Question about Canon BJC S300 InkJet Printer
Printer will not turn on
My printer will not turn on on any of my usbs. Tried hooking up other equipment in which they turned on but the printer did not.
What should i do?
Thanks
    President:
  • 2,712 Answers
Try a different USB cable. If that does not work, try the printer on a different computer. If it does not get recognized there as well, then your printer is probably defective and you'll need to get it serviced.
Also make sure that you have the latest drivers installed for your printer for your OS.
Posted on May 19, 2008
My Dell 3115cn printer will not connect to the network (it still works on USB cable), hard to believe it's broken, so can the printer system be reset?
Try turning off the printer and disconnecting power plug from wall. Hold power on button for about a minute. Then replug unit and turn power on - it should then attempt to hook up to your existing network.
If no go, try reinstalling the software that initially came with printer and was used to set up the network
Jan 10, 2017 | Dell Office Equipment & Supplies
Windows 7--64 bit. USB port, was working. Had power outage due to lightning striking corner of house, burned out some breakers. Printer was on surge protector, but printer and PC not powered off prior to...
See if printer will work in another working computer. If it does the issue is with your computer hardware/software. If it also does not work then the issue is with the printer. And if so, it is not cost effective to repair given the price of printers these days.
Mar 03, 2017 | Brother MFC495CW AllInOne InkJet Printer
How to connect to a laptop
Lexmark is one of the most popular printer manufacturers, and the installation process is fairly straightforward no matter what computer brand you have. Lexmark, however, doesn't always include all of the equipment required to hook up the printer. If you want to hook up your Lexmark printer to your Gateway laptop, you will probably need to purchase a printer USB cable.
1.Plug your Lexmark printer into the power outlet.
2.Turn on your laptop, or make sure all software programs are closed if your computer is already on.
3.Insert your installation disk into your Gateway laptop's CD or DVD drive. Wait for the "Welcome" screen to appear. If it doesn't appear after a minute, launch the installation CD manually by going to your start menu and clicking on "Run." In the "Run" field, type: D:\setup.exe
4.Press the "Install" button on your "Welcome" screen to go on to the "Introduction" screen.
5.Press "Continue" on the "Introduction screen" and press "Continue" again on the "Read Me" screen. Agree to the license agreement and follow any additional installation prompts.
6.Connect the Lexmark printer to your Gateway laptop when prompted. Plug the USB cable to the back of the Lexmark printer in the "Quick Connect Laptop Port." Then plug the other end of the USB to your Gateway laptop.
I hope you find it very helpful. Thank you for using fixya.
Aug 19, 2011 | Lexmark X4650 InkJet Printer
Bought a used HP1022n printer. Need to hook up to my computer as a local printer. When trying to instal the driver, the set-up says waiting to connect to the computer. I have the USB cable connected,...
Make sure you don't have the printer connected until after you install the driver. If you had the printer hooked up to the computer before you installed the driver, uninstall and start over. There should be a prompt during the installation process that tells you when to hook up the printer. If that doesn't work, you may have a driver for a different operating system than what you have on your computer. If you need further assistance, please email me the operating system you are using on your computer.
Feb 07, 2011 | HP LaserJet 1022n Printer
When I tried to scan some pictures to my email from my HP4250 all-in-one, I get a messege telling me that the printer is not hooked up to a USB plug, what should I do to fix this problem?
try to disconnect your usb printer cable that connected to your pc, then connect again
if still like that use another cable and connect
turn off your printer then turn on again
i hope this helpful
thanks for using fixya
Jan 25, 2011 | HP Office Equipment & Supplies
Have unplugged power cord & usb cable & rebooted computer and there is still no communication. have tried to uninstall/install printer and there is no communication between the printer and...
Did you install the drivers for this model? Did you run the install disk? Try hooking all up and turn it on while the computer is OFF the turn it on, it will have to recognize the printer then.
Aug 14, 2009 | Lexmark Z2300 InkJet Printer
I want to hook the printer to my computer
What brand printer? Is it an HP laserjet/inkjet?
If the printer is relatively new, there should be a USB Type B port on the printer. You'll need a USB cable that can connect the printer to the PC.
Once you have the USB cable plugged in, make sure the printer is turned on. If running Windows 2000/XP/Vista the hardware manager should automatically try to install the printer for you.
You can check that the printer installed by going to Start > Control Panel > Printers and Faxes. You should see the printer listed.
Jun 01, 2009 | Lexmark Color JetPrinter 3200 InkJet
Printer won't communicate
Verify your printer is compatible with your computer.
The printer supports Windows XP, Windows XP Professional x64 Edition, and Windows 2000
Correct communication problems between the printer and the computer.
  • Remove the USB cable from your printer and your computer. Reconnect the USB cable to your printer and your computer.
  • Turn off the printer. Unplug the printer power cable from the electrical outlet. Reconnect the printer power cable to the electrical outlet, and turn on the printer.
  • Restart your computer.
Aug 19, 2008 | Dell 946 All-In-One InkJet Printer
Printer won't print says USB is not hooked up
Windows freezes at startup unless hp 1350v printer is off - USB issue?
Hi.
u r facing realy interesting problem with u r printer.can u check u r printer wihht other system ? it can possible that u r win xp geting error to recognize u r printer ..please Check u r printer with anather Pc.
it should be problem with u r Printer or OS
if when replacing system problem get same please use below link for get update for u r printer
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=306895&lang=en
in this link please download all updates in updat colum install it on u r system .it should be resolve
If this Link useful for u please Rate me ......
It is Helpful for my Rating avg.
Jun 28, 2008 | HP PSC 1315 All-In-One InkJet Printer
Canon BJC S300 InkJet Printer Logo
160 people viewed this question
old marine
old marine
Corne Viljoen
