Question about Canon PIXMA MP210 Photo All-In-One Printer
Hp officejet pro k5400 will not print the mc light is blinking. I just put in new print heads this morning.
  • Anonymous Sep 22, 2008
    same problem. blinking mc LED and after replacing the print head. no fix.
  • Anonymous Feb 10, 2009
    just replaced the ky printhead. printed printed a few copies fine and now is blinking again.
  • Canon Master
  • 419 Answers
1. Printheads have an expiry date so I'd recommend checking that the printhead has not past its expiry or something similar. It's a shot in the dark but may be relevant.
2. It's also possible that the connecting strip at the back of the printheads slot is soiled with ink or condensation... Try using a cotton bud to gently clean this strip of any moisture, wipe the contact on the printhead too (NOT the printhead nozzles!) and then reinsert the printhead.
As Rowdytown points out though, pulling the power on this printer and then reinserting after a couple of minutes usually resolves any internal issues as well by hard resetting the printers state.
Posted on Jan 24, 2009
  • 3 Answers
When something like that happens with ours, we can usually just power it off and then back on to fix the problem. If that doesn't work, try unplugging it for a couple of minutes and then plugging it back in.
Posted on Dec 13, 2008
Magenta light flashing
Check your lights , this printer has a user replaceable print head as well as the ink cartridge http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c00844061
Nov 17, 2013 | HP Officejet Pro K5400 All-In-One InkJet...
Hp k5400 light blinking, can't print
The blinking means the cartridge is out of ink and needs replacing.
Jun 24, 2011 | HP Officejet Pro K5400 All-In-One InkJet...
Black ink not printing properly on HP Officejet Pro K5400. It's a new cartridge, have tried another cartridge too but same problem.
The print head may be blocked.
Run the cleaning cycle a few times on the machine.
This can be done through the software drivers loaded on your computer.
If this does not help, you will need to replace the black print head.
Feb 14, 2011 | HP Officejet Pro K5400 All-In-One InkJet...
HP Officejet Pro K550 - Printhead Error Message on new printhead - cleaned printhead, contacts... tried all fixes... what now? Is it faulty?
I have the same problem. I replaced both printhead cartidges. The MC light stopped blinking, but the KY light kept blinking. I thought it was a faulty new KY ink cartridge. So I returned that cartridge and got a new one. Still the same issue. I called hp and they said the print head is bad now and all they focused on was trying to sell me a new printer. UG! I also heard wiping off the printhead with a dry cloth may help. Did you get yours to wokr?
Jan 27, 2011 | HP OfficeJet Pro k550 Printer
I have a HP officejet pro K5400...It used to print beautiful photos but now has horizontal stripes across the photo..I tried the HP solution..aligning heads, etc but with no luck..any solution? I hadn't...
that is called banding and yes they get old /dry out , sometimes cleaning will fix other times they never will clean and then only a new printer will FIX the problem .SORRY
Jan 21, 2018 | HP Officejet Pro K5400 All-In-One InkJet...
OfficeJet Pro K5400...ink cartridge
Er, NO.
The answer to the above question is clearly misleading.
If you consult the documentation for your HP K5400, which can also be found online, you will find that the printer cartridge lights also blink when the print heads require replacing.
If you have replaced the cartridge and the light still flashes, this is the most common solution. Replace the print heads.
Unfortunately because the printer is badly designed, there is no way of indicating this, and you will have troubles if you attempt to get the HP Toolbox or any other diagnostic tools working.
Feb 12, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
HP K5400 will not print black
Check the black/yellow print head.If necessary replace it.It's part number is C9381A, #88
Oct 13, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
HP k5400 KY printhead always reports bad on Monday morning
Remove the Printhead and clean the contacts on the back of the printhead and also in the where the printhead mounts.
Try leaving the printer turned on over the weekend as the fault maybe caused by the ink drying out.
Jun 22, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Officejet K5400 Won't print black
  • If there are defects on the page, run a Level 3 clean from the control panel of the printer. Follow the steps below:
    1. Press and hold the Power button.
    2. Press the Cancel button one time and the Resume button nine times.
    3. Release the Power button.
May 15, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
My KY yellow light is blinking. What should I do?
The k5400 is not recognizing that the ink cartridge is installed. Clean the contacts on the back of the ink cartridge and also the contacts in the K5400 printer. I always use 91% isopropyl alcohol, Hp says to use distilled water. Do let the contacts completely dry before reinstalling.
Feb 24, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
2,245 people viewed this question
old marine
old marine
