Question about Sony DVP-NC600 Multi-disc DVD Player
SOURCE: Sony DVP-NC600 Powers down during CD playback
The tray won't open. I took top off and dvd top side holder, but the laser mechanism won't disengage so the tray will open, even with no dvd in it. How do
I reset it. I power on, hit open key, it makes hum noise then goes by to
standby mode.
Posted on Oct 11, 2008
SOURCE: SONY DVP- NC85H
I am getting this error too and I believe it means that somehow the tray that the discs ride on is jammed. I think if you unscrew the three screws on the back and the two on the sides you can pop the top off and see the tray. I bet there is a disc somewhere that didn't fall back into its right spot and it will give you that error... I just opened mine up and sure enough there was a DVD that was in the way... I removed that disc and the error went away. I hope that helps you out as well.
Posted on Oct 02, 2008
SOURCE: Sony DVP-NC600 Multi-disc DVD Player No Disc Error
The only other thing I can suggest, having repaired many Sony CD/DVD players, is to get a can of compressed air and try to blow any dust out from the laser assembly. Since you've already cleaned the lens (the most common problem), you also might have dust down inside the assembly. Try blowing with the air nozzle down inside, around the gap between the lens and the cover surrounding it. Do it from at least a couple of inches away, if the air is too powerful you can damage the wiring inside the assembly.
If this fails to correct the problem, your laser output may have diminished over time and the only repair is to install a new laser assembly. The cost of this part will most likely not be worth it to you since the unit is quite old now.
Posted on Mar 02, 2009
Apr 30, 2011 | Sony DVP-NC600 Multi-disc DVD Player
Mar 01, 2011 | Sony DVP-NC600 Multi-disc DVD Player
Dec 26, 2010 | Sony DVP-NC600 Multi-disc DVD Player
Apr 24, 2010 | Sony DVP-NC600 Multi-disc DVD Player
Mar 14, 2010 | Sony DVP-NC600 Multi-disc DVD Player
May 04, 2009 | Sony DVP-NC600 Multi-disc DVD Player
Mar 02, 2009 | Sony DVP-NC600 Multi-disc DVD Player
Mar 10, 2008 | Televison & Video
Jan 06, 2008 | Sony DVP-NC600 Multi-disc DVD Player
Dec 25, 2006 | Sony DVP-NC600 Multi-disc DVD Player
1,430 people viewed this question
