Question about Optoma MovieTime DV10 Multimedia Projector
Optoma DV10 - Temperature Light turns solid red moment after it's turned on.
The lamp blowout after about 120 hrs of usage. After replacing the lamp, I watched one movie. The night after, when I turn it on, the red temperature light came on rendering the player un-usable. Any hep would be greatly appreciated.
Regards,
Binh
  • lton Jul 22, 2008
    How do you reset the lamp ?
  • 563 Answers
Hi bkdao
Did you reset the lamp timer ?
Check if all the fans are in working condition and also check if your colourwheel is in one piece.
Posted on May 19, 2008
Why won't my Optoma DV10 projector won't turn on?
On an Optoma DV10 if its not the lamp timer, then it might be a cooling fan that needs replacing. Take out the old one, and look-up its part number online. If you don't feel confident taking it apart, have a qualified person do this.
May 23, 2014 | Optoma MovieTime DV10 DLP Projector
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
I have the Optoma MovieTime DV10 Multimedia Projector. About two days ago, I was starting to get two solid red lights on the LED for temperature and lamp. Now it is constantly blinking on and off, every...
Dear Sir,
Welcome to Fixya Support.We are Happy to assist you.
Your Projector temperature sensor could be faulty. So locate the temperature controlling sensor and replace it with new one. It will solve your problem.
Best Regards
Chandrashekhar
Dec 24, 2010 | Optoma MovieTime DV10 Multimedia Projector
Lamp bulb indicator is red and unit will not light up
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Also, check and clean the air filters.
Jul 17, 2010 | Optoma HD65 DLP Projector
Optoma HD 70 turns on with lamp and temo soiled lights
Asher fadida and alll,
The issue:
solid red error light?
HD70 "die's" after few min with strage noise?
flickers different colors before complete self shutdown?
well try this....
Before replacing your bulb, fan or any other component try first cleaning your optoma realy good!! HD70 doesnt comes with any kind of filter so you can imagine the amound of dust can be.
The most importent thing is to blow away any dust from your color wheel + the sensor attached to it .
for farther troubleshoting clean your fan's.
there are 2 fan's insinde the HD70.
probably the most problems will be solved by cleening the color wheel!!
if the problem is not solved ,chack the lemp and the fans if they work properlly.
For fan replacing:
Fan Part number: GM1207PKVX-A
Good luck!!
Feb 23, 2010 | Optoma HD70 DLP Projector
Lamp light is solid orange/red; No Image on screen when pj on
Sounds like bulb to me best way to check is take it to a service centere and they will use a replacement or test bulb to find out for you , it may not be your bulb it may be your ballast circuit . ... regards Vortash
May 10, 2009 | Optoma HD72 Multimedia Projector
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Microtek cx6
I've had the same problem with my projector three times (usually whenever there's a sports championship). You just need to call optoma, get an RMA number, and ship it to them. Theoretically they'll fix it under warranty and send it back free.
May 02, 2008 | Optoma HD72 Multimedia Projector
No picture
My too, same problem - tried replacing lamp ($150), no luck, replaced ballast ($200) no luck, replaced power supply ($150) no luck and TSC is telling me to replace the main engine ($600) - way too much for this piece of junk (cost me $4000 in 2005) - don't buy optoma products!!!
Nov 11, 2007 | Optoma RD65 65" Rear Projection HDTV
No Picture
its probably the ballast that is bad, call Optoma and you can buy a ballast for it, but you will probably want to have a pro do it, changing the ballast is a lot more involved than just changing the bulb, the ballast is what powers the bulb and it does go out on occasion.
Oct 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Optoma MovieTime DV10 Multimedia Projector Logo
441 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
