the same. Although if you turn the lcd screen towards the subject (screen faces the same direction as the lens) then the viewfinder switches on.
Sep 26, 2009 | Canon ZR200 Mini DV Digital Camcorder
Not able to view anything on screen
I work on this model of samsung the lcd problem is a common thing with this camera
The ribbon cable to the lcd from the camera cracks and causes what you are talking about .
Normally the camera will still work buy using the eye viewfinder for recording and playback but you will not hear the sound unless the lcd door is open but then the picture in the viewfinder goes away when this door is open and comes back when it is closed
my email is spinboss@comcast.net and sell on ebay as uromastyx
Jan 25, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Black screen
Assumed that LCD screen is black and what about Eye piece viewfinder? Does it show picture to you?
If LCD Screen is black, it means it has no back-light. check any button to turn back light on & off at LCD portion.
There can be an other reason of black LCD. a flexible cable which connects LCD and Camera circuits and it can be broken/ cracked/ out of order.
May 30, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
Samsung vp-d24i 800x camcorder's recording problem
saaame fuckin problem, opening it after a long time it gaved me this....black screen i cant see anithing i cant recordanything, but it can play mini dv's..i tought it was a battery problem, it doesnt charge anymore and so i've just bought one it arrives tomorrow...we'll see
Apr 24, 2008 | Video Cameras
LCD screen stopped working
sounds like the LCD screen viewfinder may have been twisted or accidentally catched or got hooked or snagged on on something at one stage and pulled something, if the screen went yellow it means the three wires going to it are possibly broken or the small white clip was slowly coming undone inside the Viewfinder for the red and green to no longer work to complete the image also indicates why the buttons on the viewfinder are not responding, try twisting the viewfinder very lightly whilst on, but most likely the small white clip holding the wires has come off at the elbow inside the camera
Apr 22, 2017 | Sony Handycam DCR-HC21 Mini DV Digital...
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
No picture in LCD or viewfinder
Flexwire in electronic viewfinder (EVF) is broken, you need pro fix.
May 19, 2007 | Canon GL2 Mini DV Digital Camcorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
329 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
