Question about Olevia LT32HVE 32 in. LCD Television
Headphone jack My headphone jack randomly stopped working. the headphones still plug in all the way. I dont know what the problem is
  • 979 Answers
More than likely, the headphone jack is loose on the interface board and will need to be resoldered...accordianman
Posted on Jul 01, 2008
My headphone jack does not work, sound still comes out from the speaker when i plug head phone. please what should i do?
it shows that the headphone may gone bad, or the jack of your pc needs repair, check your headphone to some other computer if it ok then go for repair the jack from some qualified technician
Jan 11, 2013 | Computers & Internet
I have a Latitude D600 laptop. When I plug in my headphones, the sound still plays through the built in speakers. When I twist the plug in the jack I can sometimes get sound in the headphones but it still...
I dont think the JACK is the problem, I suspect a bad headphone wire (intermittent) or an incorrect driver, headphone jacks in laptops are software controlled, (no mechanical switch inside) if you hear sound in both the headphones and the speakes it is a driver issue, try updating the driver, if the headphone wire is erratic it can fool the software that controlls the input and do crazy things also...
May 26, 2011 | Dell Latitude D600 Notebook
The right headphone on my sennheiser eh 150 doesn't work, Iv'e opened up the headphone and both the cables are securely held in place so its not the speaker, the cable is also fine no sign of any damage,...
I have the same problem, but in my case, I pulled accidentally the cable when it was plugged, but I can't neither see any damage in the cable,plug or headphone; in fact, it looks very strong. I did the same, opened the headphone, but everything's in its place. I've been browsing for two days and can't find any article related to this problem. It would be a shame to have to get rid of these headphones, they sound great!
Aug 18, 2010 | Sennheiser EH150 Consumer Headphones
Aspire 3680 headphone jack recognizes any headphone plugged in but no sound from the headphone jack, the internal speakers work but not the headphone, running vista
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Apr 02, 2010 | Acer Aspire 3680 Laptop
How do i set up the Technika TA-709 Wireless Headphones to my tv. Have lost the manual and am not getting any sound only static on all 3 channel selections.
You should have all the necessary cables to do this with the package you bought, the wire which has a headphone style plug on each end should be plugged into the headphone jack on your tv.
If they dont work then there are two further things that could be at fault:
A: The headphone audio volume controls and the actual speaker volume controls on tvs are totally different and if the actual headphone volume is turned down then you will get an interference type noise thru your headphones as no sound is being detected by the reciever and therefore they go into kind of a standby mode. !!!!!!!!!!Try looking in your TV settings menu to make sure your headphone volume is turned up!!!!
B: being an owner of a pair of these headphones I know how audio the cable can easily turn faulty from prolonged use us. The wires can easily break inside but look fine from the outside so get a new one. Headphone jack to Headphone jack cable.
I use these along with my xbox 360 wireless earpiece (fits nicely under the headphones) and I think they're far superior to the Turtle beach headphones +++ My setup is 100% wireless which also makes it better than any turtle beach setup on the market.
Jan 07, 2010 | Audio Players & Recorders
There is a sound on the computer. But when I put on the headset, it does not work. The sound on the laptop still goes on.
If the sound of your laptop does not transfer to your head phones first ensure that you have plugged your headphones in the proper jack (I know this sounds silly but it happens.) You may have mistakenly plugged your headphones into the mic jack. Secondly if you are plugged into the proper jack try a different set of headphones to verify that it is not a problem with the headphones. If you get the same result with a second set of headphones then your headphone jack may be bad or came unplugged from your motherboard. In this case disassembly of the laptop may be necessary to check the headphone jack. I would wait for a few more suggestions before going that far though. Hope this was helpful.
Barrett Canning A+, Network+, Windows XP Certified Tech
Nov 20, 2009 | Computers & Internet
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Feb 26, 2009 | Marantz SR7500
Sentry HO900 headphones
The H0900 should come with a mini-plug adapter. The headphone jack in my TV was deeply inset, so I kinda reversed it. The adapter plugs into the transmitter, then the Red/White plugs, into that, then the long end of the cord into the TV.
Works fine for me. My problem will be posted seperately.
Mar 09, 2008 | Sentry HO900 Headphones
Button/Jack
Replace the player - there is no repair for this
Jul 02, 2007 | iLO (2 GB) MP3 Player
Olevia LT32HVE 32 in. LCD Television Logo
224 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
