Question about Vivitar ViviCam 3710 Digital Camera
Pc won't pick up camera
When i plug the usb cord in, the power light on flashes green and red five times then stays red, pc won't even pick it up, i have xp home.
    Scholar:
  • 99 Answers
Here is the manual for the camera. It would have the error codes and also the OS that are compatible. Thanks! / Go here to download the manual for future reference:
http://www.vivitar.com/ecms.aspx/e65dedb4-5c74-4e09-8110-95947ea5f876/SupportFiles/ViviCam3713.pdf
Posted on Jul 20, 2008
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
Battery charging shows quick green light
Ill try to help you, I think the slow flashing green lite is when you first plug it in the longer its on it will flash quickly when almost finished mine blinks untill full then stays on try to wear your battery all the way down then try to charge again good luck
Mar 24, 2014 | Nikon COOLPIX L19 Digital Camera
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Jan 27, 2014 | Softheat Heating Pad HP218 12 3P
Sony Bravia KDL-55EX500 flashing green and yellow light, an won't turn on. Any suggestions?
you guys are going to love me. lol. i figured it out at least for mine. $ )
1.start by unplugging the tv and everything plugged into it(make sure the only thing plugged into the tv is the power cord).
2. next plug in the usb flash drive with the update or a compatible version of the firmware.
3. now while holding down the up arrow button on the tv remote, plug in the tv and keep holding the up arrow while pressing and holding the power button on the side on the tv until you see the light on the tv go from solid green to solid red and yellow flashing lights. once you see this just sit back and wait a few min for it to force the update and it should turn on when its done.
let me know if this works for you as well or if you need any clarification. also know that step three is a pain to do alone and must be all done within a short period of time preferably at the same time.
Oct 16, 2011 | Sony Televison & Video
I cannot stay connected to internet, my model 2701HG-B 2wire at&t dsl will start flashing red then disconnect me from the internet or my game site, how can i get this to stay fluently connected please!
You might want to try disconnecting everything EXCEPT the power cord. If you still get the red power light (it should stay there forever) then bring the gateway to Radio Shack or somewhere they have a 5 volt DC @ 2 amp power supply and plug it in for 5 to 10 minutes and see if the power light then stays green. If it stays green then all you need is a new power supply! If not, then the gateway is fried. Mine keeps going from a solid green power light to a flashing green power light and I can hear a relay click every 2 minutes at which time a pop-up say "ethernet line disconnected". I tried new power supply etc. to no avail! It is fried after 1.5 years! No more 2wire for me!
Sep 28, 2010 | 2wire 2700HG-B Router (2700HGB)
I have Vista and need a driver for Pentax, Optio S digital camera. I have a USB cord for the camera but not the disk. When I turn on the camera all I get is a black screen with the letter and number A90. I...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Aug 21, 2010 | Pentax Optio 33L Digital Camera
When i plug in my usb charger, the light flashes red green then orange. even without my battrie
try cleaning the battery(copper bits) try charging it on your lap top, it should flash red green orange, keep unplugging and plug back in again its worked for us
Jun 24, 2009 | Samsung NV3 Digital Camera
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
Kenko
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
Mar 27, 2017 | Kenko MC-4 DG for Nikon AF 2x (MC4AFNDG)...
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Vivitar ViviCam 3710 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
