Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Black and decker mm675 lawn hog
I took the blade off of my b&D electric mower, but I cannot figure out how to lock the shaft to get the blade nut tight. Any ideas?
  • Anonymous May 29, 2008
    i tried wedging the 2x4 in place but i could not get the lockwasher to slide into place. the blade axel would not stay far enough out for it to lock the axel while i turned the nut
  • dug6g-004 May 11, 2010
    I have a similar problem, but I'm trying to get the blade *off* so I can replace it and the fan and the plastic blade insulator. The instruction manual says to use a 2x4 to keep the blade from turing. Well it keeps the blade from turning, but the shaft turns freely even when the blade is held in place with the 2x4. So the question is, how do I lock the shaft to loosen or tighten the nut when the blade does not hold the shaft like it's apparently supposed to do?
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
Posted on May 23, 2008
I'm not sure, but I think the little black plastic thing that holds your blade in place is damaged, I am having a similar problem where the shaft is spinning and not catching the blade. Now trying to replace that part the shaft was spinning with the nut I was trying to replace. I finally got it off by using a vice grip to hold the square metal and damaged plastic part in place while turning the nut. However now I am having a hell of a time finding the replacemet part that says right on it "replace if damaged"
Posted on Sep 07, 2009
  • dsopala Sep 07, 2009
    Found the part, it's called an insulator. you can find it at sears, I figured out exactly which part I needed for my model from the Black and Decker website. the one for my lawn hog mm875 is 241381-01
    http://www.searspartsdirect.com/partsdir...
    Champion:
  • 313 Answers
After you install the fan the next step is to install blade then plastic spacer either orange or black spacer then the metal washer and the nut. nut will fit the 2 flat side of the shaft hold it while tightining the nut.
Posted on May 29, 2008
Blade insulator fails immediately
if the blade isolator is slipping and breaking off then the shaft isn't being locked properly to blade , there can be a few reasons 4 this too happen ,(1) teeth on bottom of lock nut worn off (2) shaft is rounded off in one spot ( lock nut not properly tightened)
Apr 23, 2016 | Garden
Black and decker lawn hog 18 was working fine last time used but will not start now what,s the problem
while unplugged rotate the blade a few spins to move the brushes if there stuck make sure the outlet is good and try another power cord
Aug 13, 2012 | Black & Decker Black and Decker Mm575 18"...
How do i tighten the blade on a black and decker MM575-18
Hi Kevin,
User a pair of channel-locks to grab the square spacer below the nut. Then tighten down the nut using wrench.
May 07, 2012 | Black & Decker Lawn Hog 18-Inch 12 Amp...
How to hold shaft when replacing blade
You should hold the blade while loosening the bolt that holds the blade.
Jim
Aug 05, 2011 | Black & Decker Black and Decker Mm575 18"...
I cannot remove the blade from my B&D MM575 mulching mower. The manual says to block the blade, then loosen the nut. However, when I block the blade and turn the nut, the shaft continues to turn,...
You can use a pipe wrench on the shaft and a regular wrench on the nut. Disconnect your spark plug and tip the mower onto it's left side. You will have to use your left hand to go down through the mower shoot to hold the pipe wrench and your right hand to unbolt the the blade attaching bolt, it should come off immediately.
Remember you may have to purchase a new blade holder, since your problem shouldn't occur if your blade holder was OK. GOOD LUCK.
Jul 28, 2011 | Black & Decker Black and Decker Mm575 18"...
I have a black and decker lawn hog mower with a 19 inch cut that i am trying to change out the blade. My problem is i cant get the mounting nut off becausethe shaft keeps turning. I have tried everything,...
are you turning nut the right way ! on a lot of mowers, the nut turns off the opposite way the blade turns, to keep it tight. good-day ! Loosen the nut in the center of the blade with a wrench by turning the nut counterclockwise.
Jul 14, 2011 | Black & Decker 19" Electric Lawnhog...
Cannot tighten blad for 18" Electric B&D Mulching Mower
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
May 26, 2010 | Black & Decker Black and Decker Mm575 18"...
Black&Decker MM675 lawn mower height lever would not stay
I would look in my owners manual and get the part number for the height lever and order a new one. You could also try and wire the height lever so it can not move. I am not sure how it engages but you could may be try and bend the lever so it is tight and won't move. Just a couple of ideas.
Good luck
Aug 31, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
1,532 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
