Question about Singer CE-100 Futura Computerized Sewing Machine
SINGER CE-150 YOU STATED THE MACHINE MAY BE OUT OF TIME IF THE THREAD KEEPS BREAKING AND WHEN EMBROIDERING THE BOBBIN THREAD IS WHAT SHOWS MORE THAN THE COLORED THREAD.  DOES THIS MEAN I SHOULD TAKE IT BACK TO THE STORE WHERE WE BOUGHT IT?  THE MACHINE BELONGS TO MY MOTHER-IN-LAW AND I'M THE COMPUTER WHIZ IN THE FAMILY SO I GET TO TRY TO RESOLVE ALL THE PROBLEMS WITH THE MACHINE.   THANKS, DERRAL
  • Anonymous Mar 24, 2014
    94 year old mother in law can't remember how to thread the 9608.
  • 323 Answers
Reduce the upper tension until the thread doesn't show on top anymore. This will probably solve both problems.The problem you describe is mechanical not computer related.
sewman7
Posted on May 21, 2008
I have a singer Futura CE-250. I am having problems with the tension I think. While embroidering the top thread is showing completely on the underside of the material. In other words the bobbin thread...
One of the things they don't really tell you about embroidering with the singer machines is that you really do need to use the same color in both the bobbin and the top. No matter how much you adjust the tension, you will still end up with some of the thread from both showing through on the other side, unlike with most other machines.
I found this out from a Singer technician about 3 years ago when I had the same problem with my CE 150 and was going nuts! He worked with both Singers, Vikings and Huskvarna's. and saved my sanity after demonstrating a lot of technical stuff that basically showed me why Singers did this.
Save your sanity-just bite the bullet and use the same thread in the bobbin as you do in the top.
May 27, 2011 | Singer CE-100 Futura Computerized Sewing...
I have a Singer CE-100 and I would like to know why it keeps beeping and stopping?
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
I have the futura ce-100. When embroidering it
This annoys the heck out of me, cause it happens a lot more than it should. There can be some valid reasons as to why it happens, though.
Mar 22, 2010 | Singer CE-100 Futura Computerized Sewing...
Bobbin thread is coming to top when embroidering. I have changed needle and re-threaded several times
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Feb 16, 2010 | Singer CE-100 Futura Computerized Sewing...
The thread and bobbin are nesting up in the bobbin case
Two things I have found that make my singer ce-200 nest. 1st. When I change threads, sometimes I thread it wrong - always nests when I do that. 2nd. When the bobbin runs out of thread it always nests for me, so I have to check the bobbin often. And I remembered a 3rd thing. 3rd. The area for the bobbin & bobbin casing has to be clean, no pieces of threads, and the bobbin casing itself can move, so make sure it's seated correctly.Whenever I get nesting, I take the metal cover off, under the needle, to get in and clean the bobbin area and under the needle good, before I go back to embroidering.
Oct 28, 2009 | Singer CE-200 Quantum Futura Computerized...
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Bobbin/threading
Could be acouple of things. The tension on the thread or the bobbin. The needle not in all the way. Wrong type of needle for the thickness of the material. My problem was always trying to pull or push the fabric with the needle in the material - cause a bend, then the tip snags the side of the bobbin hole. Snap it's gone.
As your friend suggested, check the threading of the bobbin, the click she/he might be talking about it the first rotation of the bobbin, then being snagged by the needle thread. Good luck!
Jan 19, 2009 | Singer CE-100 Futura Computerized Sewing...
The thread keeps breakijng when I am embroidering
It could just be that your needle is blunt and you need to put a new one in. It is amazing how many different problems a blunt needle can cause. Hope its sorted now.
From Sewmad
Nov 04, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer futura ce-100 embroidery machine
Under the embroidery attachement (on the front side) is a lever to engage or disengage the "feed dog control." When embroidering, you need to move the lever to the level to disengage. The feed dog control should only be at the righe side position, or raised when you are not using the embroidery attatchment.
Jan 31, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
212 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
