Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony grand wega
I'm having a problem with our tv its a Sony grand Wega kdf-55wf655 it shut off and is not turning back on. It's been a couple days and the light flashes 6 times then goes off for a second and flashes 6 times again over and over. Please let me know what I can do. I heard it could be a fuse but I have no idea what or where to get one.
Thanks
h_moreno01@yahoo.com
    Genius:
  • 2,035 Answers
The LAMP light is flashing. function lno1() {}
lno1() If the LAMP light is flashing, first attempt to perform a power reset on the television. If this does not resolve the issue, then the lamp inside the LCD projection television may have burned out and will need to be replaced. If this appears to be the case, consult the Replacement Lamp Part Number table to determine the correct replacement lamp for use with your projection television.
NOTE: The LAMP light is not the same as the POWER/STANDBY light.
or use this link to get the manual
http://esupport.sony.com/US/perl/model-find.pl?mdl=KDF55WF65536
good luck...............
Posted on May 19, 2008
  • 2,326 Answers
Dead 6 Blinks. B+ error. Relay (RY1901) on F Board is chattering. The relay would click three times then power LED flashed six times. Standby 7 v OK.
CAUSE: the failure could be Found in the Q Box.
    Genius:
  • 1,665 Answers
It may be a power supply fault
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos May 19, 2008
    You must remove cover to look for a fuse near AC line input area board.
My sony wega kdf-46e2000 keeps shutting off. after a few minutes
Replace the lamp would be the first course of action. Also counting the blinks of the led on the front will give an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a grand wega kdf-55wf655 projection tv.
The detail of your fault is given below according to the SELF DIAGNOSTIC SYSTEM.
The description is given below:
6 : Low B error When no "DD 6V " is detected, pin 129 of TV-micro is low and it turns off the main power.
Suggestion:
This problem is little bit technically difficult, therefore i advise you to please contact any expert who can handle this or contact SONY SERVICE CENTER.
Hope you will understand my saying.
Thanks for using fixya.
Jul 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv just shut off and red light is flashing
Most Sony 6-blink codes for projection TVs follow this pattern:
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
Mar 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony wega KDF-42WE6 55
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
Jan 16, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
2 yr old Sony Grand Wega KDFE55SA20
Try cleaning your air filter sounds like its a thermal problem, often its due to an obstruction in the air filter.
Jan 16, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony TV Screen
Is you model listed below?
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
107 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
