Question about Lightning Audio b2.250.1 Car Audio Amplifier
Hey Are you sure that the terminal isn't shorted to the case of the amp? which means explain a little what is a output transistor and would that be related with the sound witch it does have
  • 631 Answers
The larger transistors clamped to the the heatsink are the output transistors. The sample amp on the page that I posted on the previous message explains the basics. I would need clear photos of the inside of the amp to be more specific.
Posted on May 19, 2008
MY MHC-GNZ7D MUSIC SYSTEM ONLY SHIWING PLEASE WAIT , ITS NOT WORKING PLEASEGIVE ME SUJETION
One possibility is that the power-on speaker protection delay is stuck on. The most common cause of this is a shorted transistor in one of the power amplifier channels. In that case, you will need to replace the speaker driver transistors in that channel. I don't have service information on your particular model; it may use power amplifier modules rather than individual transistors.
The tricky part is identifying the amplifier power and speaker output terminals to test for this problem. To find a shorted output transistor, you need to measure the resistance between the output of each channel and the plus, then the minus power supply connections. There is a relay between the amplifier output and each speaker terminal on the back; this relay is turned off by the speaker protection circuit, so you can't measure from the speaker terminals. If you have a fried transistor, one of the tests will show a resistance of a fraction of an ohm. A good transistor will have a very high resistance or read open. This will be the case whether you have modular amplifiers or discrete transistors.
If you see a blown fuse, that is a strong indication that you do have a fried transistor. Sometimes the speaker protector circuit shuts down fast enough to save the fuse, but not always.
Apr 27, 2011 | Sony Audio Players & Recorders
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
Jan 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
401s Rockford Fosgate Amp. Not turning on. No power light. Pos+ and GR- are solid. Thought it may be remote, so tried running a wire from the POS+ to REM to test it, no luck
Amp Failure:
These repairs are best left to a repair tech familiar with car audio amplifiers. Check with your local shop to get a reccomendation. If the light isnt even coming on, chances are your input or power supply has been taken out.
Jan 01, 2009 | Rockford Fosgate Punch 401S Car Audio...
No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
Dec 31, 2008 | Blaupunkt PCA460 Car Audio Amplifier
I have an audiobahn A8000t amp with the protection light on
Note:
Dec 30, 2008 | AudioBahn A8000T Car Audio Amplifier
I have a fosgate 301x with power to the amp but none coming out
Note:
There are no internal fuses on any car audio Amplifier. Servicing will be required.
Dec 30, 2008 | Rockford Fosgate Punch 301X Car Audio...
Well my amp comes on but it doesnt give out like bass power or its jus not working like it use to the light comes on orange or red
Note:
Dec 30, 2008 | Visonik V4208 Car Audio Amplifier
Amp turns on just fine but no sound comes out
Amp Failure:
Seems as you have blown an output. Seek repairs.
Dec 29, 2008 | Power Acoustik A3000DB Car Audio Amplifier
Hello....
If you disconnect the speaker wires from the speaker terminals on the amp and the amp still goes into protect mode, the amp probably has shorted output transistors. If that's the case, the amp is probably not repairable. The outputs that Sony used were discontinued and there are no other transistors that will work properly (unless some of the newest transistors are compatible).
If it's under warranty, contact Sony. If it's out of warranty, contact one of the authorized Sony service centers to see if they can help. They may have a supply of NOS parts that would work.
Nov 23, 2008 | Sony XM-DS1600P5 Car Audio Amplifier
Amp problem
If it's not, the amp probably has a shorted output transistor.
If you want to repair it yourself, read through the following page. It explains the basics. Let me know if you have any questions.
Basic car amp repair primer
May 15, 2008 | Lightning Audio b2.250.1 Car Audio...
Lightning Audio b2.250.1 Car Audio Amplifier Logo
46 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Richard Lukszys
Richard Lukszys
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
