Question about HP DeskJet F380 All-In-One Printer
Ink cartride dear all, can I use HP 21b cartridge in HP deskjet F380 printer? I already see at HP website, it says that this printer is using HP 21 and 22 Cartridge. if I use 21b, is my printer is going to be broken? thank's
  • 975 Answers
NO , ITS NOT GOING TO DAMAGE YOUR PRINTER , IT IS SAFE TO USE , HP 21b , WHICH " b " STANDS FOR BLACK INK , hope its helpful AJ
Posted on May 19, 2008
Can i use 21B cartriages in hp deskjet D1560
Cartridge 21 & 21B are similar cartridges, instead of 21 can be replace with21B.. Only difference between them are economy in pricing & yield.. 21B is lesser cost than 21..But both genuine packs are manufactured by HP,
Apr 26, 2012 | HP D1560 Deskjet Printer InkJet
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
I need to know where to put the ink cartridges for HP F380 Deskjet Cartridges 21 ??not sure od other cartridge No. if 20 or 22
Hi ,
I am pasting a link from where you will be able to replace the cartridge and u will have all the information required .....
http://h10032.www1.hp.com/ctg/Manual/c00656399.pdf
Now when u open up the link u need to click on Maintain the Hp All in one and on the right side scroll down and then you will find everything that you need ,,,
All the best
Mar 31, 2010 | HP DeskJet F380 All-In-One Printer
I can't get my HP DeskJet F300 series back online.I ve done everything, I ve even stopped the print spooler and started it again but the same problem still exists.And another problem that the ink cartidge...
First, the cartridges. This printer uses a 21 for Black and a 22 Tri-Color. The 58 is a Photo cartridge that replaces the 22, not the 21. Make sure that the cartridges are properly placed in the printer. The next step is the easier one. Might sound like some work, but it is the best way to correct conflicts with HP branded printers. First, uninstall the printer from the PC completely. Use the uninstall function. When that is done, re-install the printer onto the PC and test it. This should solve your problems, as long as there is not physical issues with the printer itself.
Sep 26, 2009 | HP DeskJet F380 All-In-One Printer
My HP Deskjet F380 Series Won't Print
If you are not using an HP factory new cartridge, then that may be your problem.
Jun 14, 2009 | HP DeskJet F380 All-In-One Printer
I have a HP Deskjet F380 All-in-One. Error light keeps flashing.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP DeskJet F380 All-In-One Printer
What to do? HP Deskjet F380 Error with Cartridge 21b.
hi!!!
removed the cartridge
and placed it back properly!!!
Oct 26, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
116 people viewed this question
Ben Johnson
